Question about Acer Aspire 5630 Notebook
Internet connection lost
We lost our internet connection when they changed the cable wire and the modem.. but i tried to use another laptop but i connected to the internet. so what's the problem with my laptop?
  • harabel_11 Jan 11, 2009
    laptop sony vaio model PCG-7113L cannot connect to the internet anymore
  • 4 Answers
You have to go to the "Network connections" and set up a new network, your computer is probably defaulted to connect to the old modem and since it cannot find it it wont conect
Posted on Jan 11, 2009
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
Lost internet service on laptop
First, are you wired or wirelessly connected to the router? Is there any computer that is connected to the router aside from the problem one?
If you are wired connected to the router, try connecting the Ethernet cable into different LAN port of the router.
If you are wirelessly connected to the router, try disabling and re-enabling the WiFi of your laptop and try connecting again.
If there's another computer that's connected to the router and it can get online, then the problem is in your computer. Checked the Network properties of the problem computer and make sure that you are getting a valid IP address.
If you have two computers and both of them are not getting online, try connecting first one of the computers directly to the modem. If same problem occur, then contact your ISP.
If you can get online while directly connected to the modem, then turn the Netgear router OFF for about a minute and turn it back on and try again.
Hope this helps and have a good day!
Nov 29, 2009 | Computers & Internet
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
I have 2 laptop computers with built in wireless and I am trying to connect to internet via a D-Link 615. I have tried multiple things but it keeps telling me that my cable is disconnected and I have no...
HI. you have to check first what kid of modem u have.. im sure if the laptop is connected directly to the modem, u have a wired connection and u can connect to the internet.. if ur modem is a cable modem, u need to mac clone the mac address of the computer that can connect to the internet. u need to connect the computer that can connect to the internet to the router and do a mac clone and the internet connection settings is dhcp..if u are using a username and password to connect to the internet, u need to use the pppoe settings on the router, and if ur isp give u a static ip address, u need to set the router on static ip. how u can check the ip address, click on start, run and type cmd and it will show a dos prompt, type ipconfig/all and it will list the ip address, subnetmask, default gateway and dns server.. u need to setup the router first in order to talk to ur modem..
Jul 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
No connectivity from 1 laptop but connectivity with another`
Try resetting the modem whenever you change between those PC's some NIC's will hang a cable modem stuck on an address.
May 02, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
L2TP connection problem
Hello, I've had the electric cut off and immediately back on and I lost my connection from Wireless router to modem. I could not connect in the same way. I could access the router settings with wireless laptop and PC but not to internet on either. I bypassed the router and connected the PC computer to modem then to internet verifying with a browser. I then reconnected the computer cable back to router and router to modem. It stayed connected. But I'm not sure if you have a PC connected to the router also. Sometimes just unplugging some cables and replugging will solve problems. Hope this helps.
Feb 18, 2008 | D-Link AirPlus DI-524 Wireless Router
Exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Dec 22, 2006 | ASUS WL-500g Wireless Router (WL500GDLX)
Acer Aspire 5630 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
