Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Eureka the boss 5893A brush roller will not work
I have used the reset button and also checked the belt which is working but the brush roller will not move. I just got the vacuum and the brush roller was working and then suddenly stopped. What else can I do?
  • 281 Answers
Is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Posted on Apr 23, 2009
2 Suggested Answers
galati2k
  • 281 Answers
SOURCE: Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
Eureka Boss Capture 8803AVZ Bagless Upright Vacuum smells like it is burning
First you need to checkl and make sure the roller brush is not jammed up and the belts is not slipping due to the brush not turning
Apr 30, 2011 | Eureka Boss Capture 8803AVZ Bagless...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
My boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
May 01, 2010 | Eureka 5856BVZ Boss Bagless Upright...
Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Jan 24, 2010 | Vacuums
4870 roller part number
I know the belt number
Eureka Part Number: 61110B (Replaces 61110, 61110A)
And the roller i think: Genuine Eureka Brush roller part number 61250-3 for Eureka The Boss/Smart vac/smartvac ultra 4800 series vacuums including models 4870 and 4880
Hope this helps you.
Jan 03, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
In Carpet setting, the vacuum brush does not spin
I put 3 turns of electrical tape around the area of the beater bar that meets the vacuum belt. This solved the problem short of replacing the beater bar.
Jan 18, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
482 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
