I have a good connection to my home network, this is a new computer I use for school, everytime I move from one page to another, I loose my internet connection, I believe I have a wrong setting on this computer, can you help
  • cecheese Jan 12, 2009
    Thank you, that worked!
    Champion:
  • 209 Answers
Check your bandwidth if this is with in 80% of the internet speed given by your ISP you can determine by using the www.speedtest.net site or some other sites that measures the speed of internet prior from this you need to delete the cookies. temporary internet files and history. if your bandwidth seems to be below from the speed of internet which you applied for, you need to report to the technical supports of your ISP to fix the problem.
Posted on Jan 12, 2009
How can proxy server bolked ?
A proxy server is a computer used to act as the one contact point between your computer and the open Internet. The primary benefit of a proxy server as that it can cache (store) Internet web pages and other content on its disc drives. When a user connected to the proxy server requests a web page or content that was previously accessed by another user, the proxy server can deliver that content/page from its cache to the new user without having to go out to the Internet.
Network administrators can configure a proxy server to prevent users from reaching dangerous or unauthorized web sites. So if your computer is connecting to the Internet through a proxy server, you will be using whatever restrictions the network administrators have set up. If you are not using only your home network, you are most likely NOT using a proxy server. If you are using a school, university, organization or corporate network, then you are most likely USING a proxy server to connect.
Feb 28, 2015 | Computers & Internet
Tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 | Computers & Internet
Tip
How to connect to always automatically connect to your SSID
Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
  1. A computer with a wireless adapter
  2. A wireless router
  3. An active internet service
  4. This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
  5. This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID
is the technical term for your broadcasted network name. This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.
Let's Begin.
Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to Control Panel and then left click on it.
Double click on the Network Connections icon.
Double click on Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on Properties.
Click on the Wireless Networks Tab.
Now scroll up and down under Preferred networks until you find your Wireless Network Name (SSID). For me, it's called linksys therefore I will select linksys.
Now click on the Connection tab.
Under Automatic connection, click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
on Apr 05, 2010 | Computers & Internet
Wifi wont connect and some other
well, the signal, may be good, but if theirs a huge amount of people on the same acess point, things get messy. if u have alot of people using the same network, the internet becomes laggy, and even if u have a good signal, the internet can be very laggy, and lose connection alot, it depends on the amount of people using the same network, so at home u have only u and ur family connected, at school more people might be connected to the network than at home.
Jan 21, 2012 | ASUS Computers & Internet
PAGE SAY BANNED----CANT GET ON DEALOZ SITE
From where are you trying to reach that page??? from your home internet???, from a public internet connection (internet caf?)??? from a library ???, from a school??? from worke???, when a site is BANNED it is becaus the site is blocked by a proxy server or firewall ussually what you would find in a public connection, school, or worke place (shop, office, etc...) and is often managed by the IT team, if it's from your home connection than you should reset the router (to clear all firewall rules that could have been set by someone), than re-program the router...
Apr 15, 2011 | dealoz.com
Everytime my wife's iphone connects to our home network, my laptop looses the internet connection and goes to a local connection only. I have to disconnect and reconnect and everything works fine.
I find that when it comes to iphones and home wireless networks, that using 64bit encryption is the best. I'm not sure what you are using now, but give this a try.
May 03, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Everytime I try to log into facebook it another page says expired
well, the connection timer has timed out, It has to do with internet connection speed and consistency. If your connection to the site gets dropped, it's because the website doesn't hold it's connection open too long waiting for your computer to connect to the site, which ties up the server/network. once the timeout ends, your connection expires. Basically your computer only has a certain amount of time to connect to the site, if it doesn't, the connection expires. And Facebook is hugely popular. hope this helps.
Apr 02, 2010 | Microsoft Windows XP Home Edition
I have hooked up a switch box to are internet service .so I can use another computer but everytime i try to download or look at anything it says page cant be displayed or no connection .What do I do?
Make sure your original ethernet cable from modem is pluged into #1 port on your hub. reset modem by unplug then restart all PC's on your network. Good Luck.
Nov 20, 2009 | Microsoft Windows XP Home Edition
I cant login into my space my school has it blocked
Multiple solutions:
-Log into the computer as an administrator. The admin account possibly does not have the same policy.
-Install VPN software on the computer at school, also install VPN software on your home computer. Login to your home computer through the VPN software at school and browse the myspace pages.
-Long shot but give it a try, change it back if it doesn't work -
Open Internet explorer, Select tools from the menu list, select Internet Options from the bottom of the drop down list, Select the Connections Tab, Click the LAN Settings box torwards the bottom. Deselect "use proxy settings", select "Automatically detect settings". Restart IE. If you get nothing, change it back.
-Get myspace IM on your cell phone
Apr 14, 2009 | MySpace Social Network
Need wep to connect laptop from school to home network while at home
YOU SHOULD BE ABLE TO FIND THE WEP KEY IN YOUR INTERNET CONNECTIONS. IF THERE IS NO WEP KEY, JUST CREATE ONE AND YOU SHOULD BE GOOD TO GO. THIS CONNECTION LINK HAS A TAB TO SHOW CHARACTERS IF THE KEY HAS BEEN ENTERED. YOU WILL PROBABLY HAVE TO REMEMBER IT, OR JUST CREATE A NEW CONNECTION WITH A NEW WEP KEY! THAT IS THE EASY WAY! GOOD LUCK.
Oct 30, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Computers & Internet Logo
David Payne
David Payne
