Question about Air King AK80LS Deluxe Fan
I need grill hangers replacement number 5S1202092
I am trying to get the grill hangers for the ceiling light cover. I lost one of them so I need replacements. I looked in the Air King website and the replacement number listed it as part number 5S10202092. Can I order them through you and if not then who can I order them through?
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: I manage an apartment building that was built in
Replacing the entire fixture might be a better choice than repairing the originals; they aren't that costly new.
If you want to pursue replacement motors, Johnstone Supply would be an excellent source if you have on in your area. It is a 'wholesale' supply company for trades-people but I have never been turned away and I've found their counter folks exceptionally helpful. For one thing, these motors are kind of generic so there are several brands that will have the same mounts, etc.
They also have a huge paper catalog you can request or pick up in their stores.
Try them:
Johnstone Supply
Posted on Sep 12, 2009
SOURCE: Need to Buy light cover
I have found searspartsdirect.com to be most helpful.
Marc Arel
Marc the Handyman
Marc Arel Services
mackeral74@hotmail.com
Posted on May 28, 2011
When replacing fan oven element lost wires down back of oven
Best to turn off oven power at circuit breaker. Grab a strong torch and a wire coat hanger. Straighten the coat hanger and make a small hook on one end. Using the torch light guide the coat hanger loop towards some part of the wire and slowly fish it out.
Hope this helps. Otherwise you will be left with no alternative but to pull oven out (heavy) to access the side cover and remove it. It would be helpful to know the make and model of the oven if you needed more help with getting to the wire itself.
Aug 29, 2014 | Ovens
The bras 365+ how come it will not stay flush with the ceiling. Help!!
What I have read is that you must pull the wire through to gather the cone up to be flush with the ceiling.
Seriously I would return it and get another lamp. This does not seem like a good system to me from what I have tried to find out for you.
Apr 03, 2013 | Home
My flush ceiling fan is wobbling and hitting against the ceiling making an awful noise. How do I fix that issue?
The fan blades appear to be out of balance. First, check the screws that hold the fan blade irons to the fan motor. Tighten all that may be loose. If that doesn't solve the problem. the fan hanger bracket behind the ceiling cowl cover may be loose (it's attached with thin screws). In addition, the electrical box, that the hanger is attached to, may have come loose from the ceiling joist. If the electrical box has come loose, the box will need to be reattached to the joist with 1 1/2" long screws.
Hope this helps to solve the problem.
Mar 14, 2011 | Heating & Cooling
Remove ceiling cover plate of Hampton Bay Antigua. This is the model that does NOT have srews on the outside of the coverplate that you loosen before turning. We've tried everything. Left, right.... You...
first you will need a ladder and a screwdriver/phillips a couple wire nuts or electrical tape.at the "top" of the fan you will see a bowl shaped cover it will have usually no more than two screws in it..loosen or remove those screws to access the fan hanger inside.once you get that far inside you will see several wires .undo each wire seperatly and cover with a wire nut or electrical tape(please make sure your power is off to that circuit) once you have unhooked all the wires from the fan and secured them out of the way. lift the fan out of the hanger itself (sometimes it is easier to remove each blade from the motor housing before removing the fan from its hanger ) those screws can be found at the base of each blade on the motor housing..If you are moving or adding a cieling light be sure to remove both parts of the fan hanger..the second part will still be attached to the cieling..usually two screws holding it into place..if just replaacing the fan,,you can sometimes leave the second part there and hang the new fan with it..
look carefully there are screws somtimes with a grommet or paint as these were built in factorys all over the world and are very inconsistent if you rrally cant find screws and it will twist it is always left
left is loose right is tight
lefty loosy righty tighty lol
my grandad taught me that one i always remember
Feb 26, 2011 | Hampton Bay 73554 Antigua Ceiling Fan
Move existing ceiling fan to another location
make sure light switch is off.
start by unscrewing the fan blades. take out bulbs and bulb covers etc.
once all thats down the fan and light switch cover has three screws you can take out and unplug it to get it out of the way. look around the base for some more screws to take out and remove the big cover thats covering the motor. get it out of the way. now you will see the bracket thats holding the motor in place. remove them screws and bolts, but be careful and ready, the motor is heavy, and as it comes down, normally hamptom bay has a coat hanger type hook that will let you hook the hanging motor on the hook long enuff to disconnect the wires ONE AT AT TIME and then put the wire nut back on it just for safety. when they are all disconnected , you can un hang the motor , and then inspect the new fan bracket, it probably fits the same hanger. but if not, you need to take the bracket motor hangar down and get the wires out of it. if the light switch is off IT WONT SHOCK YOU. just dont touch the bare wires to your hands ANYWAY. if they touch each other thats ok. IF THE WALL SWITCH IS OFF. ok now its removed.
Jul 31, 2010 | Hampton Bay 24002 Ceiling Fan
How do I get my hampton bay antigua fan down from the ceiling
Jul 30, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Can not open hood on 1998 town and country lx
is the cable that goes to the hood latch broken?
or is it inside the van were the cable broke?
"if the cable is still were it should be....but the lever is broken......you can get a pair or pliers and pull the cable "metal one not the plastic cover"
but if the cable broke inside the hood and now you cant get it to open....
The only tools required are a set of pliers, a good work light, and coat hanger.
"try to make a hook with the coat hanger"
Set the work light down low so that it shines up through the grill at your latch. The coat hanger pulling action. You must use the coat hanger close to where the cable connects to the mechanism, then pull in a direction as close to that of the cable as possible.
be patient......and if you get it to open have the replacement cable ready.......
hope this helps XD
May 13, 2009 | 1998 Chrysler Town & Country
Char Broil Commercial Series
What you are expierencing is a restriction in either the line coming from the regulator or a bad regulator. Most likely I would lean towards the regulator.
Jun 11, 2008 | Grilling
Air King AK80LS Deluxe Fan Logo
Top Air King Dryers Experts
Are you an Air King Dryer Expert? Answer questions, earn points and help others
