Question about Panasonic Home Theater System System
Instalation I woud like to know how can install the home theater to hear the tv progran on home theater system.
  • 336 Answers
You need to check the back of your home theater for an input jack (it could be labeled tv in or aux in). Then check your tv for audio out jacks. Use a quality rca patch cable from the tv to the home theater. The tv may need to be switched from variable to fixed audio out on the audio menu of the tv. If it is an older or inexpensive tv in may not have the output capabilities.
Posted on Jan 11, 2009
How are the cables supposed to go when installing satellite tv, dsl, and home phone?
without knowing the brand of satellite TV and the brand of DSL it is impossible to answer this question and even with all the brand and model information, every home install is different and custom to that home. I would contact my satellite TV provider
May 27, 2015 | home Audio Players & Recorders
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
Why doesn't the ARC TV sound work through the HDMI cable? Is it because the KDL-52XBR7 only has the Bravia Sync and no ARC support?
Not all Hdmi cables have same capabilities. Check out:
http://www.hdmi.org/consumer/finding_right_cable.aspx
Mar 27, 2015 | home Audio Players & Recorders
Compatibility fo TV and Sound system
TV has audio outputs, the RCA cable type. If you connect the audio output (red,white) from the TV(look on the back), and connect the RCA cable to Input of home theater system,you should get TV sound from home theater system. You may have to set the audio on the TV for external source. Go to menu, to audio setup, to options. On the Home Theater system, you may have to select the audio source, i.e. audio input 1, etc.
Aug 09, 2009 | Samsung Theater System
I can't get my philips 47pfl3603d/f7 to work with a coby dvd968 home theater system the tv has one spdif coaxial out and coby also has one i pluged the cable, still can't get to hear my tv channels thru...
You need to select the source of your home theater system. Press <SOURCE> on the home theater remote to switch between DVD, TUNER, and LINE modes. Select LINE, then you should now hear audio from your TV, Please make sure that your TV is not muted, just increase the volume until you hear audio on home theater. Also increase the volume of your home theater.
Regards,
Jeep Brainy
Jul 26, 2009 | Philips 47PFL3603D LCD TV
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Lost installation guide for Magnavox MRD 510 Home Theater System
Download MRD-210 User Manual as it might help you to hook up video cables properly. Connections between Tv and Homer theater is not proper in your case.
Sep 11, 2008 | Philips Magnavox MRD510/17 Theater System
Panasonic Home Theater System System Logo
274 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
