Question about AMD ATHLON XP,3200+,512k Cache (Barton),2.2Ghz,400Mhz (CUAMDXP3200B4)
How to get my CPU to run at the correct speed
In a nutshell, I can't get my AMD Athlon XP 3200+ to run at its optimum speed of 2.2Ghz as it should. I've flashed the Bios to accept the CPU, but I believe ther may be a jumper setting to adjust, if so, which one? Any adjustments in the system Bios only causes instability in the system either causing crashes, reboots at will, or lock ups. There is a solution, as others have had this same problem, but I'm ******** if anyone can come up with a clear solution.
I have attached all the info you should need with CPU-Z readouts, hope you can help.
Cheers
**** J
  • 2 more comments
  • Dogsbreath Jan 15, 2009
    A little more info that may help.
    I understand what you say about getting the board up to an FSB speed of 400, but how? In the bios the only FSB speed I've come across ranges from 100 (default) to 280, this is in the FSB CLOCK. If I set the FSB speed anything above 115 - 120 my system becomes unstable and is suject to crashes and lock ups.
    The DEFAULT VCORE is set at 1.650 which I can't seem to change and the
    CPU RATIO is set at AUTO although it does have the ability to multiply in half increments through a range of 6.0 - 15.0.
    I tried to set this ratio at 14.0 to see what happened and my system would not start, I had to reset the CMOS to get back in.
    I've looked at the jumper theory but I can't find any jumpers on the idiots guide that may indicate that there is a setting for a 3200.
    Any further suggestions.
    Dogsbreath
  • Dogsbreath Jan 16, 2009
    It is the exact board you indicated as Board 1 and as indicated in the CPU-Z
    KT6V MS7021 VER1 N1996
    The MSI live monitor downloaded the update BIOS for this motherboard, and if you look on the website you can see that it supports this chip. I have found the attached photo on the board, does this give you any clues. It seems it may be a setting, if it is, how is the setting made, I can't see any switch? This info is located next to the CPU.
  • Dogsbreath Jan 17, 2009
    This board and CPU were born for overclocking, but I can't get the chuffer up to its optimum speed before I even consider overclocking. I reckon it's that SW1 setting I have to adjust to 1-2 first, but how do I do that? I can't see a switch to throw, just my computer which will soon be taking flying lessons out of the window. I think you're almost there, c'mon, get that brain working.
    **** J
    President:
  • 948 Answers
Your FSB should be 400 MHz for the Athlon XP 3200+ processor.
CPU-Z shows your core speed at 1320 and your FSB at 241. If you multiply those numbers by 1.66, you get 2200 and 400. So all you have to do is get the board to the correct FSB speed of 400 and your core will be right.
There are two MSI boards with the number CPU-Z gives you. Board 1
Board two
The AMD page doesn't show the core voltage for the older processors, they do for the current ones. I looked at the MSI site and didn't see their manuals online for the motherboards either, sorry. I'm not positive it was changed using a jumper though, you saw nothing in the BIOS to set it? If the jumpers are on the board they may be labeled FSB and you can try the various positions.
Hope that helps, good luck.
Posted on Jan 13, 2009
  • 1 more comment
  • Dick
    Dick Jan 15, 2009
    "In the bios the only FSB speed I've come across ranges from 100
    crashes and lock ups."
    That leads me to believe that you do not have a motherboard that will support the 3200+ processor. Does it look like either one of those in the pictures at the MSI site or better yet, can you read the model of the board? If it's there it will be printed directly on the PCB in white letters & numbers.
  • Dick
    Dick Jan 17, 2009
    FixYa has the manual online
    This site says your system clock is 200 and your multiplier is 11. Your core voltage appears to be correct.
    SW1 in your photo should be set to 1-2, giving you a clock speed of 200MHz
    Do you have the MSI utilities described in the manual? Core Center and Live Monitor? It seems odd your default settings are not correct, this board seems ideal, even for overclocking.
  • Dick
    Dick Jan 18, 2009
    The photo you posted appears to have it set on 1-2 already, those two are surrounded by solid white, indicating contact to me. What about the bios settings under Frequency/Voltage control (page 34 in the online manual)? Does your default settings look just like the manual, the "CPU FSB CLOCK" set at 100? If so, when you changed it to 200, did you also change the CPU RATIO to 11.0 and the VCORE to 1.65 in case the auto settings didn't match? And did you leave the memory timing at the default settings?
    You might also try removing all but one stick of memory to eliminate one potential problem.
What must I do into the bios To changes the cpu
NOTHING THE MOTHER BOARD AUTOMATICALLY DETECTS CPU SPEED
Apr 17, 2010 | ASUS A7N8X-X Motherboard
ASUS A7S333 upgrade solution
MPN: A7S333
Product Type: Motherboard
Form Factor: ATX
Width: 30.5 cm
Depth: 21.9 cm
Compatible Processors: Athlon, Duron, Athlon XP
Processor Socket: Socket A
Chipset Type: SiS745
Max Bus Speed: 266 MHz
BIOS Type: Award
Storage Controller: ATA-100
your max cpu would be proably 3200 anthlon xp ok
Jan 10, 2008 | ASUS A7S333 Motherboard
Amd athlon xp 2400+ problems witha epox ep-8kra2+ motherboard?
It sounds to me like the processor that you bought is not fully supported in the current bios in your mobo. I would check the epox website for newer bios. Be careful flashing the bios, if you misstep in the flash, you may end up with a brick. If you are successful, you should be able to run the processor at the speeds you expected, though within the limits of the hardware on the mobo. Also look at the spec's for the mobo on the site to see if your processor is listed as being supported.
Feb 14, 2010 | EPoX EP-8KRA2+ Motherboard
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
CPU (processor) speed dropped to 1.09GHZ
Go back into the Bios and change the settings back. If this does not correct the issue you may have another issue. If this is a laptop you can reset the bios by locating the Bios reset switch, usually appears as a pin hole on the bottom of the computer, if this is a desktop then you need to use the Bios Reset jumper on the motherboard. It sounds as thought Windows is not reading the CPU type and speed correctly so you need to undo the change you made to get it back up to speed.
Aug 23, 2009 | AMD Athlon XP 2600+, 2.13 GHz...
Have a SV266M MOBO. w/amd Athlon XP 1700 CPU. I want to upgrade
i could only fins thease specs for you
AMD Athlon up to 2400+
AMD Athlon XP up to 2600+
AMD Duron up to 1.8GHz
Jun 29, 2009 | Syntax SV266M Motherboard
Bus Speed 200mhz instead 1000mhz
PLEASE INDICATE WHAT IS YOUR PROBLEM....
Jan 08, 2009 | ASUS M2N-E Motherboard
Cpu update
basing from MSI website cpu support for this mobo,
the best AMD processor you can fit on this mobo is
ATHLONXP 3200+.
Barton (0.13u) 200/400MHz FSB 512KB L2 Cache AthlonXP 3000+ 200 Auto OK AthlonXP 3200+ 200 Auto OK
http://global.msi.com.tw/index.php?func=prodcpusupport&prod_no=592&maincat_no=1#menu
Oct 13, 2008 | Intel Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
Computers & Internet Logo
432 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
