Question about Canon PowerShot A510 Digital Camera
I have a CANON powershot a510 and it doesnt even turn on...
I checked the batteries and the memory card, they're both fine.... I keep clicking the on/off button but i never turns on...... Please help
  • Canon Master
  • 4,738 Answers
Here's some thing to try for a camera that won't power on.
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
For your camera, there's a tiny white slide switch on the battery door that closes when the door is closed. Make sure that the switch isn't damaged. Also check the little plastic nib on the battery door that pushes on the switch when the door is closed.
Posted on Jan 11, 2009
HI GOOD DAY I CANT TURN ON MY CAMERA IT DOESNT WORK EVAN WITH NEW BATERY THANKS
Check to make sure the batteries are inserted correctly.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.Close the [Memory Card / Battery Cover] securely, and then turn the power on.
If your camera still does not work even after you have performed the above procedures, your camera may be malfunctioning. Please have the camera serviced in this case.
Apr 19, 2011 | Canon PowerShot A460 Digital Camera
What is the maximum size of an SD card that can be used in a Canon PowerShot A510?
You can use any size SD card. Just keep in mind that SD cards max out at 2GB; any larger cards are actually SDHC cards and will not work in the A510.
Feb 05, 2011 | Canon PowerShot A510 Digital Camera
I have inserted a new PNY optima SC HC memory card and window in camera says "memory card error". Does the canon not take this card?
Correct. The A510 uses SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work.
Nov 02, 2010 | Canon PowerShot A510 Digital Camera
Canon Powershot A510 - black screen
well giving it a tap/thump it might have a dry joint ....
Sep 14, 2009 | Canon PowerShot A510 Digital Camera
My camera is not turning on even when we put in new batteries.
There could be 3 problems:
  • broken memory card door switch
  • broken battery door switch
  • dead fuse
I have seen all of these on A510 and A520. If you have a multimeter, some experience and like to repair it yourself, I could help you. My e-mail is toms.safranovs@gmail.com
If not, you should give it to a local camera repair shop or Canon service center for a repair.
Tom
Aug 01, 2009 | Canon PowerShot A510 Digital Camera
Can't format memory card in A510 Canon digital camera.
Have you used this card in the past? Is this a new card?
Is this card rated to be used with this camera. Some cameras can only support cards of certain sizes.
If the card is compatible, take the card to target or best buy and format it on a camera there and see if it works then put it back in your camera and see if it works after.
Mar 07, 2009 | Canon PowerShot A510 Digital Camera
Your LCD display might have switch off by mistake.
Press on the display button in the camera.
Jun 09, 2008 | Canon PowerShot A510 Digital Camera
Canon powershot A510 all of a sudden no power??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. Recommend trying first the one listed that describes removing the memory card before powering on the camera:
May 11, 2008 | Canon PowerShot A510 Digital Camera
Canon PowerShot A510 Digital Camera Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
