Question about Hardware & Accessories
My Nordik TM-064 digital outdoor timer switches on and off when operating. Solution?
I have set the timer for a four hour operation. It worked well for the first hour but has now started to switch on and off at every 5 minutes. Should I unplug and re-start? Other solution?
2 Suggested Answers
SOURCE: How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Posted on Dec 18, 2010
I lost instructions for setting Woods Outdoor 24-Hour Mechanical Timer. I set time of day and pressed down tabs for on and off time, but nothing happened. What more do I need to do?.
1) Copy following link for how to set analog timer by experimenting with features.
http://waterheatertimer.org/How-to-set-timers.html
2) Usually you move slide switch to timer, and make sure load is ON and operable before plugging into timer.
Dec 10, 2012 | Woods Outdoor 24 Hour Mechanical Heavy...
How do i set my timer to turn my xmas lights on at dusk and off in 7hrs.
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Some timers let you select hours of operation once timer turns ON at dusk.
Each timer is slightly different, depending on brand, type, and if timer is digital or mechanical.
Nov 18, 2012 | Woods Outdoor Photoelectric 24 Hour...
I lost directions for my farberware kitchen timer. it is battery operated,has a digital display and 4 buttons.(one green ,one red and two black buttons..) i cannot reset the time. if you can tell me the...
I recently bought one. The instructions are on the packaging.
To switch from timer mode to clock mode, press STOP and START together.
To set the clock, press START and hold for 5 seconds until the whole display flashes. Press HOUR to set the hour. Press MINUTE to set the minutes. Press START to start the clock.
Mar 13, 2011 | Sport & Outdoor - Others
Dec 17, 2010 | Woods Outdoor Lighting Timer
How do I set the woods outdoor timer model #59730
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
If this is not your timer, look at following page to identify your timer
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Dec 09, 2010 | Woods Outdoor Lighting Timer
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I have a Woods TM1710 outdoor timer and the instructions are not very clear. First, what is the manual overide switch. Second, what are all the on/off positions on the dial for. Third, which part of the...
Woods timers and manuals
Woods TM1710 shows at page bottom, and does not have online manual that I can find
TH1710 is a promotional timer for outdoor use.
TD series and TM series timers are evidently sold at a price point, and not made with same features as more expensive timers.
That being said, TM1710 has a dial that rotates as time passes.
Poor image quality is hard to make out, but dial looks like 12 hour.
If this is true, then time programs repeat each 12 hours.
Set timer and the lights turn on-off during am hours, and then cycle repeats for pm hours.
Kinda silly to make 12-hour outdoor repeat timer since you want outdoor lights ON during pm but not am. But cheap prices sway we shoppers who later discover a saw horse that is supposed to balance on 2 legs.
To set ON-OFF times, there are segments located around outer edge of dial.
Pull segments up or leave them pushed down to set ON-OFF.
Most timers are OFF during hours when segments are pulled up, and ON when segments down, but this timer may be opposite.
Manual override is button or switch that overrides timer functions and turns light ON full time.
Again poor image quality makes it impossible to see manual override, but it looks like manual override is white button to lower right of dial.
If that button is manual override, then it appears to rotate.
Usually you set override one direction to override, and other direction for timer to operate
Nov 27, 2010 | Woods Hardware & Accessories
I have a new Nordik digital indoor timer TD133B. It has never displayed information on it's screen. The instruction manual indicates plugging it in for an hour to charge the battery. I did this but still...
Most plug-in timers have rechargeable battery that is not replaceable.
Instructions say: Plug in timer for hour and then unplug it to set programs.
Intermatic makes a couple plug-in outdoor timers with replaceable batteries that load from back of timer, but otherwise batteries are rechargeable.
If battery will not charge, then display doesn't show, and that signals the timer is no good.
Take timer back if you can, and exchange for another.
I was looking at timers in Walmart and Target yesterday (since my specialty, and interest is timers).
New plug-in timers are inexpensive.
Lowes and Home Depot also carry inexpensive plug-in timers.
Be sure to save timer instructions because generally, store-bought timer brands don't show manuals on-line. Except GE brand timers from Home Depot.
Add a comment if you need more help.
Nov 25, 2010 | Hardware & Accessories
We have a clock operated digital timer but can't find the instructions. Its a 125V general purpose timer. We can't find a maker name anywhere on the timer. The numbers on it are TM-012 and E227659. We...
Plug it in, put a paper clip in the reset. Hold CLK and then push day, hour, minute for actual time.
Push and release program to turn on and off.
Nov 10, 2010 | Garden
Hardware & Accessories Logo
176 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
