Question about Elna 1010
My elna su needle position dial is stuck .its stuck on the right position on the dial but the needle i in the centre . therefore i cannot use mu cams
4 Suggested Answers
  • 323 Answers
SOURCE: needle position
this wheel does seize over a period of time.Remove the top cover so that you can see the wheel. It can be unseized by spraying a mixture of 20% ammonia to 80% water under the wheel. Let it sit for 20-30 minutes, spray it again and then turn it with a pair of pliers. Do NOT break it!! use a soft cloth around it if you want to protect the wheel from scratches.
sewman7
Posted on Jun 18, 2008
SOURCE: have a 1970's elna su supermatic but cams don't work
There are two types of discs - single and double.
For the thinner single discs do as follows:
1.Turn stitch width knob to "0"
2. Turn stitch length knob to "0"
3. Insert the single disc
4. Turn the top selector to "A"
5. Make sure the needle selector is in the centered position.
6. You may now choose any stitch length or width you wish. I usually try "3" for the width and 1/2 for the length to start.
For the thicker double discs do as follows:
3. Insert the double disc
6. You may now choose any stitch width.
7. The stitch length must be put on "A" - this is the difference between the single and double discs!
I hope this helps!
Posted on Apr 09, 2009
neona_techie
SOURCE: Needle position wheel is stuck
Remove the top cover. Note where the shaft of the the needle position wheel enters a metal casting under the wheel. Old oil deposits gum up the shaft. Heating this area with a hair dryer usually frees up the shaft. Be careful you don't use too much heat that would melt the plastic wheel. Lubricate the shaft with tri-flow and work it in by turning the wheel while it is warm. If it sticks again after it cools, repeat the process. It may take several hours or days for the tri-flow to penetrate and free the wheel up.
Advice provided by the amazing Ray White at whitesewingcenter.com
Posted on Jul 12, 2009
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Elna SU needle position lever is very stiff
this is probably due to lack of use and just stiffening up of this lever, best thing is to take off the top cover and get some triflow oil into the lever area, then try to work it back and forwards. First though, always set the stitch length and stitch width dials to zero before you try to move the needle dial, this applies to changing the stitch selector too, always turn width and length to zero first to avoid wear on these parts internally.
If you are happy to delve a bit deeper into your machine internally you might want to join the Yahoo group called Elna Heirlooms where other Swiss elna owners share their love and knowledge of these machines, there will be message thread on this issue there for sure.
May 08, 2014 | Elna Sewing Machines
The needle won't pick up bobbin thread on mu Elna Air Electronic SU
Has this just started after a jam up? As it's usually a symptom of timing being out.
However first check needle is in right way, flat shank to the back and threading is correct including the take up lever.
If no joy then mechanic service time
Apr 18, 2014 | Elna Sewing Machines
Zigzag feature is not working
Remove thread from machine and open door to where you put cams in. Step on pedal and run at full speed. It the mechanism where the cams go spinning? It is likely that your elna graph gear is broke
Jan 09, 2014 | Elna Sewing Machines
I have a Elna Heirloom sewing machine and i have misplaced my book i need to know how to do a blind stitch.
Have you found the blind stitch foot? On my Elna SU it has a piece of metal shaped a bit like a boat rudder in the middle, going front to back. Do you know which stitch does blind stitch? On my Elna it does two or three straight stitches and then one zig zag stitch. Make absolutely certain the needle is in the centre position before you start, if not, it will get expensive on needles! Fold up your hem and press it, and tack it into position. Blind stitch is a bit different, you need to position the presser foot so that the hem is on the right hand side of the paddle, and the "body" of the item is to the left. In order to do this, you need to fold the body of the fabric again (but don't press it or it will leave a line). I'd suggest a few practice runs first on scraps of fabric, so that you get the fabric positioned correctly. It will also take a bit of fine tuning to get the needle to just take a tiny bit of the body of the item. I found it a great stitch for things like curtain hems, and fairly heavy fabrics like tweed, because done properly it's far stronger than hand sewing and the stitch hides itself in the fabric, but I find it difficult to get it just right.
Dec 17, 2013 | Elna Sewing Machines
Elna tsp air electronic 58 will not zig zag stitch
Firstly will it sew any stitches that require the needle to swing from side to side? the serpentine stitch or blind hem stitch?
As this machine is now 20+ years old (but a beautifully made Swiss Elna, don't junk it) I must ask firstly has it had a full service recently?
What can happen with these (and many machines if left for a bit) is that the needle bar bearings will sieze up and the needle won't swing from side to side. It can certainly be fixed if this is the case, I've done it with a TSP and a SU Air Electronic machine.
Other possibility is that the spring that pulls the neeld bar back to position may have broken. Check this as follows. Set stitch width dial to 4, stitch selector to zig zag and press the needle bar to the right, place your finger high on the bar, not down on the needle itself. If it moves to the right freely, then release it and it should move back to centre itself if the spring is there.
If the bar does spring back slowly and the machine hasn't been serviced for some time; then good chance its the bearings. You may want to take it for a full service as a technician can check out the timing also as well as giving it a full clean and lube internally.
Apr 24, 2012 | Elna Sewing Machines
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
Apr 10, 2011 | Elna Sewing Machines
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
Have a 1970's elna su supermatic but cams don't work
I hope this helps!
Mar 11, 2009 | Elna 1010
I have and Elna su sewing machine and i can't get it to zig zag. Please refresh my memory on the settings i should have it on.
Depends on which SU you have, but you need to move the stitch selector to Zig Zag, then set the stitch length to 2.5 and the stitch width to at least 2.
On the earlier models the stitch selector is a wheel inside the flap on the top of the machine, on the air electronics, it is a coloured dial.
If this doesn't help, check if you've inadvertently moved the needle position to the side setting.
Aug 23, 2008 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
116 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
