Question about Zenith Audio Players & Recorders
How to hook up zenith z711b surround
Surround pro logic dolby
3 Suggested Answers
SOURCE: RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Posted on Dec 28, 2008
  • 41 Answers
SOURCE: how to hook up sharp dolby surround pro-logic
The source of your program will determine how you hook things up, and if you want to (if it's possible) route the video through the Sharp as well. Some systems have video switching, so you can run all sources through the system, and have a single video cable running to the TV.
If you are using a DVD player, typical Pro-Logic requires a red/white RCA cable from the DVD player to the amplifier unit. The video cable, either a 4-pin S-Video or a yellow composite cable, will run to the amplifier unit for switching purposes, or ditect to an input on the TV.
You can also run red/white RCAs fron the HDTV to an input on the Sharp. You likely have to set the TVs audio output to "fixed" or "external", which will disable the TVs speakers, while putting out sound to the Sharp.
Posted on Jan 06, 2011
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Whent I connet my android to my samsung HTC55 using the aux 2, just one speaker work, that is correct? is there a way to connect my android and all my speakers work
Your Android phone can only output in mono or stereo, but it does not have a surround sound decoder, so it cannot output natively to a 5.1 surround sound system. However, your HTC550 has a Surround Sound Mode called Dolby Pro Logic II, which will simulate 5.1 sound from any stereo input. Try activating Dolby Pro Logic II mode on your receiver to get surround sound on your Android phone.
Apr 28, 2011 | Samsung HTC550 Theater System
Trying to hook up this surround sound to a hdmi 1080p tv and cant get the speakers to make anything but background static. not sure if wires are connected correctly
You probably have to use the TV remote,go into the sound settings,and change it from stereo to whatever options there may be for surround.Good luck! Greg
Aug 22, 2010 | RCA -RP9972 190W Dolby Pro Logic System...
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Canoot get surround sound from back speakers
MAKE SURE YOU HAVE THE SPEAKERS WIRED INTO THE SURROUND NOT THE SURROUND BACK. IFF YOU HAVE SPEAKERS WIRED TO SURROUND MAKE SURE THE VOLUME FOR YOUR REARS IS TURNED UP.ALSO CHECK THAT YOU HAVE AMP SET FOR SURROUND SOUND,IE DOLBY DIGITAL OR PRO LOGIC TWO.
HOPE THIS HELPS.
Jun 01, 2008 | Audio Players & Recorders
Dec 18, 2007 | RCA RT2280 System
Yamaha htr-5240 dolby digital problem
Is there switch from dolby pro logic/ surround / or analog/ digital?
Sep 27, 2007 | Yamaha HTR-5240 Receiver
343 people viewed this question
Top Zenith Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Greg Cann
Greg Cann
Gagan Telecom
Gagan Telecom
Level 1 Expert
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
