Question about Graco Baby Gear
Need to replace graco swing circuit board
The motor is good, the circuit board appears to need replacement
3 Suggested Answers
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Posted on Nov 20, 2009
SOURCE: baby swing......graco doesn't swing
We`ve recently bought a 6 speed swing second hand and had exactly the same problem ie it only worked when the swing was empty. We found that if you give the swing a nudge before switching on the motor this sometimes works as the motor only has to keep the swing moving.
If this doesn`t work, strip the motor down and check the contacts. A poor contact will mean that you get less power from the motor. Be careful not to break the connectors on the motor as you take it off as they are fragile. If any contacts appear weak, then they should be carefully soldered to make a strong contact.
Then carefully reassemble the motor on the swing and give it a push to get it going before switching on the motor.
Hope this helps someone reading this.
Ian and Ellie.
Posted on Dec 14, 2009
Why does the control board on this Sanyo CL2472 Split unit keep going out? 3rd one appearantly I replaced the most recent one 2 months ago
•Poor ground, at unit or disconnect/breaker panel
•Shorted wiring from I.d. to o.d. unit not shorting out all the time,
I've had a o.d. fan motor take out a couple of boards. •The motor was "stiff" to turn and the high resistance during operation damaged the board
•Ive learned anything, wiring or load, connected to them over-engineered circuit boards can damage them. Get a good voltmeter you trust. Certainly get a set of small leads for your meter due to the cannon connector sizes. Call tech support and write down everything you can. Ask for resistance values for loads and circuits. Start with the o.d. fan motor, I always do. Took me 3 warrantied boards before I found it BUT, I only found it when I had a new motor next to the old motor and I spun it. Could feel the bad was Stiff compared to the new motor. And start troubleshooting in the area that's connected to faulted area on the board. Tech support can help there. Work safe!
Jun 22, 2015 | Sanyo Heating & Cooling
Printonix p 500 error papfd drvr cir
Paper Feed Driver Circuit. The paper feed driver circuit on the controller board is drawing too much current.
1.Cycle power. If the message appears, replace the controller board. Record the message and return it with the defective board.
2.Power on the printer. If the message appears, replace the paper feed motor.
Jan 20, 2014 | Printronix Line Matrix P5005B Printer
I need to replace the circuit board on Tectrix Bikemax 3000 recumbent. Any idea where I can find a circuit board?
Here is a quick list.
www.fitnessrepairparts.com/equipment/Select/10131/Cybex/BM1000-BM3000-BikeMax-S-N--640000-Y02Tectrix Bikemax 3000
Jan 18, 2014 | Exercise & Fitness
Error code Lr
LR usually means that the the signal from the control circuit board is not getting to the motor either because of a bad connection at either the motor or the board or the motor itself is no good. Need to check the connections first, if they are ok replace the CCU (central control unit) board, this is the board behind the touch controls.
Nov 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Belt won't turn.
HI, please replace the control board
Sep 29, 2009 | Spirit Esprit ET4 Treadmill
Need to know how to replace the windshield wiper motor
First remove the wiper arms.Then remove the screws that hold the black plastic grill, you will see the motor.You will need then to disconnect the wiper arm transmission linkage from the motor, then remove the three bolts holding the motor on, dont't forget to disconnect the electrical connector from the motor.Install in reverse order.Good luck.
Jul 20, 2009 | 1999 Chevrolet Silverado 1500
Reebok i run stopped working after 5 mins power light on . display screen blank
it sounds like it may be the fuse on the motor circuit board? if you unscrew the motor cover and have a look inside(ensure you have turned the power off) you will see the circuit board and the fuse is in the middle. take it out and have a look to see if it is intact. go to Maplins and ask for a replacement as it is not a standard fuse, it is a 'time delay fuse'.
if this does not resolve the issue, you may need a replacement motor circuit board (around £40) which is very easy to replace. if you need help doing this let me know and ill guide you through it.
Apr 16, 2009 | Reebok Vista Treadmill - RBTL13305
Rheem Air Handler will not run. This is a 2006 Rheem model RHLA-HM3617JA Air Handler. I replaced both the condenser and air handler circuit boards. I replaced the motor in the air handler.. The condenser...
Have you hard wired your fan motor to verify that the motor and or the capacitor are good? If you do a continuity test of the motor leads(with electricity off of course) you can see if the motor has open or grounded windings.
Apr 11, 2009 | Ruud Handler Air Conditioner
Need wiring diagram
i dont think u need a wiring diagram. you should check your wiper motor circuit board first. on my 94 s10 the wipers either worked when they wanted to and now they dont work at all. just either replace the circuit board yourself ($19.95 on ebay) or replace the whole wiper motor ($60 on ebay) and your wipers should work. just give this a shot as its a good place to start. i myself am going to replace the wiper circuit board as its cheap, and really easy to access and replace. all you need is a screw driver. good luck. and no, im not a GM Technician. just owned my truck since day 1 and always try to check vehicle forums for answers first.
Aug 01, 2008 | 1994 Chevrolet S-10
Kenmore Elite Topload Electronic Controls
try replacing the start capicator on the back wall of the washer small black cylender with two wires on it ps your old motor is good if this fixes it
Jan 14, 2008 | Washing Machines
Baby Gear Logo
564 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
