TV Menu is in wrong language
It looks like the screen displays on all menu selections is now in Swedish or a similar language. I want English.
The 'Install' option on the main menu is greyed out so the language cannot be changed.
Is there a 'Universal Reset' - I would prefer to do this as I want to start again with setting the TV channels?
  • 1 more comment
  • steve_gledhi Jan 12, 2009
    I was asked "Can you get to Languages through the main menu without going to install?"
    There is no Languages option on the main menu.The main menu reads
    Bild (colour?)
    Ljud (sound?)
    Egeenskaper - can't be selected
    Installera - greyed out
    Hope that helps to pinpoint the response.
    But surely there must be a universal reset such as poking a paper clip in a hole, or holding down buttons during start-up or one of the other many reset options found on virtually every piece of equipment.
  • steve_gledhi Jan 13, 2009
    I have a Philips model 20PF5320 /01. I have not yet received any suggestions yet.
    TV Menu is in wrong language, looks like Swedish. I want English.
    Someone must know of a 'Universal Reset'? Please...
    I was asked for the model., it's in the original question - Philips model 20PF5320 /01
    Genius:
  • 1,239 Answers
Hi
did you  Check the menu, in the yellow section, there's a "language" setting.
Posted on Jan 13, 2009
  • ABHISHEK.C
    ABHISHEK.C Jan 13, 2009
    Select INSTALLATION and press the right cursor button. Select TEST RECEPTION and press the right cursor button.
    Select your language with the cursor left/right buttons. The menus wil appear in the chosen language).
    Check that the preselected LANGUAGE, COUNTRY and TIME ZONE are set according to your preferences.
    Press the cursor up/down to select MANUAL STORE and press cursor right. Press the cursor up/down to select SYSTEM and press cursor right to select the correct system.
    ress the cursor down to select INFORMATION and press cursor right. Press the cursor down to ALWAYS ACCEPT NEW SOFTWARE and press the cursor right to select YES.
  • ABHISHEK.C
    It seems the main cpu controller is defective.
    It could be a soft code problem or a hardware problem.
    ONE: Do a hard reset.  Merely unplug the power cord for 4 hours or more.  When you power it back up the internal codes will all be automatically restored to the factory default settings.
    TWO:  If the hard reset does not help it means there is a hardware problem. Either the controller IC or some other components must be replaced.
    Is the set worth the repair?  Only the shadow knows.  It is marginal in age; usually one this old I would not recommend it be repaired.  Why? Because once a set begins to have serious problems it is statistically very likely another failure will follow soon after.  Then, with a couple of repair bills you will be wishing you had just bought a new set. On the ohther hand, if it is a good set and you like it it may be worth it and you may get lucky and find it will go reliably for another 10 years; a pure guess into the future.
    I would guess the repair, assuming an IC had to be replaced, to run around $150. But you may have to leave it in the shop for a few days while they order out the part - unless you can get it into a factory authorized facility that is well equipped.
    Do you have any further questions?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Determine if the TV would allow you to go to PC Mode:
  • press AV on remote to display "Source List";
  • use cursor up/down and select "PC", press cursor > to engaged the Philips to PC mode (DVI-I In);
  • if TV is set to PC Mode, press MENU;
  • use the cursor and select "Reset to Factory Settings".
Pls post back result(s). Good luck and Thank you for using FixYa.
    Sniper:
  • 59 Answers
Hi what i can recommend is to go back to the store that you bought it and have them show you where the setting for it is
  • 565 Answers
Contact your local phiips resseler or guaranty appartment they hcan help u to do it. or tell how u can do it because most models have diffrent ways to do it.
Posted on Jan 12, 2009
  • 19,396 Answers
The only universal reset is by unplugging the power cable.
If you tell me the model number you can try entering in service mode, but I don't think it can help.
The Fault need a reinstall of the internal firmware.
The firmware for Philips TVsis not distributed, you need to have repair done at an authorized service centre if unplugging does not reset.
Call philips at the phone number listed on the ownler manual.
The fault may be a factory defect, in that case will be repaired for free, regardless of warranty and age of the set.
If you need Philips support number let me know your location and the TV model.
I answer within 24 hours .
Thanks
  • 51 Answers
Change phone language to english
Look it up on the Mfg. website. They usually have manuals posted.
May 28, 2014 | Vtech Cordless 6041 Phone
How to get subtitles in english .they are coming in another language
Hello
To select the language, do the following.
[1] Press Menu and the press Left or Right arrow on the remote to select language option.
Choice of language selection [3] will appear on the screen.
English, Espanol and Francias
[2] Press Up or Down arrow to select the desired lannguage you want to be displayed on the screen. Then press ENTER.
[3] Press Menu repeatedly to exit the Menu screen to be cleared.
OK.
Jan 11, 2011 | Toshiba MD20F51 20 in. TV/DVD Combo
I am trying to set my Sanyo picture right side up. what setting do I go to?
Check Ceiling feature.
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT button(s) to move a red-frame pointer to
SETTING icon.
Language used in ON-SCREEN MENU is selectable from among
English, German, French, Italian, Spanish, Portuguese, Dutch,
Swedish, Russian, Chinese, Korean and Japanese.
Display
This function decides whether to display On-Screen Displays.
On ··· shows all On-Screen Displays.
Off ···· sets On-Screen Displays disappeared except;
? ON-SCREEN MENU
? "Power off?" message
? "No signal" message
? "Please wait...."
? P-Timer counter
Set a red frame pointer to item and press SELECT button.
Press POINT DOWN button to move a red-frame pointer to item
that you want to set and then press SELECT button. Se ting
dialog box appears.
Dec 11, 2010 | Sanyo PLC-XF46N LCD Projector
How do i get the language back to english?
Hello
Press the Menu Button on the remote to show on-screen menu.
Press Cursor Up or Down button to scroll through the on screen menu until the word Install is hilighted.
Press Cursor Right button to display the Install menu features.
Press Cursor Up Or Down button to scroll the install features until the word Language is hilighted.
Press Cursor Right button repeteadely to select English or Spanish [Espanol]
When finished press the Status/Exit button to remove the menu from the TV screen.
[The language control only makes the TVs on-screen menu items appear in English or Spanish. It does not change the other on-screen text features such as Closed Caption [CC] TV shows.]
Ok.
Nov 11, 2010 | Philips Magnavox 27MS343S 27" TV
How do I reset the printer to the english language panel display
Follow these steps to change language setting on the printer display :
1.On the printer control panel, press the Left arrow twice or the Right arrow seventeen times on the Menu button until SELECT LANGUAGE? appears on the printer display screen.
NOTE: If the language is currently set to a language other than English, the Select Language? menu option will appear in that language.
2.Press the OK button.
3.Press the Left or Right arrows on the Select Photos button until your desired language appears.
NOTE: Even if the printer is currently set to another language, the name English will appear in the English language.
3.Press the OK button to select the language. A message requesting confirmation of the selection will appear appears. If the correct language is displayed, press the OK button. If the incorrect language appears, press the CANCEL button and start the selection process again.
4.When the SELECT COUNTRY/REGION? setting appears on the printer display screen press the OK button to continue.
5.Press the Left or Right arrows on the Menu button until the desired country/region appears on the printer display screen.
6.Press the OK button to select the country/region.
Nov 07, 2010 | HP PSC 1610 All-In-One InkJet Printer
I want to change laguage from Swedish to English.
The customer cannot go to setup menu because he won't be able to read it - it's in Swedish
This is what I need you to do.
Press the menu button (base everything on symbols/icons) - You would see a menu in swedish but on top are tabs. The rightmost tab is a camera with a ranch symbol - so move the joystick to the rightmost tab. Scroll down to the option with a BUBLLE SYMBOL with ABC on it, press in the joystick (toggle switch) to enter or select and scroll down look for ENGLISH.
Aug 22, 2009 | Kodak EasyShare V1003 Digital Camera
Laserjet 3600 HP printer in wrong language in display led screen
When you say writing, I assume you mean the language on the printer's display. Here's a step by step guide (since I assume you can't read the Japanese).
Press the blue Checkmark button to access the menu system. Press the down area twice which will give you access to the configuration menu. Press the Checkmark button to select this menu. Press the down arrow twice to access the system setup menu. Press the Checkmark button to select this menu. Press the down arrow 13 times (you can just keep pressing it until it gets to the bottom. It won't go any farther than the last entry) to get to the very last entry which is language.Press the Checkmark button to select this menu. The languages will be displayed in their native scripts. The first one is English. Press the Checkmark button to select English. And you are done. Press the U shaped arrow to get back to the main menu.
Sep 20, 2008 | HP LaserJet 3600dn Printer
Change Language Setting on W375
Hello there. please do the following. press the menu button>press the screwdriver option>press the wrench with a brown file icon>go down 6 places from the top and select it> you will then see english at the bottom. hope i helped!
Sep 20, 2007 | Motorola Mobility W375 Cellular Phone
I have problem to change language. HYUNDAI HTL-32v2
bang on the tv till the tv changes the language because that usually works but if it does not change the language i would call a professional television fixer person to come an fix your problem and if he cant do it then i dont know what else to say cause your on your own!
May 20, 2007 | Hyundai Q321 32 in. LCD Television
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
