Question about Tools & Hardware - Others
The Front Roller may have become Hard and the belt won't hold when you adjust just rough up the roller.
Posted on Jun 25, 2009
    Problem Solver:
  • 7 Answers
Try removing the adjustment screws and applying some Teflon thread sealant. That should prevent the screws from turning on their own. Another thing you can do it check the pulleys with calipers and make sure it is still cylindrical. I have seen ones that become worn on one side. Finally, roughly check the belt tension on both sides and make sure they are approximately the same tension.
Good Luck!
Ben Steigerwald
Posted on Jan 12, 2009
How do I get the wheels to pop back out after changing the sanding belt on my old craftsman belt sander #31511720 model?
The tracking adjuster will tilt one wheel in so's you can start putting the belt on. After it gets about halfway, you will need to adjust that the other way and just bump the switch a bit a few times as you adjust and it'll work its way back on.
Feb 03, 2015 | Craftsman 3 x 21 in. Belt Sander, 8 amp
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
How do I adjust an older model 360 sander to keep the belt running stright? I've been trying to adjust the knob on the side but it does not make any difference whch way I turn it the belt runs to the...
Ah. The knob may be way out of adjustment. Since the you've damaged a belt already, use it as a test belt to get the knob back to where it should be. Unfortunately there is no easy solution - it will require some trial-and-error.
Hope this helps.
Apr 27, 2011 | Porter Cable Cable 360 3" x 24" Single...
Craftsman 315.117150. The belt keeps sliding off, as soon as turned on and start to sand. It seems to be on correctly.
You need to adjust the tracking knob which is by the front handle that looks like a triangle head screw. Make sure the belt tension leaver is tight and the belt has enough tension on it. Quickly press and release the start switch and note the centering of the belt. It should be in the center of the bottom platen. If it is not, adjust the tracking knob and bump the switch again. If the belt is going in the wrong direction turn the knob the other direction. Once you are close the center of the platen, press the power switch to turn the unit on and lock the trigger. Firmly hold the unit vertically from the front handle. Fine adjust the tension knob to center the belt and make sure the belt is not hitting the case which will cause damage. You should be able to use the belt sander without the belt slipping off. Let the sander do the work, do not push down and limit the side to side motion. If the belt will not stay on then the belt is too large or the torsion spring needs to be adjusted to applying more tension on the belt and drive roller.
Mar 22, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
My Hitachi Belt sander SB75 the sanding belt moves off rollers as soon as applied to work piece how do I stop this happening?
There is a belt adjustment know on the side of the sander. Turn the adjustment know back and forth while the sander is running until it centers itself.
Jan 01, 2011 | Hitachi 3 In X 21 In Belt Sander, 2 Speed,...
Belt sander Craftsman 315.117150 The spring-loaded bolt that adjusts the front roller has an eye hole into which a spring is fastened to the roller. The eye has broken, consequently I am in need of a new...
Alright, I found the breakdown and it is not a very good one. I think I know the part number that you need, but I would feel more comfortable if you would look at it yourself, because the last thing you need is confusion.
You can also purchase this part right from the link. Their picture shows the spring actually attached to a small rod on the ordering page. Let me know if this helps.
Nov 26, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
How to adjust belt on skil belt sander
There should be a tracking adjustment knob on the side of the sander behind the front roller. Run the saw and adjust this knob to center the belt. You will probably have to do this every time you change belts. Hope this helps you...
Sep 11, 2009 | Sander Tools & Hardware - Others
Sanding belt continually slides off towards one side
The tool has an adjustment control to keep centered on the tool. Should be a knob on the side of the tool. Run the tool with the belt on, and as you adjust the knob you'll see the belt migrate left and right; adjust the knob to where the belt is centered on the tool
Sep 03, 2009 | Porter Cable 362V 4 X 24 Vs Belt Sander
Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Jun 12, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
801 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
