Question about Coleman Heating & Cooling
Coleman gas furnace model number 8665d766 wiring diagram to install terminal block
Wiring diagram to install tgerminal block example togo switch to turn system on where does the blk wire go on terminal block from switch
jcpark50
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
SOURCE: Line voltage Tstat installation Dayton D-F79 elctric shop heater
If I understand your post correctly....You state that you are hooking up a 240v heater and towards the end you speak of removing jumpers...W2 terminals..ect. It sounds to me your trying to us a 24v low voltage thermostat instead of a Line voltage thermostat.That's what I'd take a look at.
Posted on Jan 21, 2009
SOURCE: How to wire a Coleman proprane furnace
do anyone know anything about a coleman furnace modle number 9210
Posted on Jul 20, 2009
billyvangogh
  • 108 Answers
SOURCE: Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Posted on Oct 31, 2009
  • 4 Answers
SOURCE: i need a wiring diagram for a magic chef furnace
There should bee a wiring diagram on the inside door of the unit, it will show fan speed connections
Posted on Nov 01, 2009
My Coleman Evcon furnace blows cold air even when the unit is turned off. How do I stop it from doing that?
Hello Rhonda Killalea,
On MOST furnaces built since 1960. there is provision
for the BLOWER on the old type THERMOSTATS.
BLOWER SWITCH ... has two positions
"ON" and "AUTO"...
(turn blower from on to "OFF" (or correct wiring)).
"AUTO" is the POSITION your thermostat NEEDS
to be on...
Only then will your heater's blower be under
control of those internal temperature controls.
I am including a SAMPLE page from the OWNER's
MANUAL... (a wild guess of which "EVCON" model
you might have)...
Without YOUR MODEL NUMBER... your answers
are going to be completely generic (pretty useless).
You will also need to disclose what model
THERMOSTAT you are using... while you are
LOOKING...
Try to note the FUEL you are using, HEATING
or HEATING-and-COOLING...
ELSE... my only suggestion would be to look
at the WIRES... note their color and CREATE
a TRUTH TABLE between the "typical" R,G,Y,& B
wires ( telephone wires ) and the ACTUAL
SCREW-TERMINAL designations...
Black, Brown, Red, Orange, Yellow, Green, Blue,
Purple, Gray & White... industry colors for
the possible TERMINAL designations... (and more)
THEN...
Go to the HEATER (air-handler or compressor)
terminal block and VERIFY .... The OLD FASHION
Red, White, Black and Green have a TERMINAL
MATCH from the thermostat to the HEATER.
Hope this helps...
Carnac the Magnificent
https://www.manualslib.com/manual/500880/Evcon-Eb-Series.html?page=2#manual
Evcon EB SERIES Owner Manual Page 2
Feb 20, 2018 | Coleman Heating & Cooling
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Wiring diagram for gas furnace COLEMAN
Alvaro, can you give me the model number of the Coleman Furnace you are needing this diagram for?
Dec 20, 2013 | Cars & Trucks
I have a Coleman AGU10016A Gas Furnace which initially runs fine but after a certain time shuts off and cuts gas to burners and pilot what is the problem?
That's a safety to prevent an unsafe condition. It is caused by any number of protective devices such as flame roll out, blocked flue pipe, fan stopped working and causes the heat exchanger to get too hot and trip the limit switch etc. Call a qualified tech to deal with gas appliances. Gas isn't a DIY thing.
Dec 11, 2013 | Heating & Cooling
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
I have a Weil mcLain Gold gas furnace and the Amtrol WH-7L hot water maker. I heat alot with an indoor woodstove and if the furnace is not being used I cannot get any hot water. However, when the furnace...
You should download & review the manual for Amtrol Boilermate products here.
Page 12 of the manual begins examples of wiring between the Boilermate and aquastat (also gas valve and multi-zone relay), that is usually mounted on the boiler. In order to use it correctly, you'll need to determine which aquastat (or other device) your furnace has. You should be able to locate this info on the inside of the aquastat cover. The Honeywell Triple Acting aquastat is very common and looks like this:
The cover is held by a single screw on the top, bottom or front (depending on the model you have). The inside should have wiring information along with the model number. Compare the model number with the wiring diagram for it in the Boilermate manual.
Make sure power is OFF before continuing.
Check that all wires are terminated and undamaged. Make sure terminal screws are not loose. Tighten any found to be loose.
The orange wires are connected to a switch that is normally OPEN but CLOSES to start the boiler when the hot water has cooled. It is also used to operate a "power vent" for a minute or two both before ignition and after flame out for safe pre and post purging of the combustion chamber of furnaces that lack a chimney.
Blue wires are connected to a switch that is also normally OPEN but CLOSES to start the boiler when the hot water has cooled. When the switch connected to these wires is CLOSED, ignition happens instantly. There is no delay for purge so when these wires are used to start a furnace, it should be one with a chimney - not a power vent.
For additional help with your particular installation, you will need to provide information concerning the wiring diagram in the manual that applies. Otherwise, there are simply too many variations to walk through.
I suspect that the switch(es) that are connected to the orange (or blue) wires - or the device (aquastat or multi-zone relay box) is not operating as expected to start the furnace.
The troubleshooting section of the manual that seems to apply best is the section: Boiler will not operate when calling for hot water on page 27 (if you want to try some of their suggestions while waiting for additional replies).
I hope this helps..
Nov 29, 2012 | Heating & Cooling
Coleman gas furnace model #8665d766,..the burner cycles great,...but fan motor will sometimes continue to run,..if you hit it on the front side lightly,..it shuts off...?
Hello, this sounds like it may be a problem with the relay on the integrated control board. it sticks occassionally and therefore the fan will keep running, when you hit the front side it causes the relay to open and thus the motor turns off. only option is to replace the control board as the relay cannot be replaced byitself.
May 15, 2011 | Coleman Heating & Cooling
My coleman gas furnace wont ignite. i replaced the ingintor but i think a wire has crossed and i am not sure which wire. i purchased my furnace and it didnt come with an owners manual
If you have the model number, go to the Coleman Heating and Cooling website and using the model number, you can search for and download the Owners Manual.
Mar 11, 2011 | Coleman Heating & Cooling
Heating & Cooling Logo
103 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
