Question about Toys
How do you charge air hog hover assault
I charge the helicopter but then red light blinks then it turns of and green light starts to blink. Then I use it and I can use it for a small amount of time how do I charge it?
Just had the same problem and realized that one battery was in upside down. Even though they were in the way the manufacturer had specified on the diagram inside the battery compartment. Check the batteries , making sure all the negative ends (the flat ends) are on the side with the spring.
Posted on Nov 11, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: Need charging instructions for Air Hogs Havoc
1.Take out charging wires. 2.turn off your heli and insert charging socket into your heli's socket. 3.the charging green light will light up while charging. 4.charging complete, the green light will turn off. 5.pull out the wires and you are ready to fly. Let the heli's battery cool down for approx. 15 minutes before charging.
Posted on Jul 21, 2010
  • 4 Answers
SOURCE: when i turn on the remote control, the red on/off
The batteries in the controller are nearly flat
Posted on Oct 02, 2010
SOURCE: My air hogs sharpshooter is
Did you turn the actual helicopter OFF? make sure that is switched OFF. Did that help?
Posted on Dec 02, 2010
Air hogs charger blinks red then turns off
Make sure you have the switches set properly.
Dec 28, 2012 | Air Hogs Toys
How long does it take to charge. mine has a problem charging and operating. how do you know when it is charging?
the light on the front of the heli blinks green red green gred then when its fully charged it just blinks green. also make sure the tx is turn to the charge setting which is all the way down
Feb 21, 2011 | Air Hogs Reflex Micro Helicopter
SharpShooter won't charge.. instead of Blinking red light (Charging) I'm getting a blinking Green one ????
Hi just got one myself and after a day same problem. Replace all your remote batteries with new ones And it will charge normally with blinking red then red and green blinking. I enjoyed flying it but enough is enough. There is no replacement blades, It eats batteries. I would go with this sites micros http://www.xheli.com/rchelicopter.html
Im looking at this one, charges with usb so wont kill batt's, Metal frame and also they sell parts http://www.xheli.com/s107-miniheli-blue.html. Good luck and happy flying.
Dec 28, 2010 | Air Hogs Havoc Heli Helicopters
My sharpshooter and remote both turn on, but the helicopter does not react at all, what should i do?
I had this problem yesterday as well :)
My helicopter charged once worked and flew once for about 5 minutes. Then the helicopter stopped responding to the controller and it wouldn't take a charge. When I connected the remote to the helicopter the CHG light came on solid for about 30 seconds. This means that the controller is waiting to be plugged into the helicopter.
A couple of points to check before you go further:
1) make sure that the helicopter is turned OFF before charging!
2) When charging the red CHG light will blink.
3) When finished charging the red CHG light and the green Power light will blink at the same time.
4) After a certain amount of time both lights will stop blinking to save the batteries.
After taking the helicopter apart this is what I have found:
*The helicopter has a 140mA-H 3.7V Li-Po battery.
*The battery has a little board with 2 tiny computer chips. When the battery is empty these 2 chips will completely disconnect the battery. This prevents damaging the battery and this is why the helicopter stops responding when the battery is empty.
*There are two connections between the battery and the little board - a long connection which wraps one time around the battery and a short connection. My problem was with the short battery connection.
Solution --The little board has a short piece of foil which connects to another short piece of foil on the battery. These two pieces of foil are simply pressed together and then glued. In my case this connection broke. To fix the problem I removed the yellow tape and glue and used a soldering iron to solder the 2 foil pieces together. Make sure that you put tape (any household tape should be OK) back on the battery to prevent any shorts.
Dec 26, 2010 | Master Heaters Air Hogs Sharp Shooter...
Need charging instructions for Air Hogs Havoc heli. Is remote control switch to be turned on during charging? What position is channel switch in? Is Heli on/off switch set to charge? I have no...
Feb 19, 2010 | Spinmaster Air Hogs Battling Havoc R/C...
Toys Logo
1,559 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
