Question about Janome Sewing Machines
Janome feed dogs on MC 6600P won't come back up
SOURCE: Quilting on Janome MC 4000
I have a MC4000 and a manual. To raise or drop the feed dog, remove the accessory box and feel at the back of the free arm there is a lever that will slide left or right to raise or lower the feed dog. I am not a quilter, but the manual says to use foot A (zigzag foot) and accessory L (quilter) which appears to be a guide. Cheers, Deb, Townsville, Australia
Posted on Nov 03, 2008
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
  • 6 Answers
SOURCE: Feed Dogs on Janome 1600P
I recently purchased a Janome 1600P-DB and in order to do free motion quilting I had to cover the feed dogs with an index card. I also cut a small section out of the card to allow for the thread and needle to move freely. Standard tape was used.
Posted on Oct 21, 2009
  • 55 Answers
SOURCE: Feed Dogs won't come back up!
Have you tried sewing with the machine after setting feed dogs to up position. You may already realise but it takes a full revolution of the machine to engage and raise the feed dogs after setting the feed lift control to up (the feed dods will drop as soon as you adjust the feed lift control but will not raise until a full revolution of the stitching mechanism).
If you have already tried this unsuccessfully try removing the cover below the feed dogs and spray lubricant on the feed linkages and try freeing them.
Posted on Nov 04, 2009
SOURCE: I have a janome 1600p. how do i drop the feed dog
there is a little metal plate that fits over the feed dogs, this is what I am using
Posted on Dec 26, 2009
Dropped feed dogs on 6600p machine but will only stitch straight when have dual feed on
If the feed dogs are down, it can't do other patterns. It uses the bottom feed dogs to move the fabric with the needle bar.
Mar 03, 2015 | Sewing Machines
I have a Janome 900 MC and I am trying to embroider a label and can't get the carriage to move, it just sits there in one place. I have tried lowering the feed dog and was told to raise it back. I have...
when the feed dogs are in the down postion the machine stay in one place
when the feed dogs are in the up positon then the machine will sew
if the machine still doesn't sew when the feed dogs are in the up position the feed dogs need to be checked to see if they need a adjustment or need to be replaced
Oct 14, 2013 | Janome Memory Craft 9000 Computerized...
Thread dog lever jammed: Janome MC 6600
it's possible that the feed dog lever has come loose or broken
it would be a good idea to have the machine checked
Jun 12, 2012 | Janome Sewing Machines
Feed dogs won't raise and lower on my memory craft 9500, how can I fix this problem?
when your machine on your machine movable arm pushing a switch liver which will raise your feed dogs you can do one thing when your arm moves to the normal possision just given your finger to the upside movable are you see one long switch bar is there just push and see machine feed dogs will come out actualy that action to be done by arm only,you call one MC expart to resoved your problem permenetly.
Apr 21, 2012 | Janome Memory Craft 9500 Computerized...
Where do I find the fuse location on the Janome MC 6600P?
The fuse is on the inside side of the inner circuit board behind the front panel. There are 2 fuses, top is 3.15 amp and the botom 2.5 amp
Feb 13, 2012 | Janome Memory Craft 5700
My Janome Harmony 1017 won't sew all the zigzag stitches. Stitches 5,7 and 8 bog down after just two or three stitches because the fabric isn't moving through the machine. Any suggestions?
when the fabric does not move then the feed dogs under the needle plate need to be checked to see if there up or down.
if the feed dogs are down then the lever or switch needs to be pushed up into the correct position
if the feed dogs are up & they are not moving the fabric like there suppose to, cause it's there job to move the fabric against the presser foot,, then they need to be check
the gears that do the zig zag stitches should be checked to make sure there not worn & weather they might need be be greased
Aug 29, 2011 | Janome Harmony 1017 Sewing Machine
My feed dods have droped down how can we ajust them to raise them.
Usually when you slide the knob to drop the feed dogs they drop immediately. But when you switch the knob back to raise the feed dogs, they won't come up until you rotate the handwheel one revolution in the forward direction.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
I've forgotten how to drop the feed dogs-can you help
There is a little lever on the back of the free arm at the bottom. Push the lever to the right and that will lower the feed dog.
Jan 26, 2011 | Janome Memory Craft 3000
good luck!
Feb 08, 2009 | Janome Memory Craft 4800QD
Aug 16, 2008 | Janome Memory Craft 4000 Sewing Machine
Sewing Machines Logo
123 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
