Question about GPS
I replaced the battery in my navman C60 and now it wont turn on
It would never hold charge and was working before replaced battery. I even put the old battery back in and it wont turn on or do anything?
SOURCE: epson c60 problem
Problems with Epson Stylus C43UX InkJet Printer Driver Downlaond
Posted on Jan 07, 2008
SOURCE: navman F10
i'm having the sam problem this is my secound unit what is wrong with things pls help
Posted on May 01, 2008
Geekman
  • 32281 Answers
SOURCE: New 6600 mAh battery won't charge
Is the AC adapter the original that came with the laptop or is it a replacement?
Check the label on the laptop (on the bottom of the laptop) for the voltage and current requirements.
Check voltage output of the adapter with a multimeter, this voltage should be slightly higher that the voltage than what is shown on the adapter's label because there is no load on the adapter.
It could be that the current (amps) that the adapter is delivering less power than the laptop's requirements, whilst it can power the laptop it may not be sufficient to charge the battery fully.
Try charging the battery overnight by shutting down the laptop but leaving it connected to the mains. Then boot up the laptop in the morning and check the battery's charge state. If the battery is at or near full capacity, then the problem is a (part) faulty adapter.
Posted on Jan 07, 2009
cadman000
  • 607 Answers
SOURCE: 98 cadillac deville battery wont hold a charge
sounds like a 12V drain on the system, like a trunk or glove box light that won't shut off.> Could be many. many other reasons why. The way I would find the draining circuit would be to remove the neg cable of the battery. I then would connect a 12V test light between the neg battery TERMINAL and the neg battery CABLE. With a 12V drain the light will shine. I would install into the light a 9V battery powered recepticle to hold computer and radio station memory. Then I remove fuses 1 at a time, then reinstall, at the same time looking for the 12V light to go out. Hope this helps.
Posted on Apr 05, 2009
SOURCE: battery not holding a charge,
Check the charging rate of your bike, see if its system is charging, if it does charge thn theres somewhere the battery is getting drained out.
In order to see if tht is happenning, switch off everything and thn remove one battery wire on the battery, after doing so try to fix it back and notice if theres any sparks when it comes to the contact of the battery terminal , if so thn theres a drain somewhere in the electricals and wiring.
Good luck.
Knight (Yamaha Seca XJ750A 1981)
Posted on Apr 17, 2009
Www navman com manuals
Rechargeable battery life is not infinite. A few houndered times is about all you get on average. How deeply you let it discharge, the temperature of the space that it is in, how long you let it charge, etc. all affect the number of charge / discharge cycles it can provide.
You should probably have the battery replaced - or if too costly, stick with direct power only.
May 24, 2013 | GPS
Navman wont start
well does it have an AC inlet to charge it? If so use it rathyer than DC car charger to revive a depleted battery. It will take an hour or so to get up enough power to turn it on and a few more hours to get a decent charge into it. Life of battery in unused state is around 3-4 days depending on condition of the battery. Total depletion will take some time to get the battery to recover siufficiuently to get basic operation to occur. Be patient and if this fails to fix it try replacing the battery altogether
Jul 24, 2009 | Navman Personal Interactive Navigation GPS...
My ds lite wont turn on but it charges fine
if your ds is about 2 years old, it's probably time to change the battery. even though the battery is rechargeable, it wont hold a charge as it gets older. no matter how long you keep it on the charger, the battery is truly dead and it wont turn on. if anything, replace the battery. if your ds is brand spanking new, then you probably didn't leave it on the charger long enough to begin with.
hope this helped
Jul 23, 2009 | Nintendo Video Game Consoles & Games
Pin navman handhelp pc will not work off battery
Try holding soft reset for a couple of minutes whilst charging. If this does not work leave pda charging with hard reset switched off BUT all data will be lost. Then move hard rest and if you are lucky the green charging light will start flashing and you can switch on. It sounds as though you have flat battery and if left too long restarting becomes very difficult as the motherboard cannot start the recharging process while the pda is switched on. This is true even with new batteries which can be supplied flat if old stock.
Even liquid damage is unlikely as there are so few exposed connectors. I have not tried it but gently drying motherboard with a hair drier on gentle setting and cleaning battery connector and screen ribbon cable before assmbling might work. Treat both connectors as being etremely fragile although they are more robust than you might think. But treat them with extreme care as repairs to them would be more expensive than the value of a working pda.
Jun 09, 2009 | Navman PiN 570 GPS Receiver
Navman icn520
check the battery switch on the back. you will need a pen. Mine does the same thing. I believe this switch has to be set to ON for it to work. At least mine wont turn on unless the switch is turned on.
Apr 10, 2008 | Navman iCN 520 GPS Receiver
Nickel metal hydride battery wont charge
It is time to replace the battery. What is the model number of your camcorder.
Feb 28, 2008 | Video Cameras
Navman F10
Feb 10, 2008 | Navman F20 GPS Receiver
Navman Pin570 battery replacement
There are 2 little black tabs at the botton of the back that you have to remove, behind these there are 2 screws u remove, and flip the ariel up and there are 2 screws under there you remove also.
The body is clicked together use a guitar pick, ur fingernails or small scewdriver to seperate the 2 sections.
Inside you will see a few screws holding the systemboard down, if need unscrew them.
you will see the battery its stuck onto the system board... be carefull seperating it,.. use a flat intrument or a butter knife to work it of the board ( its stuck on with double-sided tape or some kind of silicon)..
unplug it,
plug your new battery in.. BONGO
Let me know how you go.
cheers
plato
Put it all back together again
Jan 22, 2008 | Navman PiN 570 GPS Receiver
Navman repair
Any electronics repair place or perhaps a camera repair shop should be able to fix it for your. Search google or your local phone book for electronics repair or camera repair. This is a very easy repair IF you are electronics savvy, but not a good first/learning project. This will require either soldering a loose connector back to the board or they may need to find and purchase a new connector to replace the old one if it is broken.
Nov 09, 2007 | Navman ICN510 GPS Receiver
GPS Logo
65 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
