Channel seach I can`t figure out how to channel-seach on this old TV. I`m in Denmark and the TV is set on DR1, which is one of the major stations here. However, I would like to connect to my satelite-dish. Can you help,please? Best regards, Per Lippert Solb?rmarken 24 8641 Sorring Denmark
  • perulla Jan 11, 2009
    There is no menu-botton on the TV or on the remote! But thanks for
    trying!
  • 57 Answers
If your tv is rotary or digital.if rotary you search manually the channel .first set the channel you want then press and hold the fine tuning manually counter clockwise to get some good reception.second the digital tv you may press the menu and choose the auto search ,then wait until searching will be finish.
Posted on Jan 11, 2009
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Set stations
A channel scan is a vital part of utilizing your cable TV service. When a coaxial cable is connected to a TV, sometimes it will not display any channels until you configure the TV for your specific cable connection and scan for available channels. A channel scan can be applied to basically any type of TV or TV/VCR combo, even if you are missing its remote control.
Read more : http://www.ehow.com/how_6875646_do-old-tv_vcr-tv-remote_.html
Instructions
    • 1 Bring up the TV's menu. Look for a button on the front panel of your TV/VCR labeled "menu" or "setup." Press it and you should see a menu appear on the screen. Part of the menu should inform you what buttons you can use to navigate through the menu. If not, try using the volume buttons or channel buttons on the front of the TV and see if pressing those allows you to navigate through the menu.
    • 2 Specify channel scan settings. Once you are able to navigate through the TV's menu, look for the "channel scan" "auto-program," or "auto-tune" option. This may be inside one of the TV's sub-menus such as "setup," "channel setup," or the like. The key of this step is to specify your cable settings before running your channel scan. The "tuner mode" option needs to be set to "cable" rather than "air" or "antenna." You may have to specify what cable type to use, this will be set to "std" or "standard" for the vast majority of cable providers. If you are not certain what cable type you use at home, contact the technical support department of your cable provider.
    • 3 Run a channel scan. Once the scan settings have been set properly, run the scan (usually done by pressing a "start," "scan" or "begin" button.) When the scan is complete, check to see if you are getting all of your channels. Contact your cable provider if you are not sure how many channels you are supposed to be getting.
good luck
Jan 08, 2015 | Televison & Video
Tv stays on one channel,no color or picture just ghost or outline, i have a Sharp lc46sb 54u
Check the settings to see if it is locked on channel 3 for external tuner source to have an input from a cable box ant in that needs 3 to function or from some other externally decoded signal like a vcr. Does the TV have a Digital tuner or the old analog tuner? If it's digital you can hook up a rabbit ear antenna with the UHF output on it & should be able to tune in some stations. If it's the old style then you will need a converter box to get it to receive any stations.
Fist check the settings to see if it has it set to lock on channel 3 for external tuner source.
Apr 03, 2013 | Sharp Aquos Televison & Video
Just bought tv and can't figure out how to run channel auto scan??? we did do it but where is this button to fininsh the process???Having major problems programming the tv
the programming should be automatic...it will seek the channels and put the active stations into memory.
when it is done searching it will come back to a channel...this can take up to 30 to do because there are several TV broadcast bands it has to look through now.
as a last resort, unplug it (power) wait a few seconds , then plug it back in and start all over (reboot)
Apr 12, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Digital channel numbers are different
The channels for a digital stations are really just "names". Thy will be the number for the old analog channel followed by a "-" and a number 1 through 4. The actually frequency can vary
from the old frequency. You can see this at;
http://www.tvfool.com/
To set up your tv, you will have to connect your signal source (Antenna or Cable) to the set.
Go into the menu and select the Signal source (Channel) to match what you connected.
Go into the menu for scan or auto program and SCAN in the channels in your area.
Now you can watch the stations on your set.
If the broadcast frequency of any station change, you can re-scan it in again. The "name" will not change so the change will be invisible to you.
Feb 25, 2009 | Vizio L32 32 in. LCD HDTV
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Old TV can't scan for cable channels
it depends on how old the set is. some of the older sets would only go as hi as channel 120. some really old sets only went to 36 on cable. how high do the numbers go?
Jan 05, 2009 | Televison & Video
Can't get cable stations
you have to go into the menu and set for cable then scan for active stations.
Mar 15, 2008 | Televison & Video
Channel selection
What you need to do is take the remote, go into the menu, find channel scan and do a channel scan to find all the available stations available on this system. Make sure the TV set is in the cable mode and not antenna mode or you wont get any stations above channel 13.
Sep 18, 2006 | RCA F27628 27" TV
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
