Question about Sentry Fireproof Safe
How to open Sentry X041e Security Safe - Sentry Fireproof Safe
    Top Expert:
  • Sentry Master
  • 14,162 Answers
Posted on Apr 25, 2016
SOURCE: NEED TO OPEN A SENTRY SAFE BUT DON'T KNOW WHICH
Locksmiths advise If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking sentry safe open.
Posted on Aug 09, 2010
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Posted on Mar 15, 2010
SOURCE: Sentry S3807 safe-cannot open
locksmiths agree on how to install sentury safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe?
to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
Tip
I have lost my sentry safe key or combo
<span>Hi.<br /> <br />Sentry respects strong security standards. There is no simple way of hacking a safe if you loose the combo. If there was a simple way of opening a Sentry safe, Sentry would withdraw the model from the market.<br /> <br />When you own a Sentry safe you are supposed to register the combination in Sentry website. The combination will be held as encrypted data in Sentry server. After registration you get an user name and password that will allow recovering the combination.<br /> <br /></span><span>If you have already <a href="https://www.sentrysafe.com/CustomerCare/Store_Combination">registered</a> and need your combination now, <a href="https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination">you can recover your combination clicking here</a>.</span><br /><span><br />Most owners are not aware and do not register the combination.<br /> <br />If you have not registered the combination, then for security reasons you will be asked to send Sentry request your combination from the Customer Care team. The request must be accompained by a notarized letter stating you are the owner of the safe (form must be downloaded from website). The document can be obtained from any local Notary Public office.<br />You will also be required to pay Sentry $20, that is what Sentry will pay to verify with double check your identity.<br /> <br /></span><span><a href="https://www.sentrysafe.com/CustomerCare/Lost_Your_Combination#">Page is the same published before, at the bottom the button to open Notary public form template.</a></span><br /><span><br />I know that the procedure is annoying, but that is the only way to get a lost combo. Sentry care to protect owners property and safety and security concerns impose use of this procedure.<br /> <br />Other useful links:<br /> <br /></span><span><a href="https://www.sentrysafe.com/ContactUs/Call_Or_Email_Us">Call or Email Sentry</a></span><br /><span><br />International websites:<br /> <br /></span><span><ul><li><a href="http://www.sentrysafe.co.uk/">United Kingdom</a></li><li><a href="http://www.sentryjp.com/">Japan</a></li></ul></span><span><br />Here US customer care number: 800-828-1438.<br /><br />Ginko.<br /></span>
on Nov 11, 2010 | Sentry Fireproof Safe
How do I open sentry H4100 file safe
Proceed to watch this video link that I added. It will guide you on how to open your stuck file safe. HowTo Open Stuck Sentry Safe H4100 Others
Oct 19, 2014 | Sentry Safe Products Sentry Safe H4100...
Open my sentry safeBD374252*
Hi.
The only way of opening a sentry safe is by using a registered combo, or by contacting Sentry. There is no other simple and non destructive way to open a Sentry.
See here: Sentry respects strong security standards. There is no simple way of hacking a safe if you loos.
Oct 05, 2009 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
495 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
