Question about Kenmore 58522 Side by Side Refrigerator
Freezer not freezing
I have made sure nothing is blocking air flow, tried turning to the highest setting and still the freezer compartemnt is freezing. Bought this unit in Aug. 08
  • Ron Coons
    Ron Coons May 11, 2010
    So you have no refrigeraiton? freezer freezes but fresh food no good?? you can get air to flow to the refig compartment, if you open the freezer can oyu hear the freezer fan turning???
  1. check to defrost timer is opperating , located under the unit behind lower grell.
Posted on Aug 21, 2009
I have a fagor refrigerator that freezes everything. any advice
Make sure your filters are clean also nothing blocking air flow check and clean front vent
Sep 21, 2017 | Fagor Refrigerators
Whirlpool S20b American style f/f. The fridge is very cold and some foods are freezing.
Suggest lowering the refrigerator set point to a lower number such as 3. There is usually an indication of normal setting on the adjustments. Wait 24 hours and check the refrigerator compartment again. Use a thermometer to record the temperatures. The meat compartment will be normal just below freezing. If no success then read the following.
One reason that this occurs is that the unit is working near continuously to reach the freezer temperature. Another words the unit is not capable or cooling the freezer to the prescribed temperature. The result is the excess cooling eventually reaches the refrigerator section causing the refrigerator to freeze. The unit will if this is the case run nearly continuously. This situation is counter intuitive. Freezer not reaching set point, excessive cooling over cools refrigerator therefore refrigerator freezes.
The cause is either the freezer door/seal is not closing or sealing the freezer compartment or the compressor or defrost cycle is not functioning properly.
Check the freezer door seal using a strip of paper. Check to see if air is flowing from the vents in the freezer. Using a thermometer check the temperature of the freezer. Listen for and record if the compressor is running or not.
The normal freezer temperature is around '0' Fahrenheit. If no or little air is flowing from freezer air vents look for ice on the back wall. If ice is present it is likely the auto defrost cycle is not working. Attempt to defrost by hand which requires several hours with everything removed.
Check that lint and dust has not blocked the coils under the unit and that the lower fan is running. Usually warm air exits from the machine grill in the front. Remove the grill and check for air flow and debris buildup. Vacuum if necessary.
And unfortunately if the compressor runs continuously and no air blockage underneath would indicate that the cooling capacity is reduced requiring a major service or replacement.
Hope this helps?
Oct 17, 2016 | Whirlpool Refrigerators
Freezer won't freeze. Temp control? Or is it the black thing on the in line for the freezer heat puller/radiator lookin thing? The fridge stays cold fine.
Set the temp control lower and yes, check the coil. Make sure they are free from dust and you have plenty of air flow around the fridge. Also make sure you do not block the air vents inside the freezer.
Mar 05, 2016 | Refrigerators
Not cold enough
You have to balance the freezer and the refrigerator. The freezer runs both and if you have one set too low then the other suffers or if you have one set to high the other suffers. Make sure that nothing is blocking the air flow from the freezer to the refrigerator and make sure the coils in the freezer are not frozen with ice.
Aug 10, 2012 | Kenmore Side by Side Refrigerator
Motor not runing properly
You need to make sure nothing is blocking the vent located in the back of your freezer, by removing all items you will have a better flow..
Aug 03, 2012 | Smeg FAB30 Top Freezer Refrigerator
The fridge doesnt seem to be cold enough not sure which way to turn the dial no indication as to which way to turn. No instruction manual to refer to.
Make sure the freezer dial is in the middle (12 O'clock) position if it has one
If it is turned too far towards the right it will cut off all air flow to the refrigerator
compartment, the air flow from the freezer cools the lower compartment. Also make sure
the fan is running, if it has failed then the freezer will freeze up and block all air flow.
The refrigerator compartment has a cold control as well, it is normally turned toward
the right to make it colder or if it has numbers, set to 5 or above.
I recommend setting the refrigerator to 36 to 39 degrees (just above freezing). using a
thermometer (stick type set in a cup of water overnight to get an accurate reading).
It is the preferred method, and will help in this instance since the numbers aren't legible.
Hope this helps.
Mar 12, 2011 | Hotpoint Refrigerators
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fan is a big issue. New problem though.
good day!first and foremost, in most freezers, the highest freezing point is 7.in regards with the water dripping from the air vent hole, you have to minimize your your freezing setting to the middle.turn it to 3 or 4 freezing point.
Aug 22, 2008 | Haier HTE21WAAWW Top Freezer Refrigerator
Kg34na90gb fridge freezer - fridge temperature cold, no matter what the setting on door control. Fresh food suffers as a result of almost freezing conditions.
turn the freezer up to highest setting and set the refrigerator control to about half way. this will block some of the airflow into the refrigerator.
Jul 06, 2008 | Siemens Refrigerators
Have side by side refrigerator (approx. 10 yrs old). Fridge no longer keeps food cold enough even at highest setting and freezer isn't as cold either.
Your refrigerator needs to be turned off and aompletely defrosted. Overnight if possible. You have a large amount of ice built up on the freezer coil that is blocking air flow.
Most refrigerator sections are only cooled by air flow from the fan in the freezer section.
Thaw it and clean it out real good and you should be back in business.
Jun 10, 2008 | GE Refrigerators
Kenmore 58522 Side by Side Refrigerator Logo
78 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
