Question about Maytag MEW6630D Electric Double Oven
Will not unlock after cleaning. Tried turning off power to reset, but no go. Was able to open oven by mechanically moving latch with flexible card, but still unable to resolve problem.
  • Everett Brannberg Jun 07, 2007
    Resolved own problem. Found temperature sensor to be faulty (ohm reading 10x normal).
  • lworley Oct 10, 2008
    We have a blk double oven. Went to clean yesterday started it at 9am, the timer said 3hrs. At 2pm it stopped but, the fan is still running and it is locked. Niether oven will work now. Tried to cut power but, it made no difference. Help! How do I unlock it?
I uplugged my over for 20 minutes and when we plugged it back in the door opened.
Posted on Nov 12, 2007
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
Viking deso175ss ran self clean cycle, tried to stop the cycle early. oven door locked wont reset. tried turning power on/off. was able to get door open by pushing latch to left, however it still will not...
Hello, welcome to FixYa.
I understand you have a Vking oven that is not unlocking after stopping (interupting) a self clean cycle, correct ? (I think the letters in the model should be "DSOE" as opposed to deso, aren't they ?)
Though this can cause issue's with the lock mechanism, it is unlikely anything was damaged...in my opinion of course, thus I don't think you need to start swapping parts.
If this hasn't already been done, I would suggest prepairing your oven as if everything was status quo for a self clean cycle.
Close the door, select self clean and let it go through it's start-up and lock sequence. Your going to stop it again, just as Viking instructs pressing "off" which should allow the lock mechanism to properly lock and then unlock.
During the clean cycle the unit usually has to cool before allowing for the door to open which can take up to 30 minutes, (this is why it counts down from 4 hrs even though the cycle is 3.5 hours) but since it should already be cool I'm hoping the lock will go a full revolution to it's normal position.
Normally these ovens will go through a self check sequence upon a power up (if power was lost and then restored...aka "onboard watchdog") which should include the lock assembly rotating to it's unlock position, but they can get out of sequence at times in my experience.
The other method I've tried and had success with is having a secone person hold the door switch closed while power is turned off and then restored a few minutes later.
Let me know if you have tried that and if not try it and get back to me. Hopefully that will restore it's proper function. Good luck.
Regards,
Macmarkus :)
Sep 07, 2011 | Ovens
How do i reset the locked oven door to unlock it?
I have had that problem once.I turned off the breaker to that oven over night and then in the morning the door opened as it should.I found a GE page that is below.It may help.
http://www.geappliances.com/search/fast/infobase/10000161.htm
Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
May 16, 2011 | GE JTP15 Electric Single Oven
The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
  • If no food or utensils are in oven, put it into a short self-clean cycle (1-2 hours).
  • If there is food in the oven, let the oven cool to room temperature and try to unlatch the door.
  • With electronic ranges there is a small chance that turning the circuit breaker off for a few minutes and turning it back on can release the door. latch to the "off"
  • Note: Do not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
  • Once the oven is cool after a self-clean cycle (approximately 30-90 minutes), slide the latch over to the left.(Some older models have a latch release button that must be pushed in while sliding the latch over.)
Note: Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
If the above suggestions do not work try the following to unlock your door:
  1. Disconnect power to range for 30 seconds.
  2. Reconnect power and see if door will unlatch.
  3. If door does not unlatch, and you do have food in the oven, wait for oven to cool completely and try again. If it still will not open you will need service.
  4. If door does not unlatch, and you do not have food in the oven, set the oven up to clean for 1-2 hours.
  5. Wait approximately 30 minutes and try to unlock the door.
  6. If the door unlocks, the control has reset itself and there should not be any other problems.
  7. If the door will not unlock or if you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
Note: Under no circumstances should you ever force the door or latch open.
May 17, 2010 | GE SCA2001FSS Advantium Electric Single...
LED says "Locked" can't turn on stove. How do you unlock it?
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 16, 2009 | GE Profile JTP18 Electric Single Oven
Self-cleaning oven door won't open
May 15, 2009 | Ovens
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
My self cleaning oven will not unlock
i would try to set fro a clen clycle again, it should try to relock the door and then simply cancel cycle and should reset. or try turning off breaker, upon restoring power it should check the door latch mechinism and unlock
May 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Maytag MEW6630D Electric Double Oven Logo
129 people viewed this question
Top Maytag Ovens Experts
Carmen Mikulic
Marvin
Marvin
Sal De
Are you a Maytag Oven Expert? Answer questions, earn points and help others
