Question about Garden
Do I have to split the case to replace the auger drive belt on an Ariens ST724 snowblower?
    Scholar:
  • 76 Answers
No. If you have someone squeeze the auger handle, that will allow you to remove the belt. You'll need to do the same to put it back on. Make sure to put the belt on the bottom pulley and not over one of the belt guides otherwise you will end up replacing the new belt also.
Posted on Jan 12, 2009
  • Mark Tripp
    Mark Tripp Jan 12, 2009
    Sorry I forgot one other thing, also squeeze the drive handle that will allow you to get the belt between the 2 pulleys
Start my new snowblower auger keeps turning
Belt is a bit too tight. If it's NEW it will probably stretch a bit and be OK
Dec 23, 2014 | Ariens 72023 Snowblower Drive Belt 1/4 X...
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
How to change drive belt-Ariens 522 snowblower-model # 938017
Which belt? You are referring to the auger drive right? The self propell uses a friction disc drive.
The auger drive has two belts, and in order to replace them you need to seperate the auger from the engine (split) the blower.
Happy days.
Matt
Dec 13, 2010 | Garden
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Ariens ST 724 impeller does not move under stress?
i have a old ariens ST724 snowblower engine will only run with full choke.
Jan 29, 2009 | Farmall Cub Tractor Radiator
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Garden Logo
286 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
