Question about Pyle PLMRA420 Car Audio Amplifier
Newly Installed Car CD Player won't power up
I installed a new cd player for my car by myself, but it won't power on. The only thing that seems to work is a little flashing red anti-theft light. Does this indicate that the wiring is ok? I checked all the connections to make sure they were tight and that each wire was connected to the right one and all looked good. I also changed the fuses in the fuse box, but that didn't seem to make any difference either. I'm getting pretty frustrated, because I really don't know what else to do! Please help! Thanks so much!
  • 1 more comment
  • Timeless T Apr 18, 2008
    I installed a new cd player, but ir won't power up. My light tester shows that I'm getting power through my red wire, but nothing through my yellow wire. What other way can I get power to the yellow wire? I have good ground, but head unit will not power on.... I am very frustrated because I've installed a radio on numerous occassions and never had this problem before. I've been on the internet all day trying to find help, could it be the type of factory system I used to have? Somebody please help!
  • jam-cha Jul 18, 2008
  • kris -barlow Aug 07, 2008
    i have justed conneted my cd player up and it was workin fine then i pluged somethings intothe cigarette lighter and the cd player and cigarette both cut out ... what do you u think is wrong please help me
  • 156 Answers
When you see this problem, it usually means you have power on your deck's constant power wire (usually yellow) but no power on the accessory power wire (usually red). The accessory power wire is the one that sends voltage to the deck when the key is turned on. Usually this means that the red wire is either connected to the wrong vehicle wire, or that the vehicle's radio fuse is blown. As a last resort, you can disconnect the red wire from whatever it's connected to, and re-attach it to the same connection as your yellow wire. This should allow the radio to power up, but it won't turn on and off with the key-switch; you'd have to remember to turn it off or remove the face when you leave the vehicle, or you may drain the battery. Alternately, you can extend the red wire to a different source of key-switched voltage. Depending on the vehicle, you may be able to find this behind the cigarette lighter, at the key switch itself, or at the fuse box.
Posted on Jun 07, 2007
MY CD PLAYER WAS WORKING FINE FOR SIX MONTHS NOW IT WONT EVEN POWER UP I UN HOOKED IT N HOOD IT BACK UP AGAIN IT WORKED INTEL I TURNED MY CAR OFF WHEN I TURNED MY CAR BACK ON IT HAD NO POWER AGAIN
Posted on Sep 11, 2010
Thank you so much for this information - - it helped me took 5 mins and i cant find anything else about this problem!! thanks!!!
Posted on Jun 28, 2007
2 Suggested Answers
SOURCE: No Power
make sure you have power at the end of the harness which connects to the deck. also insure that you have the 12v constant and 12v interupited hooked up correctly. this is usually the problem when the deck reconizes power but not to power it. also make sure you have the key on acc.  becasue this is one way to connect the 12v interupted.
Posted on Sep 22, 2008
Security light on and won,t turn over engine to start . rolled car on to the roof on black ice. physically car looks ok
Car Won't Start Because of Anti-Theft System ... - RepairPal
repairpal.com > Problems > Oldsmobile > 88
Car Won't Start and Security Light is On on Oldsmobile 88 ... key turns over enginebut fails to start some times..security system keeps the fuel injectors from ...
repairpal.com > Problems > Buick > LeSabre
Car Won't Start and Security Light is On on Buick LeSabre. Problems with the ... 1998 Buick LeSabreVisitor. Turn key on every thing come on but won't turn over.
repairpal.com > Problems > Pontiac > Bonneville
Replaced trans, engine, PCM and bcm, now starter diabled- theft flashes on service ...1995 Bonneville car turns over but wont fire an security light is flashing car ...
GM Passlock Security Light Issues - RepairPal
Dec 26, 2015 | Cars & Trucks
2000 dodge stratus will crank but don't stay running dies after 3-7 seconds there is fuel going to line also put new fuel filter in no luck.There also is a red blimking light continuously in instrumen
you say you have fuel going to the line but not what the fuel pressure or volume is. if you have an anti-theft on the car it may have activated not allowing the car to run which could be causing the red flashing light.
Sep 04, 2014 | 2000 Dodge Stratus
1986 Thunderbird, cd player keeps cutting off. Is this power problem?
No that sounds like the player is just old and most likely needs the tiny drive belts replaced.
Apr 04, 2017 | 1986 Ford Thunderbird
Installed new cd player and it wont power on
this happened to me in one of my cars, I bet that if you put the factory radio back in it will work just fine, most of the radios components, are part of systems wiring and used to send signals to ecm to let car start
Oct 07, 2012 | 1999 Chrysler Concorde
Anti theft failsafe,red light flashes truck won't
You need the system scanned for faults, the dealer is really just about the only one that has the expertise to fix the system.
Sep 14, 2012 | Cars & Trucks
Anti-theft goes off on 93 nissan 300zx
youv've engaged the anti-theft circuit it will need reset at a dealer
Sep 04, 2012 | 1989 Nissan 300ZX
Have a 1996 Toyota Camery. Installed a KDG140 JVC stereo/CD player but the stereo won't work. CD player works great.
If "stereo won't work" refers to you not being able to get radio stations; try your antenna connection behind the radio. The vehicle may also have a power antenna connection(blue wire at the stereo).
Jul 28, 2011 | Car Audio & Video
Car will not start- will crank- anti-theft light flashes - turn switch to on for 10 min. when light stops flashing - turn switch to off - then it will start. Changed to a new switch - worked or started for...
try a diffrent key,your extra one.Could be the micro-chip inside is not comunication with anti-theft-.This happened to me.I used the spare set for a few days .then the other key started working again
Jun 28, 2011 | 2004 Chevrolet Malibu
Hi! i just installed myself a new Dual Cd Player Xd 1222 on my ford focus 2002 4 door. The problem is when i start my car.. The dual reset every information like the bass and treble and all of the stuff....
This just means that you do not have your remote or memory cable connected to the correct power source. You need to connect this cable to a power source that continously runs. Underneath the driver side should be a fuse box. Connect the remote/memory cable to a fuse that runs, like maybe the old radio fuse. A schematic of the wiring for your vehicle would help you out a lot. This will show you the best source to connect the cable.
May 18, 2010 | Car Audio & Video
Pyle PLMRA420 Car Audio Amplifier Logo
5,064 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
