Synaptics touchpad v7.5 not working
Driver is up-to-date with ver.15.3.39.0 only the usb wireless mouse is working
SOURCE: Toshiba Satellite Pro L10 - Touchpad and USB mouse not working
I need help with my Touchpad I was able to use it to click with my finger and I have pressed a button somewhere that will not alow me to do that any more I have looked in control panel and ex. to find something to that effect but I am having no luck can you help?
Thanks
Rochelle
Posted on Aug 11, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Posted on Aug 28, 2008
  • 461 Answers
SOURCE: Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Posted on Dec 12, 2008
SOURCE: Touchpad Not Working
those laptops have a button just over the touchpad if the light in it is orange/redish its of if its blue its turned on if the touch pad doesent work while its a blue ligt it may be some thing wrong with it.
Posted on Jan 02, 2009
solutionzone
  • 86 Answers
SOURCE: Travelmate 4200 touchpad mouse doesn't work.
go to the computer hardware point or servicestation.
Posted on Mar 06, 2009
Touchpad not active
Press the "Fn" and "F9" keys simultaneously.
Test your touchpad. If it works, it was simply disabled. Press the same key combination any time you want to toggle your touchpad on or off.
Plug an external mouse into a USB port on your laptopicon1.png if the key combination didn't work. Follow onscreen prompts to install the mouse driver--if necessary. You can also move the cursor using the "Tab" key and the arrow keys, as well as click by pressing "Enter" until the mouse is operational.
Click the link in the Resources section if you are using a Toshibaicon1.png Satellite with Windows Vista. Follow the onscreen prompts to download and re-install the driver.
Open a web browser and navigate to Synaptics.com if you have a different Toshiba model or operating system. Synaptics brand touchpads are used in all Toshiba laptops, and this site provides a generic driver.Hover your mouse over "Support" on the top menu, then select "Drivers" from the drop-down menu.
Select your operating system from the list provided and download the generic driver
Follow the onscreen prompts to install your new driver, and then test the touchpad again. If it still does not work, take your laptop to a licensed repair technician.
Jan 06, 2014 | Toshiba SATELLITE 1905-S301 TOUCHPAD AND...
Turn off touchpad
If it is an Synaptics touchpad (most common), you can disable it by right clicking on the taskbar icon
You can try updating your driver as well to get these options:
http://www.synaptics.com/resources/drivers
Oct 16, 2013 | Samsung NC10-14GW Notebook
There's a tiny orange light near the upper left corner of the touchpad to the left of the touchpad. If that is lit, you may only have to tap the upper left hand corner of the touchpad a couple of times to get it to go out. and start the touchpad working.
Barring that, see if the synaptics driver is installed. Go to "Control Panel," change the "view" in the upper right hand corner to "large icons," and see if "Synaptics Touchpad V8.1" is listed.
If not, go to "Control Panel," locate device manager and click (with a usb mouse) "mice and other pointing devices," click "Synaptics PS/2 Port Touchpad," and check to see if it says, "device is working properly." If not or if it still doesn't work, click the driver tab, and click "update driver."
Dec 08, 2012 | HP elitebook 8760w
My acer aspire 4339 synaptics touchpad isn't working
try to enroll to earler system settings windows - start - control panel - recovery, if not help, try to check touchpad connection
Nov 11, 2012 | Computers & Internet
Compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
May 21, 2010 | Compaq Presario CQ60-212US Notebook
Mousepad not working
Each Touchbad should have basic functionality by default in every Operating system, letting it be used even when no driver is installed. However, try pressing FN and F7 together and see if the touchpad works again. Some people accidently press this FN + F7 key when they mute the sound with the FN + F8 key.
The FN + F7 is there to disable/enable the touchpad as some people use a USB mouse instead of the touchpad.
If you still need the drivers, here are the download links. Please choose desired driver by Operating system and Touchpad brand...
Acer Windows XP TP Drivers Synaptics
Acer Windows XP TP Drivers ALPS
Acer Windows 7 TP Drivers Synaptics
Acer Windows 7 TP Drivers ALPS
Acer Windows Vista TP Drivers Synaptics
May 18, 2010 | Acer Aspire One PC Notebook
My acer aspire touchpad frozes
right click My Computer >> Manage >> Device Manager.
See if the drivers are installed
May 22, 2009 | Acer Aspire One PC Notebook
Turning Of The Touchpad
Solution:
To disable the Touchpad the Synaptics driver is necessary.
Please follow the steps below to disable the Touchpad:
After installing the Synaptics driver click on "Start -> system control -> mouse"
You´ll find the additional register card "Settings".
Mark the Touchpad and click on "Disable".
Now the USB mouse can be connected and the Touchpad remains deactivated.
Some Amilos don´t have a PS/2 port, therefore only a USB mouse can be used.
Nov 03, 2007 | Fujitsu Siemens AMILO D-7830 Notebook
Computers & Internet Logo
345 people viewed this question
David Payne
David Payne
