Question about Sony Net MD Walkman MZ-N510 MiniDisc Recorder
Copying files few of my MDs are failing not sure why but maybe its dust .... i would like to put my collection on to my pc so as not lose any more music of which some is irreplaceable... can you please tell me how to do this .. thanking you in anticipation karl
    Brigadier General:
  • 3,006 Answers
You cannot do this.
All minidisc player/recorders (with the partial exception of the later and far rarer Hi-MD players) can only download material from the host computer. They are physically incapable at the basic hardware level of uploading material to the host computer even if it's material which you own the copyright for. As a result, there's not even a hack for it as the wiring just isn't there to do it.
The only way to transfer from the minidisc player to the host computer is by connecting a lead to the audio output socket (headphone socket) and to the audio input socket (microphone) on the host computer. There is some quality lost but if the computer has a good audio card and matching software the losses are minimal. You can improve the transfer quality by going into the menu of the MZ-N510 and setting the output socket to "line". This bypasses the volume controls completely giving a purer signal path.
The failures you're experiencing are often due to discs being corrupted by either magnets or by being left in a hot car or bag but more often just due to the anti-friction coatings within the disc casing. The more expensive blank discs didn't necessarily offer a better recording quality but the discs themselves generally last far longer.
Posted on Jul 07, 2009
After charging W350i not recognising SIM says, 'Insert SIM Card'. But the same SIM card is operative in other mobile. How can retrieve Phone contacts? Please help.
make sure if sim reader is not pin damaged or water damaged? if problem persist i think you can connect your device without simcard and copy all data to your pc, then give some repairer to check maybe need to flash (if flash you will lose your data).
or try to put your mobile without battery 2 days and then switch on to see may be this problem solves.with S.E. this problem a normal.
Jun 21, 2012 | Sony Ericsson W350i Cell Phone
The system re boots after every few seconds
A critical file is corrupted. Since the reboot occurs after a few seconds then the file is a core file. In that case the only fix is to reinstall Windows. If you have important files you cannot afford to lose then use a Linux Live CD to copy them to a memory stick before reinstalling.
Apr 12, 2011 | Fujitsu Siemens Celsius R610 PC Desktop
Can't open my 3-2-1 Collect spreadsheet due to a missing .dll file. If I reinstall the software, will I lose the data already in the spreadsheet?
In general, you should not lose any data by reinstalling the software.
However, I always recommend backing up any files you want to save by copying it onto a USB drive. This will allow you to recover if something does go wrong.
Jul 15, 2010 | Computers & Internet
Cannot record digitaly
Is the tape write-protected? If so, remove the protection.
May 05, 2010 | Sony MDS-JE480 Mini Disc Player
When i connect my pen drive my computer recognizes it and the drive is shown, but the data in the drive is not shown. Any idea? When checked the used space, it was full, but the data is not visible. What...
Have you checked in disk management whether partition is active or not , It could be spyware or malware issue. Run chkdsk command in command prompt. Then check.
Regards :
Chandan
Sep 08, 2009 | Electronics - Others
SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
Jun 29, 2009 | Sony MDS-JE470 Mini Disc Player
I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Jun 24, 2009 | Sony MDS-JE520 Mini Disc Player
Emachines desktop model T2899
This problem can be any number of issues.
1. Heat. Make sure the air vents on the tower are free from dirt and debris. Open the side up and, using a can of air found in most electronic departments at stores, blow off the dust on the fan and heatsink which resides on top of the CPU. Also blow out as much dust as you can. If your computer is fairly dusty then this should solve your problem, if not check out the other things.
2. Power supply. Sometimes when a power supply begins to fail, it doesn't put out enough voltage to the various devices inside your PC when under load. Swap out the power supply with one from a know working system to verify.
3. Memory. Remove and reseat the memory chips inside the computer. Download a program like memtest to run checks on your memory.
4. Hard Drive. Sometimes when a hard drive begins to fail, it loses valuable windows files. The computer chugs along up until a point it looks for a file then it kills the system.
Based on the issue you described, I believe it to be a heat issue as the computer is designed to automatically shut down if the CPU reaches a critical temperature to protect the internal components.
Jun 22, 2008 | E-Machines eMachines Desktop PC
Bible collection old version cant pull up int.6 need help
If you are having problems opening the software though might need to reinstall the software. If reinstalling dosen't work you might want to see if there is an error message. If there is not you might want to try and right click the icon and click run. If none of these suggestions help you can e-mail me at 4077mashunit@gmail.com and i will personally fix your problem.
All the Best,
RCF
May 26, 2008 | Computers & Internet
Philips Wireless Music Center wacs7000
Well I think thats the probem about this pc's they can't copy a cd file to the pc if its an original, but if copying the files to a new cd it will. maybe it has a copyright. for the pc. well I tried nero to change the file, cuz' sometimes the file is a different format.
or you may use Itunes from apple to download them into your HD. then try to reformat them using nero. ( if nero will)
pls. dont rate me badly. );
Feb 13, 2008 | Audio Players & Recorders
Sony Net MD Walkman MZ-N510 MiniDisc Recorder Logo
156 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
