SonySony SVr-HDT500 timer not working
When programmes set to record in advance they don't record
4 Suggested Answers
SOURCE: svr-m935 driver
where can I find software of sims svr-m935 digital recorder?
Posted on Jan 15, 2008
SOURCE: driver for svr-m935 voice recorder
I have the drivers for win xp, but i need the user manual
do u have it in a file?
my email is: dovg@tpg.com.au
i can email you the drivers, please
email me the user manual
thanks
dov.
Posted on Dec 04, 2008
SOURCE: cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Posted on Jan 29, 2009
Need instrution manual. can't figure out how to record, play back and need the manual. please let me know how to get it.
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Sep 12, 2011 | Samsung SVR-S1330 Voice Pen Digital...
VCR Recorder VC-H982 Can't time record. can't select a channel other then 3, 40 av under timer. What is pdc?. where dose it appear. what is sap in set up window? what is air in the channel...
You will probably find a free manual at the Sharp website. That should answer most of your problems. However can tell you that PDC stands for Programme Delivery Control. With it on, say you want to record a program that starts at 9pm and finishes at 10pm. Then all you need is set the control to on, when you set the timer recording, and the video will record your show, even if it starts at say 9.10 and runs while 10.10. The VCR will wait till 9.10 to start and stop at 10.10. Good if a sporting event or live event overruns!
However PDC doesn't work on digital and will not work sometimes at all or if you set the timer wrong. It uses the old teletext signal, which is why if you are in an area that has gone over to digital it should be set to off! As it will never get a PDC signal!!!!
Jun 04, 2011 | Sharp VC-H982U VHS VCR
Record is full. how to clear.
I'm not sure if a global erase is possible, but since you want to erase everything you don't have to worry about making a mistake, right?
I didn't see such feature in any of these little units, so I suspect you'll have to ERASE one file at a time. Your User Manual has the instructions I'm sure.
The operation of erasing is not exactly the same with all makes and models.
In some, you need to press ERASE as the file is playing back, while in others, you just go to the file number and erase it.
In this case I imagine you can go to the first file in each folder and erase away.
Jun 02, 2011 | Samsung SVR-S820 Digital Voice Recorder
I have several Intermatic Model DT7.It very hard to set hours and minute. I press the buttons and nothing hapens and the just start to go up through the numbers and I can't stop it.
I'm not sure what timer you have.
Programmable timers are made so you press-and-hold the button, and then display goes up through the numbers as you describe.
I test timers, and have not seen the fault you describe. 4-6% of timers arrive defective.
However you have several timers that do the same thing.
If you press the button once, then the first number shows, press button again and next number shows.
If your timer is going up through the number with one push of the button then try resetting timer.
I cannot identify your timer to know what the reset steps are.
Also, many timers you push the + button to go up through the numbers, and push the - button to go down through the numbers > try both buttons since one may be made for individual selection and other for acceleration through all numbers.
If timer operates on 120V, perform circuit analyzer test on the circuit to eliminate electrical as source of problem.
If this is a hard-wire timer, carefully review of wiring.
If you find the specific source of problem, add a comment.
Securitron makes DT7 programmable timer
To see image and identify timer:
http://absupply.net/securitron-dt-7-prime-time-digital-timer-6071.aspx
On-line manual shows on page
Intermatic shows DT300 series has been discontinued by Intermatic:
This timer also sold as Woods 59203 and GE 15091
To see image of timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59203
Intermatic shows DT17 timer:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt17c%20-%20english.ashx
DT27
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt27c%20-%20self%20adjusting%20-%20english.ashx
DT121
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
SIMS digital recorder software needed. SVR-51335
My sims svr 130 lose the driver, where looking for the driver?
Feb 23, 2010 | Sims SVR-S1335 Digital Voice Recorder
Unable to find/buy manual for the SVR-s1335
If you are still looking for the manual I can scan a copy of mine and email it to you in a PDF. Let me know by by responding with your email and I will email it to you.
Nov 26, 2008 | Sims SVR-S1335 Digital Voice Recorder
I need a manual for SVR-s1335 recorder
I have a manual that I can scan in and email it to you in a PDF format. Leave me your email and I will send it to you.
Svr-m935 driver
Jan 15, 2008 | Sims SVR-M935 Digital Voice Recorder
 Grubhead
Grubhead
