Windows not starting successfully.
My Compaq nx6110 turns on but stops on a black screen with white writing. It says "Windows did not start successfully. A recent hardware or software change might have caused this." It then has 5 options - Safe ModeSafe Mode with NetworkingSafe Mode with Command PromptLast Known Good ConfigurationStart Windows NormallyI have tried all 5 options but it always reverts to this screen again after briefly being on the 'Windows xp loading screen'.Can anybody help? Thanks!
  • 1 more comment
  • bobbyberto10 Jan 11, 2009
    There are no usb devices in, i don't think i have recently installed any hardware, so how do i reinstall windows xp? If i do, will i lose anything?
    Thanks for the help!
    I have entered the CD but nothing happens apart from the timer stopping counting down.
    As far as i'm aware my 'USB CD-ROM' is set to boot before my notebook hard drive. I keep on restarting the pc but nothing happens when i press any key apart from back to the error screen.
    Scholar:
  • 96 Answers
First address the file system by using your operating system cd. You can follow the below steps
to run the check disk utility followed by fix master boot record utility.
Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
At the command prompt, type chkdsk /r , and then press ENTER. (Space btwn k and /r)
At the command prompt, type exit , and then press ENTER to restart your computer.
The system should boot back into Windows.
If that doesn't work follow the above steps again but after you type the Administrator password ...
At the command prompt, type fixmbr and continue the next two steps.
THIS SOLUTION IS ONLY FOR A DAMAGED FILE SYSTEM.
If you get up and running you'll need to click START....RUN....then type cmd into box and hit enter.
Once your command prompt opens type sfc/scannow and press enter. The XP CD needs to be
inserted into your optical drive (CD DRIVE).
Nate P.
Posted on Jan 11, 2009
  • Nate Phillips
    Nate Phillips Jan 11, 2009
    You have to anticipate the power on self test if it's not asking : press any key to boot from cd.
    Press DEL to get into your basic input output settings soon as your system starts. Press the key continuously until the BIOS Settings screen appears. Scroll to your boot menu and choose your cd rom as your first item in boot sequence. Scroll to exit and choose save settings then press enter.
  • 71 Answers
You must remove all usb devices and any hadware you have recently installed if this problem still occures you will need to reinstall windows xp
  • Travis Foreman Jan 11, 2009
    insert the windows xp cd restart the pc then keep pressinr f9 untill you see a menu asking to select what to boot from then select the cd rom then press any key to boot from cd when the setup is started you will see files loadind at the bottom of the screen when the files have finished loading you will see windows setup screen press enter to install windows xp then you will have to press f8 to agree then you will see options asking you what to do select repair and the setup will start
Can't format my tablet pc or even start windows... PLEASE HELP!!!!
http://www.techradar.com/news/software/operating-systems/how-to-create-a-windows-rescue-usb-stick-984726
Mar 05, 2017 | Compaq 2710p Tablet PC
Hp compaq nx6110 hangin when booting and difficult to recognise the hard drive
Try booting into safe mode by pressing F8 at startup until the boot menu appears. Then select "safe mode with networking". If it boots into safe mode then see if your missing some drivers in device manager. If you are then download and install them. Next run some anti-virus and anti-malware programs to make sure your system is clean.
Jun 01, 2012 | HP Compaq nx6110 PC Laptop
WHEN I TURN MY WINDOWS XP ON IT HAS A BLACK SCREEN WITH WHITE WRITING SAYING, WE APPOLOGIZE FOE THIS INCONVENIENCE, , BUT WINDOWS DID NOT START SUCCESSFULLY. A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT...
Try safe mode.
If that works, there is a card or software that has failed.
Checking the cards is easy, take them out one at a time and restart, for motherboard features, shut them down one at a time.
For software, did you load anything new, even updates, if so remove them.
Mine turned out to be a bad PCI card for a scanner.
Feb 18, 2010 | Computers & Internet
Window did not start successfully,the screen was displaying this message after i used the system without charging for a long period of time, he command promt is not even responding it just changes from the...
While you are trying to boot up, before the Windows logo comes up, start tapping the F8 key on your keyboard. Then try to use the option "Last known good configuration". If that one does not work, try to go to the safe mode option
Nov 01, 2009 | HP Compaq nx6110 PC Laptop
Compaq laptop power comes on screen stays black
Does the computer make any sound,like the Windows startup music ? If not The hard disk motherboard my be defective.
Jan 06, 2009 | HP Compaq nx6110 PC Laptop
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
Compaq pesario C300 not starting
Have you tested your harddrive to make sure it's working properly,or you are maybe missing ntldr
Dec 10, 2008 | Compaq Pesario S4120WM (DK216AR#ABA) PC...
HELP!! PLEAse!!!!!
What you have done is put a BIOS password on your system, all you have to do is enter the password you typed after you hit F10 the first time when the system boots up. if the password does not work try hitting the caps lock key and entering the password again.
May 07, 2008 | HP Compaq nx6110 Notebook
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
