Carrier Furnace is not blowing Heat
I have a Carrier Furnace Model 58STA/STX Can anyone give a solution why it's not blowing Heat?
  • darianlsmith Jan 11, 2009
    I Popped out the old manual and did a couple of test, Still not working I do have a blinking LED, But I see no Code?
  • 700 Answers
Heres the manual for the unit, look at pages 46-47 and theres a trouble shooting ladder schematic that asks what the systums are then gives the solutions for the fix. if you are still having problems you can request to talk to me and I'll be more than happy to help.
Posted on Jan 11, 2009
  • Todd Born
    Todd Born Jan 11, 2009
    how ,many blinks?
  • Todd Born
    count the number of blinks there should be first one are fast then slow let me know the number of fast then number of slow
Carrier 58sta/stx inducer moter not receiving power. The blower turns on. Its giving me a code 31 error. Any help is apreciated.
Code 31 is a pressure failure...
Hello JT Beltran,
Cyber-"wisdom" has it as a PRESSURE SWITCH FAILURE
(not closed)...
((DON'T short past it... unless you know what you are doing)).
Usually reserved for heaters with really filthy ... heavily clogged FILTERS... or blocked duct work (too many closed vents)
Once you have eliminated the obvious fire hazards of blocked AIR circulation, checked your filter is INDEED CLEAN &
unobstructed...YOU HAVE the (un-likely) faulty pressure switch...
Hope this helps.
Jan 02, 2017 | Carrier Heating & Cooling
Carrier 58STA/STX furnace false starts even when off or temperature set lower than current.
Is it possible the drain is plugged? The newer furnaces have a moisture drain and will shut down if they are blocked., shutting them down and restarting will reset fault, but will come right back if not fixed.
Dec 24, 2014 | Carrier Heating & Cooling
Carrier 58STA furnace code 33, no ignition blower stays on. I have a Carrier 58STA furnace. It's getting a code 33 and never trying to ignite. The blower constantly stays on. It is pushing good air...
33 is a limit switch open take your furnace doors off and there should be a wiring diagram. on this furnace the blower will run if this is open. check rool out swict and linits. it sounds like you have a problem with over heating. how does the fire look ? is the vent blocked ? things like that i think page 9 has falt codes
Feb 11, 2011 | Heating & Cooling
My carrier 58sta furncace is blowing cold air constantly
Code 33 is "limit is open or flame switch is open"
FIRST make sure the filter is clean. Turn off unit then turn back on.
if it works but then later gives you a 33 code then you might have a dirty a/c coil (if you have a/c) that will cause the limit to open. 1st try that
Mar 21, 2010 | Carrier Heating & Cooling
I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Feb 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
No air in two rooms?
without replacing duct size you may damper down the airflow on the vents that have more air by closing them or taking the grill down and blocking them with an insulation type material.
Jun 11, 2009 | Heating & Cooling
Carrier Furnace Model 58STA/STX not firing
Have you checked the gas valve on the unit.. is it set to on? also check the gas valve going to the unit on?
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
1,002 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
