Question about Sony Audio Players & Recorders
The CD is locked on my CMT-DX400
I can not open the CD tray . I have a "loched" sign
2 Suggested Answers
SOURCE: Locked Cd Tray
The solution is to turn the machine onto standy and then hold the 'display' button for a few seconds, and voila, the trays are unlocked... geni-arse!
Posted on Dec 25, 2007
How do i open the disc tray on my laptop
Presuming you are talking about a CD-ROM drive, you should first check your manual for information on operating the drive. There are many ways drive trays may be opened. Sometimes there is a button on the laptop that has the standard symbol for CD eject on it that will open the cd tray. Sometimes, there is a small button on the cd-tray itself that when depressed will cause the tray to open after a small delay. This all presumes that you don't have a tray-less
CD drive, that is just a slot on the side of your laptop. If the CD tray is stuck, because of some problem, look for a small hole on the face of the CD tray. Take a straightened out paper clip and push it gently STRAIGHT into the hole until you feel it stop against a bar. Push just a little harder, and the tray should pop open. This latter procedure should only be used when all other methods have failed to open the CD tray.
Sep 04, 2014 | Toshiba Satellite Computers & Internet
Owners manual
Place a flatblade screwdriver in the lower lip of the drawer, and manually force the tray out. It is okay to pull, you won't break the tray. It rides on a straight rail gear. After pulling on it, it should eject normally, but stay open. If it closes right away, there must be some blockage within the case. Using a flashlight, check to make sure no foreign object is blocking the tray. If the tray stays open, that is a good sign. Push it in and see if it closes on its own. Try pushing the button to eject. If the tray does not come out, take it in for service. If it comes out, perhaps the problem is solved.
Jan 26, 2014 | Sharp CD-C401 Shelf System
The cd tray on my computer will not open
HI
use thin and long paper pin to open it,
insert pin in cd tray"s hole which u see in front of CD tray and push it,you will get the Cd tray out..
May 28, 2011 | Computers & Internet
I cant open my cd tray on my tascam dp01
Look on the front of the CD tray for a little hole... push the end of a paper clip in the hole and the tray should open.
Dec 12, 2009 | Tascam DP01 All-In-One Recording Package...
System will not read disk. Keep getting open tray, Have use the dust spray still not working.
An 'Open Tray' error with an XBox 360 is typically a sign that the CD/DVD drive itself is faulty. This will require it to be replaced, which is not as easy as just swapping them out.
The new drive must be of the same make and model of the old drive. If I recall, there are Samsung and Toshiba drives in 360's. Once you have the exact replacement drive, the CD Drive's firmware must be flashed on a PC in order to be compatible and detected by your XBox.
Dec 02, 2009 | Microsoft Xbox 360 Console
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
Packard bell CD rom
Cheak cd rom data cable pluge in maight be cable is unpluged and verify the port connection also
Jul 01, 2008 | Packard Bell GCD-R580B (gcdr580b) Internal...
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
CD-RW Problems
First, try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If that doesn't work, take off the side of the pc and and look to the back of your burner. You will see an ide cable connected to the back, either try a new cable or try the cable that is connected to the hard disk drive, as there will be another connector available. If you do use the burner on the same cable as your HDD then you will have to set the jumper on the back of the burner to slave. It could be a bad cable or faulty ide motherboard connection.
Mar 11, 2007 | Lite On LTR 52327S CD-RW Burner
436 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
