Question about Kitchen Ranges
F1-8 error code
Oven door doesn't close properly. F1-8 error code appears. Control panel does not work. What should we do?
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Dec 02, 2012
  • 1 more comment
  • Aliza Baron Dec 02, 2012
    Model # is JGS8850ADS. At first the error appearing was F1-1, and the oven door wasn't closing properly. When a technician came out to look the oven, he pushed all of the control panel buttons, looked at the door, and then the control panel showed F1- and didn't beep after any buttons were pushed. Seems like he made the problem worse? Before the oven worked for 1/2 before shutting down. Now, it's completely unresponsive. Any thoughts or suggestions?
    I meant to type F1-8. that's my new error reading.
  • Richard Roth
    Richard Roth Dec 02, 2012
    OK, you will need to replace the control board. Here is the board to order.http://bit.ly/11my2iz
SOURCE: Error Code F1:E3
reprogram the control board as following:press buttons on range
power off wait 5 sec
power on wait 5 sec
convection broil
clean
backed goods
stop time
190
timer set
start button 12 times(it will go through all the settings)
Posted on Mar 18, 2008
blueextc3221
  • 15935 Answers
SOURCE: oven not working error code F1 and beeping
On ranges where the electronic control and keypad are permanently attached to each other (ie. not separately replaceable) like on your range, a faulty oven sensor or problem in the sensor's wiring circuit can cause that error code on some models. Most oven sensors used these days should read about 1100 ohms when at room temperature.
Here are some juicy pearls of appliantology wisdom from our friends at Maytag for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here’s a simple explanation of what’s going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (1.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn’t high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn’t happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you’re gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel –don’t spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Most likely culprit: Temp Sensor
CLICK HERE
9e4f6b6.jpg That cylindrical object is the sensor. It's two wires connect to the ERC. You can remove those wires from the ERC and test the resistance with an OhmMeter.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 07, 2009
buffalonyman
  • 1865 Answers
SOURCE: Oven shows error on control panel: F1:E9.
Replace the electronic range control ERC
Posted on Nov 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: oven door locks, the panel beeps, and displays F1 error code
Here is some wisdom for understanding F1 fault codes.
Here's a simple explanation of what's going on and how to troubleshoot:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
gy^%$^
Posted on Oct 01, 2010
reyjoshua07
  • 1157 Answers
SOURCE: Getting a F1-4 error code
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Posted on Sep 23, 2011
Error E7 : F1 GMC275PDs07. Microwave works normally but will not heat. Magnetron changed out and still will not heat.
If your microwave is a 220 then reset the breaker by turning it off for 10 seconds and then back on. Then check it. Since you replaced the magnetron, the signal to the mag is interrupted. Did you replace the control panel? If so, then look to see if it is wired back in order. Does the fan operate when you open and close door? If not, then check door switch.
Feb 24, 2013 | Whirlpool GMC275PD Electric Double Oven
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Khhc2090s trouble
The sensor errors are probably just from opening the door and interrupting the sensor cook cycle.
By the way, you should always press "Stop" before opening the door of a running microwave. Otherwise, the door switches will prematurely fail.
I would first check the door switches and their mounts. See this help file.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can also download manuals, installations info, and parts lists here.
dee77f7.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 25, 2011 | KitchenAid Microwave Ovens
I was cleaning my self cleaning whirlpool accubake oven and a F1 and E7 code appeared. I have just bought my house and the prior owner did not leave any manuals. Help please
Most Whirlpool appliance manuals are available from Whirlpool: http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . You will need the model number from the oven. This should be located behind the oven storage drawer on the rim. It will usually be on the left for a range and on the right for a wall oven. On rare models the plaque with the model number will be behind the door. If you add a comment with the model number, I'll try to post a direct link to the manual.
Are you sure about the error code? F1 and E7 aren't in my code books. I have an F7 and E1 code that indicates a short between the door switch or latch switch and the chassis or ground. (For double ovens, there are two of the switches for each door. The code doesn't specify which oven has a bad switch.) The F5 E7 error is a door latch that will not unlock. An F3 E7 error indicates that the warming drawer sensor has shorted out.
For the F3 E7 error, simply replace the sensor. For the other two errors, the solution depends on the door lock state. You start by unplugging the oven and checking all the wires and their connectors. See http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool%20Range%20/%20Stove%20/%20Oven%20Fault%20Codes for the complete set of steps. If the wires/connectors are okay, you probably need to replace one of the door switches if the oven door was locked when the error occurred. If it wasn't locked, then you can check the voltage to the various switches and replace any that are bad. If it isn't a switch, then it is the control that has failed and must be replaced.
I hope this helps.
Jul 02, 2011 | Ovens
Door won't unlock after self cleaning. Code F1 appeared after cleaning was done. The fan continues to run even after oven is cool and door won't unlock
Hello & Welcome to FixYa
Error code F1 is displayed due to electronic oven control failure and the only way to solve this problem is by replacing the control board which is bad. Please get back to me if you have any other questions.
Kevin
Jan 01, 2011 | Maytag Kitchen Ranges
F1...
hello,
what this code mean is an error code indicating that there is a lost of connection on the door or on the control panel meaning that the door is not properly close
thank you and thanks for using fixya.
Jul 09, 2010 | Maytag Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Error Code F1 on oven timer panel
I have the same problem as above. Is there any quicker way to get an answer from tech support. I have no stove or oven right now.
Sep 05, 2008 | Kenmore 46123 Stainless Steel Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
