Question about Refrigerators
Sub zero 650. Service light is blinking. What to do to fix it? Everything else is ok. I try to reset service light but after few days io on again. Any suggestions?
    Sergeant:
  • 198 Answers
Thank you- sub zero when I called told me to shut the breaker off for 15 minutes and see if that clears the code- I still have a call in for service for Monday- any further thoughts from you??? thanks,
Posted on Dec 02, 2012
  • 173 Answers
SOURCE: Service Light
Tighten bulb.
Posted on Jul 08, 2009
navidh
  • 65 Answers
SOURCE: We have a 5 year old side by side sub zero fridge/freezer (largest size)
Check the fan in the rear of the unit.  If it is running, check the rear panel inside the freezer section and tell me if there is frost building up on the outside of this panel.
Posted on Sep 27, 2008
SOURCE: sub zero 650-display
If you cleaned out the condensor unit, your problem is probably a bad evaporator. Schedule a service call. If the condensor was really dirty then you may have just compacted the dust into the condensor in which case a shot of CO2 would be a good idea.
Posted on Oct 07, 2008
  • 5 Answers
SOURCE: Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Posted on Jul 30, 2009
SOURCE: Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Posted on Jan 03, 2010
My service light is on in the refrigerator and blinking. All appears to be working fine. Freezer is set at 00 and refrigerator is set at 40. Why is my service light continuing to blink??
HI,
The unit has picked up that it is running to long to achieve desired temperatures. I would look at a clogged condenser. Most common for this unit, as it should be cleaned twice a year. Does your unit have a bell logo on the display panel? if so, hold it 10-15 seconds to reset the service light. If no, then unit unit off for abut a minute, this will also reset the unit.
If the light returns in a few hours or days, you will need a service professional to check over the unit. Last question for you, do you or have you notice a "ice ball on the wall of the refrigerator section behind the meat role at drawer? If so call a licensed repair person to repair this when possible. SubZero has the longest warranty to help you, you can alway call them directly to answer questions also.
I am a certified servicer for SubZero, I can help you, just need little more information.
Aug 03, 2011 | Sub-Zero 650 / O Bottom Freezer...
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
My light says "vacuum condenser". I cleaned coils and fan and turned unit back on. Light came back on in few days, also don't know where reset switch is. Thanks
Good day,
The power off/on switch is the reset proceedure on most Sub Zero's however, it initially comes on when the unit senses the temperatures are too high, leaving the compressor.
It also is a known fact that a Sub Zero condenser cannot be cleaned by vacuuming only.
Service techs use either compressed air or nitrogen with a hose to blow the condenser clean.
Lacking that, a good push -pull shop vac with a crevice tool makes a good substitute.
Remove top grille, and the cover plate for the compressors.
Aggressively blow the condenser out from both sides.
Make sure it is clean, by shining a light on the inlet side, and making sure you can see thru the fins.
It's ugly, dirty and makes a real mess,
But the option long term, is winding up replacing the compressor(s).
Dec 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650: Ice Service light on
turn the unit off for a few minutes then back on. If you have a real problem that needs to be serviced the service and ice light will star flashing again relativly soon
Jun 30, 2009 | Sub-Zero Bottom Freezer Refrigerator
Feb 19, 2009 | Sub-Zero 642
Sub zero 650-display
Oct 03, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
630 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
