Question about Acer AX3950U3022 Desktop (AX3950U3022PTSE602039)
What is the motherboard for the Acer AX3950U3022
I need to replace the mother board and the hard drive for this computer.
  • 414 Answers
SOURCE: acer veriton 5800
Follow the link for driver downloads
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Mark
ps. thanks for the rating
Posted on Apr 10, 2009
VargheseAcer
  • 142 Answers
SOURCE: We need Acer toll free number
How to reach a live person: Speak "Customer Support"
Speak "Agent"
When asked for the SNID (serial number) look on the botom of your product or near a bar-code. It is eleven digits long. If you don't have it just mumble around and you will eventually be transfered to a rep. Phone: 866-621-2237 How to reach a live person: dial # when recording begins
Posted on Nov 19, 2009
  • 3940 Answers
SOURCE: I have an ACER Aspire AST 180-UD360A. Was working
From what you describe, you issue could well be the hard drive. Turn the system on, then press f12 to enter the setup, see if the system stays running. While there, if it stays on, see if the hard drive is detected.
If the HDD is detected, see if you can run diags on the drive.
Other options, boot to the Windows Media and see if the system stays running there. (you may have to remove the hard drive to do this)
If the system runs in any of these and will not boot to the hard drive at all, then there is a good possibility that the drive is bad, and you may well have lost your data.
If the system continues to power off, even with the HDD removed, then the motherboard is likely the failure.
I
Posted on Jan 13, 2010
ashokpandey
  • 121 Answers
SOURCE: Broken SATA Connector on Motherboard
SATA connector can be replaced if a local technician should have any old damaged mother board with him and if he is ready to fix it on *********** board. you will have to find it by going to the different repair shop if they are available.there is no alternate solution to this problem as there is only one connector on the mother board. if some repair store agrees to do it for you then it could be done or else you will have to get the motherboard replaced.
Posted on May 13, 2010
elshaddai159
  • 1016 Answers
SOURCE: I bought an acer desktop
Im not sure what you wanted here, but from what you have given here it comes under the Aspire and the Vertion family or group.
Hope this helped.
Thanks
Jason
Posted on Oct 19, 2010
Manufacturer of Compaq Evo Motherboard
open it up and the mother board manufacturer will be printed on the board
any mother board can be used as a replacement and if it needs replacing update it so that a later chip can be used
it is cheaper to replace the mother board , power supply , memory, chip than to buy a new computer
and hard drives are now solid state and do not have any spinning bits to fail
talk with a computer repair shop and get ideas as to how to proceed
you will probably find that with a rebuild you will save at least 25% off the price of a new store model pc and get a better unit to boot
Sep 16, 2016 | Compaq evo Computers & Internet
Was workin ok but no signal imput now
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
Mar 29, 2011 | Asrock K7VT2 Motherboard
Display is not coming of my desktop. i have used all possible way expect mother board.
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 22, 2011 | Intel Desktop Board D845EPI Motherboard
Hi Intel mother board D 845EPI After replacing
-make sure that the hard drive cable (IDE cable) is plugged-in correctly. It is possibly inverted.
Dec 18, 2010 | Intel Desktop Board D845EPI Motherboard
May 12, 2010 | Acer Aspire X1200-B1601A PC Desktop
When i login my computer I just get black screen try to reset or confiuate says primary and scondary drive 1 not found
HI Dear,
This is a hardware related issue. This might be due to following problems :
1. The data cable that connects your hard-drive to the mother board might have picked up some fault.
2. The mother board is not working.
3. The Hard-drive might be corrupted.
To see what exactly is causing this. Remove your Hard disk and try to on your friends computer. If its working fine then its the other two issues.
To check for the mother board and the data cable. remove the hard drive aand try t with another one. If the motherboard reads this hard drive then it is sure there is no issue with the motherboard and the data cable.
Now if trying above you see that HD is not detected. then replace the data cable and then try the HD on your computer. If it reads then there is no fault in *********** board. So replace the data cable and get a new one.
And if it does not reads then the motherboard have some issue. In that case i would suggest you to take your comp to nearest service station.
hope this works out. If it does not and if you have more queries that need to answered then please do write to us once again.
Have a nice day.
Nov 11, 2009 | Dell Dimension 2400 PC Desktop
Mothe4r board problem
Nothing you can do except replace the motherboard or buy a new computer.
It might be cheaper to get a new computer, especially if your computer is more than a few years old.
You can transfer the hard drive, video card, the monitor etc. to the new computer if those components are OK.
May 27, 2009 | Acer Aspire 3680 Laptop
Hit by Lightning
No Mother board is compatable.
The Motherboard and hard drive are paired and cannothe be replaced.
The best thing to do is to buy a new computer and use the Harddrive as a slave on the new one.
Jul 10, 2008 | Acer Aspire T135 PC Desktop
ASUS P5VD1-X
When the computer boots you should be able to se if the mother board detects the hard drive.
if thats not so. go into the mother boards bios and have it set so that it auto see the hard drive,
Dec 14, 2007 | ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard
Acer hard drive
Hi, the problem is one hard drive ie the 1/3 one is a SATA hard drive, the other is IDE.
to set them both up you need to do this,
Connect the IDE Hard Drive using the IDE cable like before.
With the Acer Hard Drive you need a Sata cable cost about a £1 from any shop.
You connect the sata cable from the hard drive to the motherboard, but on the motherboard you are looking for a small red connection same size as the cable, SATA is on most motherboards for machines that are just over a year old.
Hope it helps.
Have a nice christmas
John
Dec 10, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Acer AX3950U3022 Desktop (AX3950U3022PTSE602039) Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
