Question about Dell Wireless Keyboard Optical Mouse w0147
My dell keyboard has stopped working, i have changed the batteries but its still not working, will not connect to wireless hub, any suggestions please?
  • Dell Master
  • 829 Answers
Uninstall then reinstall I found that worked alot better
Posted on Jan 11, 2009
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
Friggin thing just stopped working no warning what now
try change the batterys conect first the mouse and then put batterys in the keyboard and all shoud work fine again if not working then contact your seller or manufacture company
good luck i just done my one today after 8 month and now all work just fine
Jun 09, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I changed the batteries in my Dell cordless mouse and it still doesn't work. Do I need to change the batteries in my cordless keyboard also?
I checked with someone from the Tech Support Department in my company and suggested I press the connect buttons. I also changed the batteries in my wireless keyboard. I pressed the connect buttons on the receiver, mouse and keyboard. After all this the mouse started working again.
Feb 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard stopped working. Changed batteries and
Does ther del have an external remote module that is connecter to the computer where a standard mouse and b connects. see if the connection is there anything here is possible
Jul 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Keyboard stopped responding, please help.
The keyboard should have a button underneath it. Press the button on the usb controller first and then the button on the keyboard. Repeat a few times to see if it connects. If you are still having trouble try another set of batteries as some batteries are not designed for wireless products.
Aug 15, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard is blinking a blue light but nothing else is working
Normally Dell keyboard require a wireless uSB plug in that connects to your computer and there is usually a small button on both the keyboard and the end of the connector. Press them both. Normally preplacing batteries causes the connection to be disrupted.
Mar 14, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell wireless mouse is blinking red, but functions. Problem?
try to rest the connection by pressing the connect button on the reciever and under the mouse together and relaesing them. it should work
Jan 04, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Keyboard Optical Mouse w0147 Logo
87 people viewed this question
Alun Cox
