Question about Ilford HP-5 Plus 35mm Film Camera
My fujifilm E550 fine pix has sand in it
I havent been able to use it since. can this be fixed
    Brigadier General:
  • 3,006 Answers
Possibly. But not at all cost effectively unless you try to do it yourself; the E550 was released nearly five years ago at around US$400 but good used ones are now worth less than US$50 and a professional repair will cost far more.
As your camera is effectively a write off you have nothing to lose by trying the repair yourself. You'll need a set of precision screwdrivers, an anti-static workmat or wrist strap, cotton wool buds and a set of small, artists paintbrushes would be useful and a bit of ingenuity and patience.
Start by holding the camera pointing slightly downwards and turn it on. With the lens extended try to remove every grain of sand you can using the brushes and maybe by sliding a piece of sticky tape into any gaps so that loose sand sticks to it and can be removed. When you've got all you can out, tap the camera gently and remove any more sand which appears and do the same again after turning the camera upside down. Repeat the same process for the battery and memory card chambers. When you're certain you can get no more out of the camera, remove any panels which you can. You may find some hidden screws inside the battery/memory card chambers and possibly beneath stick on trim. First remove any sand stuck to the inside faces of the panels and then shake out any inside the camera. If you see any grease/oil with sand stuck to it then remove the grease/oil with a cotton bud and make a note to replace it with fresh lubricant on reassembly. Basically, delve as deep as you dare to remove all that you can.
If you're lucky, you'll have a camera which has the vast majority of the sand removed and any remaining sand will be in non-functional places. If you're unlucky then you'll be looking for another camera, but you'll have gained valuable experience for the next time you have to dismantle and repair similar devices.
Posted on Jul 04, 2009
I plugged the wrong cord it in to the ac plug and now it only works when it is pluged im to the wall. if i can fix it how please anwser soon.
I think you fried the internal charging circuit and or the battery. You may have to replace it or try for repair shop.
May 17, 2017 | FUJIFILM Cameras
My fujifilm fine pix s5000 digital camera is having some problems. When I turn it on the screen is white but I can see icons. I'm not sure if it's related to the camera or if I just need a new card?
the video from the ccd is not making it to the lcd
does it shoot pictures if so then you have a good point n shoot blind camera
its not worth fixing .
May 09, 2015 | FUJIFILM Cameras
Fujifilm Fine Pix 80 EXA
Salt water may have caused some components to short out.
It would not be worth repairing and it would not be a DIY repair.
Sep 18, 2012 | Fuji Cameras
Fujifilm fine pix f20
There is software you can purchase in an attempt to retrieve your photo's go to www.ebay.com Type: picture recovery a list of sellers will pop up to give choices, also check www.download.com and type same notation.
Apr 22, 2012 | Fuji FinePix F20 Digital Camera
I was recently given the FinePix E550 by someone who had purchased a newer camera. I do not have the usb cord to download pix and my Dell 942 All-in-One will not recognize the camera card. What do I need...
Hi
The problem you are experiencing with your Fuji FinePix E550 could be down to a number of reasons.
You do not say the memory card size you are using but the Dell 942 will probably only read cards xD-Picture Cards 1Gb or lower.
It maybe a better idea to remove the xD card from the camera and use a USB card reader to take the images off the card. Alternatively you could buy a replacement USB cable
Hope the suggestions help.
David
Dec 29, 2010 | Fuji FinePix E550 Digital Camera
Fuji fiinepix S1500 display says ZOOM ERROR
Due to the tight tolerances inside the lense mechanism - small bits of sand or lint may become trapped in the mechanics.
It is advised to take the camera to a camera repair shop and have it disassembled and cleaned.
There are many small parts and intricacies that will render it totally useless if not done properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 28, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
Fine Pix software installation cd
Just go to the FujiFilm website. All the downloads are available there. Download and install.
Jul 22, 2009 | Cameras
Need printout of manual for Fuji FINEPIX S800 digital camera
You can download one from http://www.fujifilm.com/support/digital_cameras/manuals/ and print it out yourself.
Jun 11, 2009 | Pix FUJIFILM Fine S1500fd Digital Camera
Menu button and Zoom buttons not working
Yes im having the same problem ,however i open/disassembled my camera and my results was a broken ribbon connector from the Rear Button Board to the Main circuit board.....
The only problem is i can not find any parts list information or where i can get this part....
can any one help me with this??
FUJIFILM F460 Camera
REAR BUTTON CIRCUIT BOARD
Rear Button Assembly
Thanks
Wooker
NOKTURNAL CAR CLUB
BALDWIN PARK, CALIFORNIA
Jan 14, 2007 | Fuji FinePix F460 Digital Camera
Ilford HP-5 Plus 35mm Film Camera Logo
120 people viewed this question
Top Ilford Cameras Experts
Are you an Ilford Camera Expert? Answer questions, earn points and help others
