Question about Sony MEX-BT2500 CD Player
BTM - best radio stations for Sony mex bt2500
In the manual it says to hold the BTM and then get automaticaly 18 best radio station set in the area. It does not work. Anybody knows why?
3 Suggested Answers
  • 1126 Answers
SOURCE: How do I install the Sony MEX-BT2500 wires?
http://www.docs.sony.com/release/MEXBT2500_install_EN_ES_FR.pdf
Here is a link to Sony installation wiring for your MEX-BT2500. You didn't say what car that you're installing in.
Posted on Oct 18, 2009
afarri
  • 1386 Answers
SOURCE: My Sony MEX BT2500 won't reset. Want to reset
Hello and welcome to FixYa!
Try this. Remove the positive battery connector of the vehicle and let it sit for atleast10mins. or more before reconnecting it. This will reset the system and can get your radio back to it's default setting.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Aug 07, 2011
Directions on how to set favorite stations on a 2003 pontiac sunfire radio
AM / FM RADIO
Setting Preset Stations
The six numbered pushbuttons let you return to your
favorite stations. You can set up to 18 stations (six AM,
six FMI and six FM2) by performing the following
steps:
1. Turn the radio on.
2. Press AM FM to select AM, FMI or FM2.
3. Tune in the desired station.
4. Press and hold one of the six numbered pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return.
5. Repeat the steps for each pushbutton.
RADIO WITH CD ( BASE LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 18 stations (six AM, six FMI and six FM2) by performing the following steps:
2. Press AM FM to select AM, FM1 or FM2
RADIO WITH CD (UP LEVEL)
The six numbered pushbuttons let you return to your favorite stations. You can set up to 30 stations (six AM, six FMI and six FM2, six XM1 and six XM2 (USA only, if equipped), by performing the following steps:
2. Press BAND to select AM, FMl, FM2, or XMI, or
4. Press EQ to select the equalization.
5. Press and hold one of the six numbered XM2. pushbuttons until you hear a beep. Whenever you press that numbered pushbutton, the station you set will return and the equalization that you selected will also be automatically selected for that pushbutton.
6. Repeat the steps for each pushbutton.
Additional details could find in your Owners Manual; hope this helps (remember to rate this answer)
Jul 02, 2011 | 2003 Pontiac Sunfire
How do I reset the radio stations to be programmed into the radio? I did not receive an owners manual when I purchased my 2000 Mazda MPV Minivan
TRY THIS. GO TO THE STATION YOU WANT. PUSH AND HOLD THE SELECTED PRE-SET BUTTON YOU WOULD LIKE TO PROGRAM. PUSH AND HOLD TILL THE DISPLAY OF THE STATION BLINKS OR THE RADIO BEEPS. IT WILL BE FOR A FEW SECONDS. TO CHECK, TO THE STATION THEN PRESS THE PRE-SET BUTTON TO SEE IF IT STORED YOUR STATION. LET ME KNOW.
Feb 17, 2010 | 2000 Mazda MPV
I can t figure out how to connect my radio up like i got the cd player to work just fine but the radio doesn t work
Press the source button to select fm, press and hold BTM button until Btm flashes. This will automatically store stations for you. Page 8 in this users guide covers same as well as manually setting stations. You do have the antena connected?
http://www.docs.sony.com/release/CDXGT20W_200.pdf
Oct 23, 2009 | Sony XPLOD CDX-GT200 CD Player
Radio manual terracan
Thank you for your quick response to my email but in the meantime a friend who has the same audio system in his car solve the problem for us.
Oct 18, 2009 | Car Audio & Video
How do I change the radio station on the radio alarm
Here is the full manual
http://www.timexaudio.com/pdf/T311IB57574_35.pdf
Here are the instructions from the manual.
Setting the Radio Alarm
1. Press and hold the
Radio Alarm Button. The display will flash and the Radio Alarm Indicator will
appear. If you do not begin setting the time within ten seconds of pressing the button, the display will stop
flashing and you will need to press the
Radio Alarm Button again.
2. While the display flashes, press the Reverse and  Forward Buttons to set the wake time. Hold a button
for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, you will need to select the station. First, press the  Radio Band Button
to select a radio frequency. Next, select a station using the Memory Set 1-6 Buttons. For more
information on programming radio stations into memory, see the Programming Radio Station Settings section
of this manual. Rotate the  Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting
lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that
the correct date is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual.
While the display is still flashing, press the  Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the  Enter Button. The
Radio Alarm Indicator will appear on the display, showing that the radio alarm has been set.
Aug 08, 2009 | Timex T311T Clock Radio
Radio for Sandisk model SDMX1
Press the AB button to toggle between Audio Play, Radio, and Voice Record. Use the left/right scroll to highlight Radio. Then press the center button or play/pause button once to select radio.
You will see FM Radio in the upper left corner of the display. Under that you will see either Preset followed by a number OR Channel. If it is on Preset, you can use the left/right scroll to switch between preset stations. If you press and hold the AB button, the player will scan through all frequencies to find the strongest stations in your area and set those as the default preset stations. When on a particular station, press and hold the record button to delete that station from your presets.
Press the center button once to switch to Channel (or back to Preset). Under Channel, you can manually scroll through the frequencies yourself. Push left or right and hold for about a second to find the next available station.
Press the play/pause button once to toggle between Mono and Stereo.
Those are all the functions I've found so far. Hope it helps.
Good luck,
vw
May 26, 2009 | SanDisk SDMX1-1024-E18 MP3 Player
Pioneer DEH P4100
  1. well to set the clock you need to first hold the source button to turn it off to where the clock is just on. then press and hold the clock button until it beeps then use the arrows to set the clock..........
  2. and to set the stations you need to tune in your fav station and then press and hold the number you want to place that station. you can also do best station memory if you are in an unfamiliar area or if you just want to fast tune all the local stations that come in the best it will randomly preset the stations by pressing and holding till it beeps on the program bottom. then the screen will run BSM until it finds and places the stations. hope this helps!
Feb 16, 2009 | Pioneer DEH-P4100
How to program 1995 900se saab radio
Tune to the first and lowest station on the band that you want and push and hold button number one (in the row of buttons immediately below the station display) until the number shows on the display and flashes. Pre-set one is now that station. Repeat, using button two for the next, and so on, until you have all the stations you want programmed.
Dec 30, 2008 | 1995 Saab 900
Losing station on cd radio
THAT TYPE OF CONFIGURATION MUST BE OBTAINED FROM THE USER MANUALS
Aug 06, 2008 | Clarion DB245 CD Player
Programming the radio stations
Go to the station you desite press and hold the number until you hear a beep, about 5seconds
May 17, 2008 | 1991 Acura Legend
Sony MEX-BT2500 CD Player Logo
283 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
