Question about Samsung Home Security
Genie pro 98 light stays on
Lights won't turn off when door closes. Stays on indefinitely.
mjrock
  • 8 Answers
SOURCE: garage light turns on without disturbance.
Most likely the unit has a sensor that activates the light when you walk around or open the door.
if no one is in the room it should go off in 5 minutes, but if someone goes back in there to check it goes back on again.
Under the light cover there should be a switch where you can disable it or make it less sensitive.
Posted on Sep 23, 2008
SOURCE: 2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Posted on Feb 18, 2009
warlock61
  • 659 Answers
SOURCE: Door Ajar light stays on on the dashboard which
try spraying WD40 into the latches and open and close the doors a bunch of times
Posted on Jun 16, 2009
SOURCE: where is the door switch? mine acts like the door isnt closeing and the interior light wont go off
I could not find this switch either, It is actually located in the door latch on the door jam. Switch is somewhere inside. Took my truck to mazda dealer and had it replaced. Anoying problem.
Posted on Sep 17, 2009
  • 108 Answers
SOURCE: door ajar light stays on
just spray the door latches with lubricant be sure the oil penetrates the internal machanism.
Posted on Jan 24, 2010
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
Gene garage door openers
are you sure that it doesn't just stay on for 30 seconds to one minute and then shut off? if it stays on all the time, the light switch has been manually turned on and you need to turn it onto 'automatic'
Mar 18, 2013 | Genie 1/2 HP DC CHAIN MOTOR
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
2003 Ford Explorer.....door adjar light won't go off, dome lights stays on unless manually turned off, key in ignation creates a dinging noise.
try spraying the latch mechanism with a spray lubricant and open/close the door many times-the sensor is on the door latch (not the 'button") and it is a common problem on fords as the get older. do both doors, spray heavily, and open/close at least a dozen times or more.
Jul 24, 2011 | 2003 Ford Explorer
Xterra will not turn on. windows won't roll down, doors stays locked. won't roll over at all. odometer won't come up
Do you get any dash lights when you turn the key on? If not, you could just have a dead battery.
May 27, 2011 | 2000 Nissan Xterra
Home Security Logo
171 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Jim Goldsmith
Jim Goldsmith
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
