Question about Logitech 250 Headset
I've bought a logitech headset for my Dell Dimension 8300 and can't seem to get it to connect properly. It had two jacks, not USB.
  • s_a_macdonal Jan 11, 2009
    Many thanks for your help. All sorted now.
    I ended up seperating the wires on the headset to allow me to have one in the front of the box and one in the back, and all is working well now.
  • 827 Answers
One goes into the green headphone/speaker plug and the other goes into the red 'microphone' hole, or maybe the blue 'line in' hole, but only if that has been set as the 'line in'.
You can change the settings of the audio ports in your soundcard software eg Realtek Mixer.
Test your levels in the Audio/Video Setup of Messenger or in the Audio settings in the Skype 'Options' under Tools.
Hope this helps
Chris (ziraffa)
Posted on Jan 11, 2009
  • chris grams
    chris grams Jan 11, 2009
    Remember and try the different audio devices from the drop down lists in each program until you find the right one. The default audio device driver for the Mic and the default one for the Headphone/Speaker might not be the one you want. Good Luck :)
Headphone jack of my laptop does not work properly. I get sound from both the laptop speakers and in the headset. So i bought a USB audio device. Still the sound comes from laptop speakers and there is no...
You have to set the software in order to connect the wright way. with a USB device it will never work.
go to the properties of your audiocard and theire select what you want
Feb 13, 2010 | Logitech 250 Headset
Activating mic on Dell dimention 8300-- I connected mic then went to sounds, audio devices then volume and advanced then option & properties & record. Nothing? Please tell me what I'm not doing....
Make sure that the drivers are loaded properly, Start>Right-Click "My Computer">Management>Device Management. If you have any splats under your Device Management you may just need to reload the driver. Dell Dimension 8300 drivers are here
http://support.euro.dell.com/support/downloads/driverslist.aspx?c=uk&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_8300
And also make sure it is plugged into the pink jack.
Jan 27, 2010 | Dell Dimension 8300 PC Desktop
Dell s2209w with a GeForce fx5200 blinks black
Make sure your refresh rate is not set too high. for the 192N it should probably be not much higher than 60Hertz
Jul 31, 2009 | XFX GeForce FX 5200, Graphic Card
How do I connect a mike headset to a Dell Dimension 3000?
Does your headset have two plugs? One will plug into the mic jack that would be your Microphone. The ear part plugs into your sound out or speaker out.
Jul 11, 2009 | Dell Dimension 3000 PC Desktop
I BOUGHT CHEAP RAM, EBAY, DELL DIMENSION 8300 HUMMING
This system supports ECC and non-ECC Rambus modules. ECC and non-ECC modules can be mixed but ECC feature will be disabled. Modules must be installed in pairs. multiple modules - PC800 the max is 2 GBs
systems tool...run disc clean up...put a check mark in every box, you don' need anything there as it is all copies you have elsewhere...
then defraggment also in system tools.
If you really feel like making that ole girl hum, do a complete reinstall using the latest drivers from the dell site. If you use your service tag number it will select the better drivers for your application.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8100&os=WW1&osl=en&catid=&impid=
go to this page for drivers (above) select your operating system (2000-ME-XP-Vista).
hope this helps you. Please leave rating
May 06, 2009 | Dell Dimension 8300 PC Desktop
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
I have installed windows 2000 server on dell dimension 8300 i cant get display and usb drivers
You can try the same XP drivers which is available on the website.
Click Here to download drivers.
Thanks, PREM
Mar 31, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 flashing amber power light and dead pc
it seems *********** board is having problem plz send it for servicing
Aug 08, 2008 | Dell Dimension 8300 PC Desktop
Logitech 250 Headset Logo
116 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
