Question about Dell E176FPC 17" TFT LCD Flat Panel Monitor
Monitor not displaying
Monitor problems
    Guru:
  • Dell Master
  • 829 Answers
Our video driver probably was updated. You can try rebooting the PC hitting F8 and going to "Last Known Good Configuration" You can also try running a system restore to rollback to before you were having the issue. Finally you can reboot hit F8 boot into safe mode, go to control panel and system, go into the device manager double-click on the video card driver and roll it back to the previous version.
I do not think it is the monitor's connection since you would have not initially seen the Window's splash screen.
Posted on Jan 11, 2009
  • Milind Shetti
    Milind Shetti Jan 11, 2009
    our video driver probably was updated. You can try rebooting the PC
Display not working but system functioning
tried with other monitor just to ensure if the problem is only with in the monitor. if the same problem, the cause it could be the inverter board for screen back light which has component being shorted.
Aug 15, 2012 | Samsung SyncMaster 713N 17" LCD Monitor
Th problem is lcd
No display on laptop's internal monitor, and there is no blinking cursor?
Start with seeing if it is a display problem.
Connect a VGA monitor to the laptop. If the display does not show on the external VGA monitor, the problem is the graphics chipset.
You did not state the model number of the Fujitsu laptop, therefore all I can give is generic basic information.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
This is an example of a VGA Cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector (Port) on your laptop is either on the side, or back of the laptop. May be marked on laptop as RGB.
You can use a CRT type of VGA monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
If not there are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and at the same time tap once on the Display Toggle-Over key.
The Display Toggle-Over key is one of the F keys at the top of your keyboard. F1 through F12.
It will have a monitor symbol on it.
(For example most HP laptops use the F4 key )
No display on external VGA monitor? Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
If no display shows on the external VGA monitor you have a bad graphics chipset. Motherboard replacement.
If a display does show on the external VGA monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
Post back with the results, after using an external VGA monitor, in a Comment.
Regards,
joecoolvette
Apr 25, 2012 | Fujitsu Siemens Computers & Internet
I have prolem in samsung LED that no display shown when i turn on....can you please advice. thanks....Peter
send me detail on jogindersingh47@yahoo.com 1) if yours LED power on and display of window not giving then problem from cpu. a. first replace yours RAM and check display. b. then display cable and check display. c. Install new Display card and check display, if not giving display it means motherboard have a problem 2) LED not giving power on then problem from monitor a. replace monitor power cable and check display b. monitor logic card have aproblem
Mar 16, 2011 | MPC Computers AOC 7F 17" CRT Monitor
I have an LG 17"
First thing to do is determine whether the problem is the monitor or the PC.
Do you have another PC you could try the monitor on, or perhaps a friend will lend you a monitor for an hour or two?
Obviously if the display is ok on another monitor, then the problem is your monitor, however if the display is still "too big" then the problem is the PC.
By the way, when you say the display is "too large" what EXACTLY do you mean?
Dec 13, 2010 | LG Flatron L1715S 17" LCD Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
No display on AOC 17" CRT Monitor
My AOC 17" flat monitor (model number P7S80) is not displaying properly. Only 80% of monitor is displaying and the edges at the bottom are tapered of. If somebody is having a solution please post it.
Sep 07, 2009 | AOC CT720G 17" CRT Monitor
HCL LCD Monitor display problem
NO Bad Capacitors on the power board i have some problem in my HCL lcd monitor, my monitor display is on but at a time the display is gone. when i swicth off and on monitor power the monitor display is on ofter 2 sec the display is gone so that is the problem.
Jul 05, 2009 | ViewSonic VA702b 17" LCD Monitor
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Dell E176FPC 17" TFT LCD Flat Panel Monitor Logo
194 people viewed this question
Alun Cox
