Question about Plumbing
Onga smh 90
Need reassembley instructions
How old is the Onga 443? Do you have a pic of it please?
Hello, Ria -
Only the manufacturer of the Onga 443 MAY be able to tell you how old your pump is. You would have to provide the serial number for the pump, in hopes the company has manufacturing records in its archives. The company archives should probably have photographs of the Onga 443.
I refer you to Pentair, the oompany which owns the Onga brand name and manufactures the pumps. See the Pentair Contact Us page to find the email address for Customer Service:
http://www.onga.com.au/contact-us/
The email addresses there seem to be for sales. I would still use the email address for the country where you reside and ask that your message be forwarded to Customer Service.
Best wishes.
Jan 21, 2018 | Plumbing
How much zeoclor in an LS 24 onga
Does not matter on pool size, but on the filter tank size!
Follow Zeo's label instructions, as they may recommend a reduction of their product vs. Sand, say 80% of recommended sand amount. Good luck
Feb 23, 2015 | Pool & Spa
I am having trouble assembling the empellers on my onga shm45. Any instructions or vids please?
Try entering your question on You tube It's amazing the info on there.
Oct 10, 2014 | Pool & Spa
I need to unsubscribe from the SMH app from the app store
Open app store on your iPad
Tap on the featured button, scroll to bottom of page >tap on Apple ID
Sign in with your Apple ID and password
View account>enter password
Manage subscriptions
Tap on the SMH/AGE for iPad subscription and turn off auto-renewal
Oct 25, 2013 | Computers & Internet
I have an Onga smh45 which keeps tripping out and you have to push the reset button. I have had it in to two repairers and they say they can't find anything wrong with it. Any assistance would be...
This could be your problem. Make sure it isn't running dry.
D.R.O.P (Dry Running Over-Temperature Protection)
The Onga SMH series of pumps (excluding the SMH35) are fitted with the internationally patented D.R.O.P system which protects the hydraulic parts from possible damage that can be caused by overheating of the liquid inside
the pump casing. The overheating can be the result of external causes (outside the pump) or occurs because the pump stops priming and as water is pumped out the
pump runs dry.The D.R.O.P system is reset using the switch located on the condenser.
If you have access to an amp meter, measure the curring when pumping full load, and be sure it is less than the full load amperage listed on motor.
Aug 10, 2010 | Plumbing
Onga sand filter pumps sand in to pool ,just got re connected to new above ground pool
The lateral(s) are damaged and allowing sand thru and back to the pool. I have never dealt with that specific brand to know if the laterals come as one assembly or individual pieces. You'll need to contact the dealer you got the unit from or check online at http://www.onga.com.au/dealerlocator for someone in your area.
Dec 05, 2009 | Pool & Spa
Plastic impellor sticks inside on onga pool pump and i can't get free .When i try with phillips head screwdriver it is jamming and i can't loosen to get impellor off and the pump only makes noise and can't...
Your Onga Pool pump was running dry causing the
impeller to melt down and stick to the pump case.
You have to remove the impeller, and the only way
to take it off by using the heat gun to melt the stucked plastic impeller. Or by forcing it off slowly, cutting the impeller using hacksaw, taking care of the mechanical seal and the motor shaft not to bend it. Afterwhich you can replace the impeller, and assemble the Onga pump/motor. Then, you can
install the Onga pump back to its location. Just
send you e-mail for further assistance. God bless
you.
Oct 20, 2009 | Plumbing
Onga jsp 130 leaks
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase
off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Sep 07, 2009 | Plumbing
Diagram to repair onga house water pump
Got an Onga Riva-Flo water pump, model number TF30, its not working, can you suggests why and how to fix it please.
Feb 20, 2009 | Northern Tool 12 Room Purple Martin House
Plumbing Logo
154 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
