Question about Garden
Karcher 2.180 motor won't go.
Karcher 2.180 worked fine an hour ago. Connect elsewhere and no go - motor won't run. Pressing the trigger on the lance lets the tap water flow through so hose is not blocked. It is a hot day, but I purged sun heated water out of the hose first. Tap water pressure is rather high where I am too in case its relevant. Took a multimeter to the to contacts inside (with power disconnected of course) - on the input side of the switch there is continuity on each wire from the plug end to the input contacts. On the output side of switch there is no continuity on either contact relative to input contacts no matter which way the switch is turned. Is it possible the pressure part of the switch is not operating (unloader stuck?) or is the electrical contact of the switch stuffed? Is there some easy way I can test for either condition without pulling it further apart? Is there some simple way to unstick the unloader so I can check that first?
4 Suggested Answers
  • 56 Answers
SOURCE: Karcher K4.97M electric waterblaster cycling
It sounds to me like the unloader valve is bypassing internally.
Posted on Nov 18, 2009
  • 10865 Answers
SOURCE: does not give a continous high pressure flow cuts in and out
Hi. Water flow may be restricted to the pressure washer.
Check that all hoses are free of kinks, leaks, or blockage. Make certain all hoses and fittings are connected properly. Make sure to open the faucet/spigot to full force. Set the spray wand to high pressure.
Clear any debris from the nozzle. If the nozzle has even a little bit of dirt in the tip, it may cause enough obstruction for the pressure washer to pulsate. If your pressure washer came with a nozzle cleaner, use it to clean the tip. If not, you can use a pin or paper clip to clear the nozzle tip of debris that may have become lodged in it.
If these have been checked and the washer is still fluctuating from high to low pressure there may be air trapped in the pump. To bleed the pump of any air, turn the machine off and disconnect the high pressure hose and trigger gun from your power washer. With only the garden hose connected to the machine, turn on your water source and allow water to run through the pump of the machine for 20 or 30 seconds. Turn off the water and connect the high pressure hose and trigger gun and try using the machine again.
Posted on Jul 31, 2010
  • 16621 Answers
SOURCE: Have a Karcher kb4040 that continues to run
This is two things. One is the back flow check valve to the soap line is leaking. The other is the pressure switch on the output side of the pump.
Posted on Oct 14, 2012
Won't start after running fine
You tested it on other outlets? Check the motor for reset button?
May 02, 2013 | Karcher Garden
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
How do you unlock a sony ericsson f305?
Can't find how to send you a message so thought I would post on your question sorry about this I have gained a karcher hd6/13c Resealed cylinder head only the 3 plungers And the 3 seals on thrust guidance Runs ok when reassembled but when you stop and try to restart washing motor won't turn pump. If you turn motor fan on top it's eay to turn then it will work again until you stop again Had motor running fine without pump attached Got a drawing of pump assy 01060320 Can't remove No 24 over flow valve 45910380 No 11 drain plug. 41320070 Thanks for any help John
Feb 28, 2012 | Cell Phones
Motor running, water supply adequate but when
clean whole water supply and outlet from all debris, clean inlet filter as well. connect water and pressurise washer, pull trigger and wait about 3sec for pump to activate, if pump do not activate adn you have pressure from nozzle as it will be from main, this determines pressure sensor (it is extremelly rare for pump itself) is damaged.
check if you have still warranty,this will qualify as warranty repair, if warranty is expired, pressure sensor need to be replaced.
if you find my advice useful, please do not hesitate to leave your remarks and vote for me, thanx!
Jul 31, 2010 | Karcher 1750 Psi Elec Pressure Washer
Karcher pressure washer hunts ~ off/on ~ when running. How do I fix?
HI Your machine wil start and stop if you have any external leaks when the machine is running at not pressing the trigger. Please start the machine and not pull the trigger and look form leaks. A common one is around the high pressure hose outlet and also the trigger.
Jun 11, 2010 | Karcher 1750 psi Electric Pressure Washer
Karcher K2.36 motor cut out and won't restart
Yes, the water should be turned on first but if it only ran for a minute or two it should be OK. Most late model pressure washers have an automatic shutoff when the trigger on the wand is released. Turn on the water and then the machine and then squeeze the trigger on the handle of the wand and the motor should start as soon as the air is cleared from the line by the flowing water (about 10 seconds). If the unit was put away wet last season you may need to clean the nozzle with a piece of wire too.
Apr 16, 2010 | Karcher Garden
Karcher K 3.68 M operation
These units have pressure valves that automatically turn off the pump once the pressure is high enough. The pressure switches do fail and sometimes stick and act as you've described.
May 07, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
