BEOMASTER 4000 No sound from one speaker. Tried swaping cables etc.- problem lies in the output from amplifi
  • foxpsp Mar 21, 2009
    I have the same problem. Headphones work, however. If I put it in mono rather than stereo, both speakers have output. I have changed speaker outputs and that just changes the no sound problem from one side to the other. When in stereo mode, if I move the volume control back and forth I will eventually get both channels, but not at lower volume settings and that may eventually fade out.
    Genius:
  • 1,175 Answers
Hi...
Try one other thing..headphones. If there's only 1 channel in the headphones then you'll need to take it to a tech.
Depends on where in the country you are as to a good tech.
I know some...even me in the Northeast
Posted on Jan 11, 2009
    Problem Solver:
  • 10 Answers
No volume on all left side speakers
Determining the Cause of the Problem Let's assume our system has a head unit, a crossover, a two channel amplifier and two door speakers with only the right speaker working (the left speaker is not working). If the door speakers are behind the door panels then we want to make sure the speaker is the problem before removing the panel. We'll work backwards starting with the amplifier and ending at the head unit. Testing for a Speaker Problem With the vehicle and the stereo turned off disconnect the speaker wires for both the left and right speakers at the amplifier. Now connect the left speaker to the right amplifier output (which we know works). Turn on the stereo system and make sure the balance is set to the middle position.If the speaker still doesn't work then the problem is somewhere between the amplifier and the speaker Testing for an Amplifier Problem Now we'll need to see if the amplifier channel is bad. Put the left speaker back on the left amplifier channel and the right speaker on the right amplifier channel. This returns the speaker wiring to its original configuration. Again, with the vehicle and stereo off unplug the RCA cables from the amplifier's input and switch them so the left cable is in the right input and vice versa. Turn on the stereo system. Testing for an RCA Cable Problem For any intermediate components between the amplifier and the head unit follow these steps for each one. We only have a crossover so we'll just do this once. Begin by testing the RCA cables between the intermediate component and the amplifier. Unplug both RCA cables from the intermediate component's output. Now plug the working channel's RCA cable into the non-working side of the crossover. In our case the working channel is the right so plug the right RCA cable from the amplifier into the left side of the crossover. Turn on the stereo system.
If the right channel continues to work then you know the problem is in the RCA cables between the amp and the crossover. esting for a Crossover or Equalizer Problem At the input of the intermediate component (in our case the crossover) flip the RCA cables around (left to right input and vice versa). Turn on the stereo system.
If the right channel continues to work and the left channel continues to not work then you know the problem is in the intermediate component. Replace or repair this component.
If the problem is now in the right speaker and the left speaker works then the problem lies before the crossover. Turn off the stereo system and return the RCA cables to their normal places.
Testing for a Head Unit or RCA Cable Problem Pull out the head unit from the dash so you can access the RCA cables. Unplug both RCA cables from the head unit. Do not disconnect any other wiring. Plug the right RCA cable into the left channel of the head unit. Turn on the stereo system.
Sep 29, 2016 | Cars & Trucks
Have a xga 4000 amp only channel 2 works fine . Channel 1 very very low
Switch input connection pairs and if the 'fault' doesn't changes from one channel to the other it is almost certainly an amplifier or output fault.
Likewise switching the speakers. If after swapping the speaker connections the fault changes to the other speaker it is an amplifier fault. If not a speaker fault.
Aug 16, 2014 | Gemini Sound Products GEMINI XGA 4000 4000...
Main Speakers Loose Contact
pls. take out your speaker wires and cover the leads with soldering lead and connect it back.
Mar 16, 2013 | Audio Players & Recorders
Connect with componet cables.
The only digital audio input for this TV will be via the HDMI input. Of course, even with HDMI in, you're only going to get a simple stereo output from the TV. You can use the analog L & R audio inputs for a very similar sound from the TV speakers.
The digital multi-channel audio (Dolby Digital, THX, 5.1, 7.1, etc) encoded in the program should be connected to a suitable multi-channel amplifier with either a TOSLINK (optical), RF (coaxial) or HDMI cable for theatre-like sound. This can be done by (a) cabling from the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) directly to a multi-channel amp and speakers, or (b) from the HDMI output of these devices (DVD, BluRay Disk, Set Top TV Tuner, etc.) into one or both of the TV's HDMI inputs. This will provide only stereo sound output from the TV speakers. You should connect the TV's TOSLINK optical "Digital Output" jack with an optical cable to the amplifier's TOSLINK optical input jack to obtain theatre sound.
To listen to the program shown, you would select the amplifier input assciated with the optical, RF or HDMI input that is connected to the source (DVD, BluRay Disk, Set Top TV Tuner, etc.) if connected directly. If the TV HDMI input(s) are used, they are output to the TV optical output and should be connected to the amplifier optical input. The amp input associated with the optical input should be selected to hear the program with theatre-like sound.
Dec 13, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
B & O BeoMaster 4000 Tuner/Amplifier Operating Manual
Good morning, afternoon, evening or night; whatever time you are viewing this. Thank you for choosing FixYa to assist you with your problem. You want an owners manual for Bang & Olufsen's BeoMaster 4000 Tuner/Amplifer? Here ar some links that can help you obtain this.
http://beophile.com/?page_id=8253
http://www.beoworld.org/prod_details.asp?pid=346 (You have to sign up to become a member. Depends on how bad you need this manual.)
http://www.manuals-online.net/manuals?page=1&q=%22Beomaster+4000%22 (More links to websites that may have what you're looking for.
http://www.manualzone.com/ShowProductsForModel.do?model=M17238648 (Be prepared to pay if you decide to purchase one.)
Hope these links help. Thank you again for choosing FixYa as your one-stop solution spot for your problems. Be sure to visit our site again and have a good day, evening or night; whatever time of day you are viewing this.
Apr 27, 2011 | Midland WR-100 Weather/RDS Radio
I have a beomaster 5000 which will cut out at any time sometimes it goes for ages,other times it will go almost immidiately,also i have the beogram 5000 and the cueing function doesn't seem to raise the...
O.k. The Beomaster 5000 needs new Quiescent current presets , you can temporarily solve the problem by turning the two presets (in the main amplifiers) fully anti - clockwise .
Your beocord needs new belts for sure .. availiable from CPC of Preston .. Hope this helps ..
Oct 29, 2010 | Bang and Olufsen Beosound 2000 Shelf...
My amp powers on but i get no sound and i have everything hooked up properly, what is wrong with it?
Have you tried your subs on another amp???? Or hook up a small speaker at low volume to the amp and see if it plays....If it doesnt, then the problem lies within your speaker output on your amp or your line out (rcas) on your stereo
Oct 24, 2010 | Jl Audio 500/1 Car Audio Amplifier
What type of speakers and turntable work best or will work with a Bang & olufsen 2400 reciever and 6000 reciever. thanks
I believe this Beomaster series needs amplified speakers that goes with it. You might use the RCA out and make it amplified with another receiver or amplifier and use ''usual'' passive speaker.
Oct 08, 2009 | Audio Players & Recorders
My beomaster 3300 will not get full volume.
fix your cables...check then at the speakers...and the at the amplifier, if the cables are to close it causes a short circuit...this was happening to me once...
Aug 08, 2009 | Audio Players & Recorders
760 people viewed this question
 Grubhead
Grubhead
