Question about Saws
Porta cable model 725 or 736 bandsaw stand or vise availability and price ?
Vise has chain and visegrip hold down for cutting metal,plastic,etc.
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Reduce bandsaw speed to cut metal
My old delta has the transmission on the back for cutting metal, and it is geared way down for power, 1140 would be way to fast, It is more like 40 rpm. I don't know if even a set of step pulleys would slow you down enough. Depends on the metal. I have the step pulleys too, but never bother to change them. The transmission, you just pull out the lock in the center of the pulley and it throws it into back gears. real nice, has an oil filled gear box on the bottom. Everybody wants my band saw!
Posted on Feb 23, 2010
How do you lock femi 782xl Bandsaw for vertical operation
BandSaw at Trick-Tools
vansantent.trick-tools.com/tools/BandSaw
BandSaw found in: Femi NG160ABS Benchtop Semi-Auto Mitering Bandsaw, Ellis 1600 Dual Mitering Head ... ...that has a locking valve for setting up cuts. ... The HEM Saw 782XL portable bandsaw is a great fit for hobbyists and those needing an accurate portable ... JET HVBS-56M, 5 x 6 inch Horizontal/Vertical Bandsaw.
Band Saws, Horizontal & Vertical - Trick Tools
www.trick-tools.com > Sawing
Find Band saws in a variety of configurations including horizontal, vertical, ... Bandsawblades are a long lasting and low cost consumable, reducing the maintenance andoperating cost of this type of ... Femi 782XL Benchtop Mitering Bandsaw.
FEMI 782XL Swivel Head Portable Bandsaw 110 volt
www.stakesys.co.uk > Shop By Category > Metal Cutting Band Saw
The 782XL can be locked in a vertical position and, when used in conjunction with the optional table kit and quadrant, used as a vertical bandsaw for cutting ...
' The Saw That Cuts Straight
www.hemsaw.com/
Dec 16, 2015 | Saws
How to replace the cranking pull cord?
Ok, the spring will more than likely unravel when you remove the pull cord cover/assembly. There is notch in the spool for winding the rope around it. So make sure the spring is wound enough to fit it in the housing. Then take the rope, already knotted and in the spool. Turn the spool in the direction that tightens the spring.Push down on spool and allow spring to retract the rope. (Don't forget to tie the knot in the rope handle before placing on mower). Then lightly clamp in vise or visegrip, or channel lock pliers. I like to use visegrips on one side, and channel locks on the other. Place over the square flywheel nut,release channelock pliers, hold with fingers tightly so the spring does not unravel. Then release visegrips and hold with other free hand, Place over flywheel nut and slide down. Re-attach with screw previously removed. Your done. Don't forget to tie the knot in the rope handle before placing on mower.
Mar 28, 2014 | Mtd 22" Yard Machine Push Mower
Replace guide bearings on jwbs-18 saw
" That one will be a press fit onto that eccentric shaft. Small bearings like that are easy to drive off with a suitable punch or mandrel. Simply stand it up in the jaws of a vise so the jaw edges contact the outer rim of the bearing and use a hammer to drive it out. Put a washer or similar bit of metal between the shaft end and the punch to protect the face."
Make sure before you put the new bearing on that the shaft is clean and smooth.
Nov 07, 2013 | Jet Machinery Jet Equipment 708750B...
! have a metal cutting bandsaw from toolmac model 73- 532501 Where can i get spare blades
One question , what happened to your blade? Why do you need spare blades? Oh ,actually,t here are lots of sites that can supply some blades for your bandsaw. Give it a try visiting sawblade.com .
Nov 04, 2012 | Saws
Will a timber bandsaw cut thin plastic or will i need a plastic cutting blade on my clarke bandsaw. The teeth are very fine on the timber saw thats in now thanks
Hi, yes it will cut plastic, but if its a brittle plastic you will need to guard against splitting. To guard against this you can brace the plastic with a thin sheet of plywood underneath whilst cutting.
Aug 31, 2010 | Garden
Sony vaio desktop all in one back light not working
To fix your problem please follow the below given steps
Step1
Power on your computer and wait until there should be an image displaying on your LCD monitor. Look directly into the monitor from a distance of about 1 inch way. Cup your hands around your face to block out the light in the room and get a clearer view of the LCD screen. Check to see if there is a faint light visible in the screen, which will indicate that the cold cathode backlight has gone out, or no image at all, which will indicate a different problem.
Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb
Step3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
Step4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the back light directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
Step5
Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
Step6
Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
Step7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the back light bulb was installed correctly.
Please rate me if this solution works for you
Thanks......Have a great time.
  • Step 2 Check the manual that came with your desktopmag-glass_10x10.gif LCD monitor or navigate to the manufacturer's website and find the model of cold cathode bulb that the monitor uses as a backlight. Purchase a corresponding replacement bulb.
  • Step 3 Power off your computer and then remove the monitor cable from the port on the back of the computer case. Disconnect the monitor stand from the monitor either by pulling out the plastic latches or by removing the screws holding it to the monitor's casing.
  • Step 4 Lay the monitor face down onto a stable work surface such as a desk or table. Take out the screws along the edges of the monitor's casing and set them aside. Lift the back side of the monitor case off of the monitor and set it aside. Check to see if your model of LCD monitor has the backlight directly exposed on the lower end of the monitor or if it is hidden behind another plastic or metal piece.
  • Step 5 Remove the screws holding the plastic or metal piece over the bulb if there is one present and set the piece aside. Check to see if your model of monitor keeps the bulb in a plastic casing or if it is soldered directly to the metal. Use a soldering tool to remove the solder or instead use a rotary cutting tool to cut into the clear plastic casing around the bulb if it is inside a case.
  • Step 6 Slide the new bulb into the open spot on the monitor and either solder it in place or use a piece of tape to cover over the opening you made on the plastic casing with the rotary cutting tool. Place the metal or plastic cover back on if there was one and reattach the screws. Set the casing back onto the monitor and place the screws back in.
  • Step 7 Put the stand back on the monitor and then reconnect it to your desktop computer. Power the computer on and wait for an image to appear on the screen to make sure the backlight bulb was installed correctly.
  • Read more: How to Diagnose & Repair Desktop LCD Backlight Problems | eHow.com http://www.ehow.com/how_5038642_diagnose-desktop-lcd-backlight-problems.html#ixzz0uJr4tmU8
    Jul 20, 2010 | Sony VAIO PCV-V200G PC Desktop
    Feb 23, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
    How do I adjust a craftsman bandsaw to keep it from pinching when cutting circles. I have inheirted the bandsaw with no manual
    Hi Alvin,
    Lower the vertical guide down until it is just above the cutting surface.
    However, a standard band saw blade is primarily for straight cuts. They are too wide to make sharp turns.
    If you are attempting intricate work requiring extreme angled cuts, a scroll saw is better suited for your needs.
    An alternative to check on would be if any thinner scroll emulator type blades are available for your model. They don't as well on heavy jobs, but you'll get the maneuvering you need on the thinner stuff.
    Best regards
    Mike
    Nov 06, 2009 | Craftsman Saws
    Rubber on wheels is shot. Where can I get new rubber?
    Here are a few links to new tires for your bandsaw, available here and here and here. If you google "bandsaw tires", you'll find they are pretty widely available and may be able to come up with a better price...
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    May 08, 2009 | Delta Woodworking Delta Rockwell 14 Inch...
    Saws Logo
    20 people viewed this question
    Top Saws Experts
    Tom Chichester
    ray gallant
    Pieter Vleeshouwers
    Pieter Vleeshouwers
    Are you a Saw Expert? Answer questions, earn points and help others
