Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Mid cycle and then tripped the electricity without draining
The machine keeps tripping the electicity when switched on and wont drain. We have cleaned the filters and changed the fuse. Do you know what is needed. Thanks
    Genius:
  • 3,422 Answers
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Jan 11, 2009
    Sergeant:
  • 431 Answers
Check the main board
  • nematics
    nematics Jan 11, 2009
    it is due to the water log in the electric cable inside
    Genius:
  • 1,550 Answers
Did you check the connection from the circuit breaker to the unit .
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Hi my fisher and paykel MW512 top loader washing machine keeps throwing my electrical switch. A few months ago it wouldnt drain and came up with heaps of error codes and now it is tripping my switch. What...
The washer tripped the breaker once and OR after the breaker was reset it ran additional loads with no problem then it tripped the breaker again.
Intermittent problems are always difficult to diagnose because the problem usually doesn't occur when you're making the checks.
If the washer ran additional loads the problem will not be an electrical short with one of the washer parts. If the lid switch had a short it wouldn't run the additional loads.
You don't say if the additional loads used the same cycle as previously. A timer can have an internal short that might trip the breaker in heavy duty cycle but not the permanent press cycle.
If you have access to a clamp on amp meter, see the image below, then you can check the amp draw of the washer. The washer normally will draw about 10-15 amps at start up and about 5-8 amps while running. The house breaker for you washer should be rated at 20 amps.
If the washer is running and drawing less than 20 amps and the breaker trips then if can be a weak house breaker.
Mid cycle the washer is most likely draining or spinning and if the bearing or pump locks up then the washer may draw additional amps to try to start and trip the breaker.
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Mar 25, 2015 | Fisher and Paykel Washing Machines
Wmf540 beeps
Not sure your entire question but if no cycle is chosen or running and you close the door and the power trips then it is definitely your door lock mechanism. This is located to the right of the door behind front panel. If it tripped out in the middle of the cycle and by closing the door you are restarting the cycle then it will depend on where in the cycle you are up to. Of course it can always still be the door switch itself I don't usually find them tripping the power. If the machine starts the fill but trips out it is likely the inlet solenoids. If the unit fills some and then trips it is likely the motor. If the unit fills washes and then trips it is likely the drain pump. If the unit fills washes drains and then trips it is likely the motor. Of course at any of these points it can be any of the pc boards. So if you know where in the cycle it trips this will narrow down the choices.
Jul 08, 2013 | Washing Machines
Washing machine keeps tripping the electrics
you have bad circuit breakers in your house power center; replace them with the correct amperage value for your machines or, call an electrician
Feb 04, 2013 | Washing Machines
Simpson esprite 650 front loader washing machine. Electricity trips on programs b & h wash, can't complete cycle. Spinning and draining cycles OK. Why ? thanks sally
Hi Sally.Now in your posting you mentioned the machine trips the safety switch during the main wash.Is this correct?Does it trip as soon as the barrel stars to turn or a little later.Could you explain what b& h wash is.If the machine spins and drains and fills but trips during the cycle then from working on this model of machine I think the fault is your heating element.Have you tried a cold wash without any temp setting?Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Sep 12, 2010 | Washing Machines
E60 keeps flashing and beep noise. Machine is mid cycle and has come to complete stop
Electrolux E60 - NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or blocked or scaled up screens in the inlet valves
    3. Verify inlet valve operation
  • If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operation
Nov 13, 2009 | Electrolux Washing Machines
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Mid-way stoppage
Or
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
Mar 26, 2009 | Washing Machines
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
27 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
