Question about Graco Baby Gear
Graco swing circuit board is bad - Graco Baby Gear
3 Suggested Answers
SOURCE: Graco swing not working, I'm trying to open the motor box.
You need to remove the center of the part the connects to the chair. Use a thin screwdriver to pry it out a little, slide the screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off.
Posted on Nov 20, 2009
SOURCE: baby swing......graco doesn't swing
We`ve recently bought a 6 speed swing second hand and had exactly the same problem ie it only worked when the swing was empty. We found that if you give the swing a nudge before switching on the motor this sometimes works as the motor only has to keep the swing moving.
If this doesn`t work, strip the motor down and check the contacts. A poor contact will mean that you get less power from the motor. Be careful not to break the connectors on the motor as you take it off as they are fragile. If any contacts appear weak, then they should be carefully soldered to make a strong contact.
Then carefully reassemble the motor on the swing and give it a push to get it going before switching on the motor.
Hope this helps someone reading this.
Ian and Ellie.
Posted on Dec 14, 2009
How do you turn off a graco open top swing?
www.gracobaby.com/instruction%20manuals/archive/152.pdf
GracoTo add time, push the time button once or twice. To turn swing off, press and hold either speed button briefly.
Jan 08, 2016 | Baby Gear
Graco swing
I'm not sure if you tried a different outlet plug yet, but I would try to eliminate whether if its the power source (outlet) or the swing itself. Also, if the outlet has a reset/test buttons on it, then it might have tripped itself.
Apr 23, 2013 | Baby Care
We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
How to disassemble graco swing
First, take part the seat. It had buttons and what not so undo them and take it off the frame. 2nd: Take the mobile (where the teddies hang) part by pulling. From there you just pull things apart. You shouldn't need any tools.
I hope this helps a little.
Apr 27, 2012 | Graco Lovin Hug Swing - Erin
There a bar that came off the swing that I have. Just using for the first time it was given to me by some one so it does not have instructions. So can u pleaseeeeeeee help me and tell me where the bar is...
Most of the time if you go to Graco's website they have manuals for these type of items. I had to do it for my new Fisherprice swing. If you can not find it there call them and they will send you one. I had to do that before too.
Jul 08, 2011 | Graco Winnie the Pooh Swyngomatic Infant...
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Graco swing not working, I'm trying to open the motor box, but can't get the last screw out, which is behind the swinging attachement.
Nov 15, 2009 | Graco Baby Gear
Baby Gear Logo
50 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
