Question about Garden
While using snow blower notice ariens snow blower leaking oil
Area is coming from the rear of engine wondering if its a seal or something else. machines starts but doesnot have much power.while using the machine i noticed it wasn't throwing light snow very far
4 Suggested Answers
  • 474 Answers
SOURCE: have just bought a used ariens st1032. have no
that should do on both counts. be sure not to over fill the oil
Posted on Oct 24, 2009
  • 10865 Answers
SOURCE: Just wondering if my ariens st350 snow machine
Hello. Actually, Many snow thrower manufacturers now recommend using synthetic motor oil particularly for subzero temperatures. Synthetic oil, such as Mobil 1 doesn’t contain any of the waxes that cause conventional oils to congeal in cold temperatures. As a result, synthetic oil makes starting easier and also prevent parts from running dry when a cold engine first starts. Synthetic oil also has higher film strength and stands up to high temperatures better than conventional oils. You’ll pay more for a quart for a full synthetic and you still have to change it as often as conventional oils, but you are giving your snow thrower engine the best chance for a long trouble free life.
Posted on Dec 24, 2009
  • 509 Answers
SOURCE: Only one blade turns automatically on Ariens snow blower.
There is a bolt that goes through the center of the shaft that shears off if you hit something. You will need to line up the holes of the internal shaft with the auger tube and install a new bolt.
Posted on Feb 11, 2010
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Noticed a small mount of red lube on the garage floor under the auger
Well, I'm not sure about snow blowers, as I've never owned one, but every other time I've seen red fluid leaking out of a machine it was transmission fluid (which is red by the way) or similar lubes. Check the fluid level with the dipstick, if it's low then top it up and check again later to see if that's the problem. If I had to make a guess, I'd say that a drive gear or similar seal has a small leak. If that's the case you could get a new seal pretty easy, putting it in may or may not be tricky, or, just top it up before you use it like I do with my wood splitter. Hope I helped, Grimm
Mar 16, 2015 | Ariens 72601400 - Snow Blower Cover, For...
Ariens 921013 has difficulty changing speed under traction. The lever wants to pull forward when I disengage it from the holding slot on the dashboard and will not let me reduce speed without disengag
It might be time to lube the shaft the bearing slides on that changes speed. If you pull the rear cover off it should be easy to spot. Some people use oil others use a little grease. I like synthetic grease as it won't drip. If you use oil remember to wipe up any excess and you don't want it getting on the flat plate the friction disc rides on or you won't have any traction at all.
Sep 13, 2014 | Ariens 921013 - Snow Blower, 120V, 30in
How do you put it in neutral
Does it have steering control triggers to turn it left or right...if so hold both at the same time with engine off and see if you can push it..Let me know if that works. Or let me know what kind of controls you have
May 13, 2014 | Rotary Snow Blower Parts Replaces Ariens...
I bought an Ariens, model #921031 Deluxe 24 with a Briggs & Stratton engine brand new online and haven't used it yet. It's been sitting and now I have a puddle of oil under it. The place t
Some times, the seals not sealed yet not being run. Check all your oil and gear oil levels and run it. Hope everything will be ok then.
Feb 10, 2012 | Briggs & Stratton Garden
Van used 2.5 quarts of oil in 1200miles no sign of oil burning or blue smoke at tail pipe. oil light comes on frequently 2004 dodge caravan
If there is no sign of oil consumption, then you have a leak some where. Un-noticed leaks are usually found at the rear main seal and leak as you are driving. If you crawl under the vehicle and closely inspect the area where the engine block meets the transmission you may find evidence of an oil leak.
Apr 25, 2011 | Dodge Caravan Cars & Trucks
Feb 09, 2010 | Ariens 34 In. Zoom Series Riding Mower
Mtd snow blower,8hp 2 stage, 1995, Problem: oil leaking on axles, and on casing wear axle come out.wheel stop turning , no gear selection. could you direct me ???
The oil leak normaly would make the 'friction disc' inside the frame slip so as to not drive the axle.
Locate the oil leak
#1 engine crankshaft seal
#2 engine crankcase cover gasket
#3 engine overfull so that the excess oil is coming out of the crankcase breather tube and running down inside the frame
Dec 22, 2009 | Mtd Garden
Have just bought a used ariens st1032. have no manual and wondering if unleaded gas and 10w - 40 oil will work on this machine?
assume it's 4-cycle engine. regular gas, and 10w-40 should be safe- might want to use single weight 30w oil. you won't need multi-weight if you're living in a cold climate- won't be using it in the snow! check oil level, and top-up when needed!
good luck!
Oct 24, 2009 | Ariens 34 In. Zoom Series Riding Mower
2006 Saturn Vue AWD loses oil fast
First I'd find a different shop. $100 to look at it? I don't think so. Sounds like this may be a transmission issue.
Jun 21, 2009 | 1999 Saturn SL
Garden Logo
277 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
