Question about HP DeskJet F380 All-In-One Printer
Usb device noy recognised
Tried my best including drivers update and finally formated but in vain. no any usb port recognising any device ie: printer , pen drive.
    Problem Solver:
  • 6 Answers
If you know how to use bios, have a look for a setting that enables usb this maybe unchecked, if this solution doesn't work try getting an internal usb card fitted as your onboard ones maybe damaged. Have you tried to installed the motherboard drivers for usb.
Posted on Jan 11, 2009
  • 2,120 Answers
Go into Control Panel and delete all USB references, then reboot.
Computer not recognised the pen drive, lost the usb inserted drive driver is missing in pendrive when i format the pen drive
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Jan 25, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hp pavilion dv1000. All 3 USB ports not recognising any device
go to device manager and from there try updating the usb drive from there
Feb 28, 2008 | HP Pavilion dv1000 Notebook
I get this error message when trying to update my daughters smart pen: 136 InitFunc_NFlashID_Error Format it,use our FAT
I was able to get one of these working that had a dead pen. I reset the pen (insert a pin in the side), and plugged it into a USB port on my computer. I then opened the smartglobe 3 software and it updated the pen. A couple times it failed to format the pen.
I had to switch the pen to another usb port and then it finally formatted and downloaded all of the info to it. It took a looooong time to update. Then it said it was updating the Clock. It then told me to disconnect the pen, but... I was wary of this because most usb devices require some kind of dismounting before you unplug something.
So instead of disconnecting the pen when it said to, I quit the smartglobe software and shut down the computer, without ever unplugging the pen. Once the computer was off I finally unplugged the pen from the usb cable. I turned off the pen and turned it back on. It then worked, (a guy came on and said something)! I think maybe there isn't a way to "eject" the pen properly, so shutting down might (big emphasis on might) allow the usb connection to disconnect successfully without corrupting the flash memory of the pen. Or I just got really lucky. Either way I'm happy! (And not about to update it again I might add).
Aug 31, 2010 | Oregon Scientific Smart Globe Junior
Don't detect usb, malfunctioned, don't recognised
Did you reinstall from the Dell "System Restore" CDs that came with your computer, or from some "generic" XP CD-ROM?
Allow the web-page to "detect" your Dell "asset-key".
You'll be directed to a web-page containing downloadable "drivers" for your computer's USB-ports. Select, download, and Install those drivers.
Sep 15, 2009 | Dell Optiplex GX110 (2909T) Motherboard
Usb device not recognised
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
Hope this helps
Aug 29, 2009 | HP LaserJet 1020 Printer
Gateway Pen Drive .... not recognized on Windows XP
@Enquiry: It's a USB 2.0 pen drive, which might not backwards support USB 1.1 without drivers. Many computers have USB 1.1 out one end of the case (back) and USB 2.0 out another (front).
Nov 22, 2008 | Gateway M275 Tablet PC
I want USB port Driver for detect
No mention of Brand of Pen Drive so I would start there first.
Also no mention of when the latest updates were done ,hmmm
Normally should auto recognise when plugged in
(should do anyway)
When you install usb drive,
and drive does not appear be present,
Assuming your using XP,
go to start
then my computer,
right click,manage,
disk management,
This will put you in the area where you can check the health and activitys of your hard drives,
If this drive was recognised in the port then it will be visable in this area,
here you can right click on the drive and update the individual drivers of each device that may have issues.
So go ahead right click and update the drivers,
click I have disk on the wizard prompt and let the wizard search for the correct drivers,
if it comes back saying please insert cd then let the wizard search the internet for the correct drivers.
If this does not fix the problem then a Factory Default Reinstall will fix this.
If the issue still remains after these steps its the motherboard replacement time.
Jun 27, 2008 | Acer Aspire 3000 Notebook
Usb pen drive does not fnction
Try connecting the pen driver to another usb or another pc to make sure that it's a problem of the usb port of the pc.
May 08, 2008 | Computers & Internet
Umas Astra 5600 connection problem
what computer operating system are you?
Chances are this is a very old DOS scanners for Win 95/8- if your machine is XP/Vista it is not likely to work
Mar 18, 2008 | Office Equipment & Supplies
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
HP DeskJet F380 All-In-One Printer Logo
61 people viewed this question
Ben Johnson
