Question about Hoover Vacuums
Kenmore Intuition Vacuum # 28014 does not suck up stuff
Vacuum stop working the head is still running but the motor is not running there is not suction j
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
Agent Don
  • 310 Answers
SOURCE: My vacuum blows air instead
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=571660
Generic problem for all Vacuums
Posted by katweaver3 on May 04, 2008
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesn’t **** stuff up anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally if your vacuum has a round belt you may have your belt on backwards, please reverse the belt and the suction will return also you may have a clog in the tube leading up to the bag or dirt cup would be anther reason for the blowing instead of suction. This is not covered under the factory warranty. Feel free to contact your local vacuum dealer for questions.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 05, 2008
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
#1 Taper
  • 1040 Answers
SOURCE: No suction
You have a clog somewhere in the vacuum. Check the hose and the little trap door on the underneath side of sweeper.
Does the brush turn? If not, then the belt that drives the brush is broken. Replace the belt
Jim
Posted on Jun 12, 2009
  • 382 Answers
SOURCE: my kenmore intuition vacuum seems
if you bought it new then do not screw w it take it back to sears and demand a replacement or your money back Sears is very reasonable re this
Posted on Dec 20, 2009
Stick vacuum
It sounds like your head is blocked. Remove the head from the vacuum. get a metal coat hanger, straighten it out and bend a small hook on one end. Insert the hook into the head from the vacuum end until it stops, revolve it 1 or 2 times and pull it back out. If there is debris on the end, keep doing it until no more debris. Shake the head upside down to remove more debris. If you can access the bottom of the pickup tube, blow air into it with a compressor until it blows clear. try the head again ( you may need to disassemble the head to get that blockage out - likely it is hair causing the blockage).
Hope this helps!!
Dec 02, 2013 | Dyson Vacuums
Unbeknownst to me, someone took the bag out of my Kenmore Progressive vacuum and failed to replace it. I have been vacuuming without a bag for months, and today the vacuum stopped sucking. When I opened...
Sounds like you need to buy a new motor. All that grit and dust will ruin a motor and I'm surprised it lasted as long as it did.
This is where a vacuum that won't run without a bag would have been nice. (Aerus for one)
Nov 16, 2010 | Kenmore 31913 Progressive Direct Drive...
I have a Kenmore Elegance Vacuum with Dirt Sensor, Model # 116.30750400C, Serial number M41901532. When vacuuming the carpet the power head will work for 3-6 mins then automatically shut off, power is...
It is an electrical problem in the handle, if you can or know somebody that has any fix it ability it can be fixed in about ten minutes. Oh, and Sears SUCKS!!
Oct 17, 2010 | Kenmore 34612 Bagged Upright Vacuum
Is there an operating manual on the web for a Kenmore Intuition vacuum cleaner
Hi, here is a link to a site that holds the manuals, but you will need the model number of your cleaner. Hope it helps! Please rate me. :) http://www.managemylife.com/mmh/owner_manuals/search/product_type.Vacuum,%20Upright?query=Kenmore
Jul 17, 2010 | Kenmore Vacuums
Motor quit working. i was vacuuming and all seemed fine. then the motor went really low. when I opened it I noticed that the bag was not attached and the cannister had filled up with stuff and the filter...
My friend, the dirt you sucked up went right into the motor and it burned up. I am very sorry to tell you this. It is probably not worth repairing unless you are able to replace it yourself.
In addition to not being able to dool itself, you probably got dirt in the bearings and certainly in the motor brushes damaging the armature.
If you want to try the fix, find a new motor at a FisYa.com advertiser or partner, your local Sears or at www.repairclinic.com
Thanks for posting at FixYa.com
Please vote ... and dont kill the messenger
thank you
a
Dec 13, 2009 | Kenmore 31912 Progressive Direct Drive...
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Loud whistling noise from back of vacuum
On the back side of most kenmore vacuums, there is an air relief diaphragm that, when the motor is sucking but there is no air flow, will pop, causing the sound you heard. check your hose for blockage, check your bag and or filter for blockage,even your attachments/wands can become lodged with debris. Often, after a few, the motor will get hot and the machine will shut down. This is a thermostat on the motor that protects it from overheating. I am quite sure that this will solve your kenmore woes, fine choice in vacuum, kenmore, tried and true. hope to have helped! Have a super, and hopefully sucking(ha ha) Sunday
Jan 03, 2009 | Kenmore 34720 Upright Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
