Question about DCS RGS-305 Professional Gas Kitchen Range
Oven door hinges
My oven door came off on my 30 inch dcs
It wont clip back inn , what do I do?
Can you send me a phone# that I can call to have someone come over and put it back on?
I am located in Brooklyn ny 11214
    Problem Solver:
  • 3 Answers
It is tricky, it takes two people to hold door in place, put hindges into slots then fold downward towards the floor, the hinges will open all the way and it will snap back in.
Posted on May 29, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
How do I put in my oven door?
The door on k.a. / whirlpool - hinge has a tab that locks rhe hinge and prevents the hinge spring from pulling door closed all the wayslightly lifting and continuing to close thw door lifts it off the hinge rest. Some models have set screws that need to be removed some require door disasembly some ge maytag frigidaire dcs wolf viking etc the door simply lifts off. The hinges stay attached to the app.and some have holes at the pivot of the hinge wherea 1/8 inch metal tabs or nails are inserted and door is ifted up and out....
(That is 1/3 of the job 2/3 is puting it back) lol
Mar 09, 2015 | Kenmore 75012 / 75014 Gas Kitchen Range
How do I remove the oven door
Welcome to FixYa.
Most if not all Thermador owners manuals have this outlined in them, however, here you go.
Removing the Oven Door
  • Fully open the oven door.
  • Raise the U-clip over the hook on each of the hinges to the "locked" position (see illustration below). This will prevent the hinge from snapping closed when the door is removed.
  • Grasp the door by the sides toward the back. Raise the front of the door several inches (there will be some spring resistance to overcome because of the hinge being locked). When the front of the door is high enough, you will be able to lift the hinges to clear the indents.
  • Pull the hinges out of the slots in the oven front frame.
To Replace the Oven Door
  • Grasp the sides of the door at the center and insert the ends of the hinges into the slots in the oven front frame as far as they will go (see illustration below).
  • With the door open all the way, lower the two locking clips.
  • Raise the oven door and make sure that it fits evenly with the front sides.
DOOR HINGE WARNING:
**CAUTION** With the door off, never release the levers and try to close the hinges. Without the weight of the door, the powerful springs will snap the hinges closed with great force.
Let me know how you make out or if anything is unclear. Thanks for choosing FixYa.
Good Luck,
Macmarkus :)
Sep 01, 2010 | Thermador SMW272 Electric Double Oven
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Jul 25, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Dcs oven door unhinged
easy to install the door,before to remove check it how exactly the position of the door its a clip typr,or get the manual to see the procedure,open the door,pull open then if u see the hinge we have small lock in the hinge u psh it up the lock then slowly close the door,be care bcoz the hinge is powerfull,if u close the door see the hinge how to remove the door.
tnx gerbee
Jun 23, 2009 | DCS RGS-305 Professional Gas Kitchen Range
Can't put the door back on VIKING oven
should be a clip on each side of the door. hold them in as you slide the door back on.
Jun 07, 2009 | Viking VESO105 Electric Single Oven
Oven door
Hi thanks for the question. lay the door on the floor .the hinge must be locked before it can be installed back in the oven. each hinge has a locking clip . push down on the hinge and lock with clip . same on the other side. install door. push door down. unlock the clips. close door. to remove door. push door down. lock clips . pull oven door out . thanks the appliance doc
Aug 05, 2008 | Frigidaire FEF366 Electric Kitchen Range
DCS RGS-305 Professional Gas Kitchen Range Logo
584 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
