Question about Dayton E51 Oil Filled Utility Heater
I have fuel but wont inite
Its a daton e51
  • 181 Answers
What is the air pressure set at????need to be exact for unit to work properly
Posted on Feb 23, 2009
Ran out of gas put gas init still wont start
Gas or diesel engine? Running low/out of fuel is not good for the fuel pump. Gasoline cools and lubricates the in tank fuel pump. No fuel.... no lubrication or cooling.
Jul 18, 2015 | Cars & Trucks
Sir how do I unlock my nokia e51
Hello. You can unlock your Nokia E51 safer and easier using unlock code, You can get the accurate unlock code for a Nokia E51 from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia E51 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E51.
3 - Compose #pw+CODE+1#.
4 - The Nokia E51 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E51 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E51
Sep 13, 2014 | Cell Phones
I have a 2E511C heater that wont fire up but the spark plug is firing
You probably already know this . The 2E511C was manufactured by DESA for Grainger, so you must follow these Reddy Heater troubleshooting tips.
It sounds like the heater is not getting fuel or the fuel is not hitting the spark and you must troubleshoot and find out why.
Contact me for a Dayton to DESA parts cross reference chart.
Oct 27, 2010 | Dayton E51 Oil Filled Utility Heater
I have a Daton Fuel trimmer furnace for my garage.
On the thermostat see if it has a setting for fan on auto and off try turning the fan on then see if it comes on, if it does then it may be your thermostat has failed if it does not turn on then reset the circuit breakers to see if you have a breaker kicked off. If it was wired properly there should be one near the unit and one in the main breaker panel so be sure to reset both. To do this you must force the breaker switches all the way off then all the way on. On some breakers if you do not force it to the off position it will not reset the breaker. If this does not help let me know and I will try to help you some more just replay to the e-mail you get go to the bottom of the page and post add comment
Nov 10, 2009 | Reddy Heater RLP100 Portable Forced Air...
My Nokia e51 wont send txt msg's, it used to be
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
Aug 27, 2009 | Nokia E51 Smartphone
Nokia e51 restart
i am forget our phone nokia E51 so how make to phone restart
Jul 04, 2009 | Nokia E51 Cellular Phone
Heater wont ignite. Has fuel coming out front of
if the spark plug is sparking it is hot enough to lite the fuel.is ther dirt in fuel tank???is there water in the fuel???? what is the air pressure set at????is the nozzle clean and spraying correctly?????any of these will cause the heater not to fire.not the spark plug.
Feb 20, 2009 | Dayton E51 Oil Filled Utility Heater
Wat the hell is wrong with my dayton heater?170,000 btu oil fired...wont stay runnin?on shut down puffs like a mutha....
Most use a spark plug to ignite fuel it could need cleaning. You also could have water in fuel or dirt
check and clean ignitor/spark plug clean fuel line and nozzle, drain and clean tank Check for water in fuel by tilting unit to have a low corner siphon fuel from that corner after 1 hr inspect for water.
Jan 23, 2009 | Dayton E51 Oil Filled Utility Heater
Dayton E51 Oil Filled Utility Heater Logo
124 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
