USB Flash drive broken
My USB flash drive USB connection broke away from the circuit board. Where I can I take this to be repaired? or can the chip be lifted and placed on to another chasie?
  • 827 Answers
If the USB port is straight onto the motherboard then 'in theory' it can be repaired by soldering another one on, but I wouldn't expect to do fine soldering without damaging any other component on the motherboard, so there is no economical way to repair it.
If it is under warrenty say that it wore out over time, and you have just used it normally, they may replace it under warrenty...
Otherwise your best bet is to buy a USB hub if you need more USB ports.
Hope this helps
Chris (ziraffa)
Posted on Jan 11, 2009
    Scholar:
  • 149 Answers
If its broken off the circuit board (motherboard) then forget about fixing it back on......if its a desktop you've got and you have a spare pci slot then you can buy a pci card with usb connections (basically a USB hub)...... if you've got a laptop then you can buy a pcmcia card (like a credit card size USB hub)...both these cards will take the place of your onboard USB and won't cost anywhere near the amount to fix the broken usb ports on the motherboard
  • 535 Answers
If u take it in to repier in repeir cost u will buy a new pandrive
  • 741 Answers
Have to be taken to either your local PC repair shop or sent back to the manufacturer. I would send it back to the manufacturer because they are more familiar with your system. There is nothing you can do to fix it has to be fixed on motherboard.
Don't forget to rate this solution..
How to Repair USB Flash Drives Broken, Unrecognized, Not Detected?
hi Jhon.
this is all i could find out.
Navigate Control Panel -> System -> Device Manager -> Disk drivers. 3. Find and select your USB device, right click and first choose "Uninstall" and then choose "Scan for hardware changes" to refresh the drivers. After all the operations, you will find USB not recognized issue is fixed and the flash drive is detected.24 Jun 2016
Repair & Recover USB Flash Drive not Recognized or Detected ...
https://www.easeus.com/resource/usb-flash-drive-not-recognized.html
How can I fix USB device not recognized?Method 4: Reinstall USB controllers.Select Start, then type device manager in the Search box, and then select Device Manager.Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...Once complete, restart your computer. Your USB controllers will automatically install.Error: "USB Device not recognized" when you try to access a USB ...https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces...Search for: How can I fix USB device not recognized?
how to repair usb flash drive not recognized Google Search
Nov 30, 2017 | Electronics - Others
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
My flash drive is broken.........the end is broken away from the circut board. Can it be repaired?
Only attempt this repair if you need the information on the USB drive as they are fairly delicate devices inside.You should be able to repair it if you have the right fine soldering iron and good soldering skills as the printed circuit board tracks will be very fine: you will probably need to very carefully re-attach the USB plug to the printed circuit board with strong epoxy glue and then ensure that you re-join (with the help of extremely thin electrical wire if require) all the tracks to the 4 USB pins. The Electronic is very static electricity sensitive, so make sure that you do not ZAP it by first earthing yourself! Hope it helps and Good luck!
Jun 11, 2010 | Cameras
Broken usb flash drive
The data is not destroyed, but it will be tricky to fix. I would suggest you find a local computer tech who is really good soldering tiny stuff. Or go to a Radio/TV repair shop. I think it will be possible to re-connect the wires and make it work.
Sep 29, 2009 | Computers & Internet
Travel Drive Broke
It depends on your skill level as to if it can be fixed or not. The data is most likely still safely stored on the flash chip inside the drive casing. However, the USB connector has been just ripped off. If you have any experience soldering it would be as simple as getting a replacement usb plug from an electronics store or cutting a cable you have and then soldering the USB connector back to the flash drive inside the casing. This is something than can be done at home or possible by a repair shop that does any type of soldering work(tv, radios, ect) Most computer repair shops will look at you silly if you ask them to solder a thumb drive back to life. I would not expect more than to be able to mount your drive and copy the data. Odds are after you cut it out of the casing it will never go back in correctly.
Good Luck
Aug 21, 2009 | Memorex Electronics - Others
Memory stick problems!!
It depends on how good you are with a soldering iron HA :) just kidding.
the two main problems that I get on broken flash drive are:
1. the usb plug has broken off the little board. (you broke the connector off)
2. The chip has came away from the board (you bent it and popped the chip)
The quick and dirty fix for this is get a giant flat pink eraser (the width of your thumb) and some thick rubber bands. If the chip is loose then strap it to its board with some rubber bands making sure they connect back as they should while using the big pink eraser as a backing and support. attach a short usb extension cable so that you will not have to move it to plug it in once you have it strapped in.
If the usb plug is broken off then use the same process attach the usb
extension to the plug remnants and then lay the two pieces as they should be on the eraser and rubber band them together.sometimes it helps to put a little wad of paper under them to make them fit snug. plug it up and away you go.
at this point windows will most likely see the drive and can copy off your files.
HOWEVER( it may complain its not formatted, make sure that you do NOT format it) download recuvia at http://www.recuva.com/ and have it chew on the drive usually I can get something off the drive occasionally all the files. Just make sure that you have it restore the files to another drive (like your C: drive) that is good. Good luck.
the correct way involves a stereo microscope and micro soldering tools.
and you just "fix" it by soldering it back together.
Apr 14, 2009 | ASUS PR-DLSW Motherboard
Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Jan 22, 2008 | Electronics - Others
Laptop fell onto floor...now my memorex travel drive is broken...all college papers lost...help
This is actually fairly common, if the laptop still works with the broken USB socket you can take the cheap approach which is just don't use that port. If you need more ports a USB hub is pretty inexpensive.
Nov 27, 2007 | Electronics - Others
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
